The Audyssey Pro Installer Kit Thread (FAQ in post #1) - Page 202 - AVS | Home Theater Discussions And Reviews
post #6031 of 6060 Old 03-16-2015, 05:42 AM
AustinJerry's Avatar
Quoted: 2311 Post(s)
Liked: 1199
I sympathize with your situation. It sounds like you have gone to great lengths to try and achieve the sound you want. Regarding your question, I am not sure I understand what "do nothing" filters means. And I know of no way to have DEQ, but not Audyssey.
Standing back for a moment, what I am hearing is that you just don't like what Audyssey XT is doing. Unfortunately, Audyssey does not lend itself to much tailoring. The Pro kit target curve editor is just not powerful enough to handle much customization.
There are a number of choices. You can try manual PEQ, which you have done. You could upgrade to XT32, which many of us believe provided significant improvements over XT, but still suffers from limited configurability. Or you could consider an entirely different room correction technology. Other solutions, like Trinnov and Dirac Live, offer much more powerful tools to control calibration results. Dirac, for example, allows you to specify a frequency above which no corrextion takes place, and provides a very powerful target curve editor as well as the capability to save up to four different target curves that are available with a click of the remote control.
Unfortunately, choosing a different RC technology can be expensive. A new processor with Audyssey XT32 is not cheap, while Trinnov has an extraordinarily high entry price. MiniDSP offers several reasonably-priced outboard processors with Dirac Live, but requires that you have external amplification.
So, I don't think there is an easy answer to your situation, but am optimistic that there is some solution that will provide the satisfaction you are looking for. And I respect the effort you have made so far trying to find it. I just don't think Audyssey XT holds the answer anymore. Good luck.
AustinJerry is online now
post #6032 of 6060 Old 03-16-2015, 05:52 AM
kbarnes701's Avatar
Quoted: 3942 Post(s)
Liked: 2985
I agree with you, Jerry. awediophile has certainly gone the extra mile so far. I also agree that other solutions may be more appropriate for him. One thing I would add is that he could use Dirac Live with the miniDSP nano-AVR which does not need external amplification, as it sits between the source (usually a BD player) and the AVR, connected via HDMI. It requires PCM to be sent from the source, which makes it a no-go for anyone using Atmos, which requires bitstream, but other than that it is an interesting option. The nanoAVR-DL is also very affordable at $549. It is the cheapest way into Dirac Live.
kbarnes701 is online now
post #6033 of 6060 Old 03-16-2015, 05:59 AM
kbarnes701's Avatar
Liked: 2985
Originally Posted by awediophile View Post
Anyway, I now have a new problem. I miss Dynamic EQ very much, even despite its own quirks like excessive surround boosting.
TBH this surprises me. As you clearly know what you are doing with manual EQ, why do you miss Dynamic EQ so much? If you create a 'Harman curve' (the one that research shows is most universally preferred, with a gentle downward slope from LF to HF) chances are you won't miss DEQ at all. And if you do, then why not create a few curves with your own inbuilt loudness compensation, to cater for different listening levels you may use from time to time?
When I switched over to Dirac Live, I wondered if I too would miss DEQ. I even had heated debates with friends claiming that it was 'necessary'. However, in reality I have not missed it in the least. Now it is true that I tend to listen at the same SPL almost all the time, but Dirac had no way of knowing that, and yet the response is superb. And I know I can speak for Jerry too, who also uses DL and has not missed DEQ either - and, interestingly, he usually listens at levels quite a bit below my own. And he is using the same target curve as I am too.
Quoting from Sean Olive's article, linked below:
"A flat in-room target response is clearly not the optimal target curve for room equalization. The preferred room corrections have a target response that has a smooth downward slope with increasing frequency. This tells us that listeners prefer a certain amount of natural room gain. Removing the rom (sic) gain, makes the reproduced music sound unnatural, and too thin, according to these listeners. "
So I am wondering if you are not so much missing DEQ as having set up for a curve which doesn't meet your preferences? Have you used a 'Harman' type curve?
For info, this article by Sean Olive gives very useful background info.
This is the general shape of the Harman curve:
And this is the comparison of different curves, from different EQs, showing the Harman Curve as the most preferred.
One of those curves is Audyssey XT - can you guess which?
post #6034 of 6060 Old 03-16-2015, 10:22 AM
awediophile's Avatar
Hi. Thanks for all your responses. I'm a bit surprised at the advice I'm getting. None of the suggested solutions offer a suitable replacement for Dynamic EQ. The problem is to retain the correct the tonal balance with content that is listened below "reference level" (whatever that is for the particular content). Such a correction necessarily must take into account A) the difference in level between reference and playback, and B) the relative level of the content itself. That way it can properly map frequency response between equal loudness contours (http://en.wikipedia.org/wiki/Equal-loudness_contour, but note that Audyssey relies on proprietary data rather than the ISO standard).
No other vendor to my knowledge (Dirac, Trinnov, etc.) offers a suitable replacement for Dynamic EQ. While It is true that a house curve like the one suggested by Harman can help, it only addresses the problem at one particular playback level and does not adapt to the content itself like Dynamic EQ does. For what it's worth, I used to use a target curve more like the Harman curve, but since I got room treatments, that no longer sounds right. Right now, I'm calibrated flat from roughly 250 Hz and up with a gradual rise below there that reaches 4-5 dB at 20 Hz. This gets the balance about right when I play movies back at a level appropriate for my room size and acoustics (i.e., 3-9 dB below theatrical reference, depending on mixing conditions for the Blu-ray) and turn Dynamic EQ off. Unlike with movies, however, I do a lot more casual music listening including at times when other people are asleep in the house, and Dynamic EQ is essential to get the balance. If you look at those contours, you'll see a dip in the 2-4 kHz range that appears at the lower level contours. My response is so tight now that without Dynamic EQ on, I even notice the excess in this region at especially low playback levels.
By the way, neither the standard "Audyssey" target curve nor the mid-range compensation has ever done me any favors. I agree with others that Audyssey probably should have made something like the Harman curve (or the default that Dirac uses) as the standard curve.
awediophile is offline
post #6035 of 6060 Old 03-16-2015, 11:30 AM
Liked: 1199
Well, in that case I think your only option is to consider upgrading to XT32. Consider purchasing a processor from a vendor that has a reasonable return policy and audition the noticeably better RC with DEQ, and if you don't like it, then go back to the drawing board.
post #6036 of 6060 Old 03-16-2015, 04:29 PM
Gooddoc's Avatar
Quoted: 1006 Post(s)
Liked: 550
I'm having the same feeling right now that you get when you beat your head against the wall for an extended period then stop. Sweet, sweet relief....
That may not be understood by all, and I apologize for that. But I seriously have a physical reaction thinking about all the time I spent on Audyssey.
pepar likes this.
Gooddoc is offline
post #6037 of 6060 Old 03-16-2015, 05:02 PM
Liked: 1199
post #6038 of 6060 Old 03-17-2015, 12:13 AM
grassy's Avatar
Quoted: 42 Post(s)
I have placed my order for a pro kit today.
Fame is a mask that eats into the face.
grassy is offline
post #6039 of 6060 Old 03-17-2015, 01:17 AM
I considered that some time ago and opted to buy the OpenDRC units instead. At this point, I'm much happier with the "roll-my-own" approach. In the end, I think Audyssey's biggest flaw is its over-reliance on automation. Yes, automating the whole process does make the technology more accessible to the typical consumer, but as can be seen in these forums, getting good results with Audyssey still requires some sophistication.
I believe Onkyo may have been planning to replace Audyssey on their receivers before Atmos came along because their core users were intimidated by a setup process that requires multiple measurements. That's too bad because measurements at multiple positions really are necessary to get good performance from any decent room correction system.
Perhaps what's really needed is a system that automates everything that can be reliably automated and nothing else. It should also facilitate the process of human review for cases that cannot be reliably automated. In some sense, Room EQ Wizard is already like that in a lot of ways, but its functionality as a room correction tool is primitive compared to what Audyssey, Dirac, and others are capable of. Being that this is the "Audyssey Pro" thread, how much do people here wish for an advanced room correction system that requires more manual intervention to operate but is also more configurable, yields more reliable results, and is at least as powerful (in terms of actual filter performance) than XT32 Pro? How much would such a system be worth paying for, and who would be willing to invest the time and effort to learn how to use it properly?
post #6040 of 6060 Old 03-17-2015, 02:02 AM
d4g
d4g's Avatar
Quoted: 12 Post(s)
All I think is Audyssey needs to redesign the pro approach and make it more manual and give users the ability to create curves and also have the auto version in it too.
d4g is offline
post #6041 of 6060 Old 03-17-2015, 06:17 AM
Liked: 1199
I keep re-reading your original post, trying to understand what you really want. You commented on Audyssey over boosting the high frequencies, yet you fail to acknowledge that one of the most significant changes from XT to XT32 is the change in emphasis away from correcting the high frequencies and focusing more on the low frequencies. You commented that Audyssey frequently sets the sub distance wrong, which I disagree with. And you lamented the loss of DEQ, a proprietary Audyssey technology which will be difficult to duplicate elsewhere.
Adding up these factors, I still think it points towards an XT32 upgrade, at least an evaluation of the technology. With your Pro kit, you can get the most out of XT32, so I am confused why you don't give it a try. If it doesn't meet you requirements, you can continue your search.
kbarnes701 likes this.
post #6042 of 6060 Old 03-18-2015, 10:43 AM
My ultimate question was how I could get Dynamic EQ to turn on without other Audyssey corrections. The rest of my post was to outline why I would want to do this and to bring up some issues and limitations with Audyssey and Pro that I would think most here would recognize. Or not.
I was not aware that XT32 puts more emphasis on correcting low frequencies than high. Can you point me to this information? Going by the chart here it looks like the opposite is true, i.e. the mains filters increased in resolution more than the sub filters did. This is more for reasons of curiosity since I am already committed my custom-made corrections for the several reasons I already outlined. While I would expect XT32 to provide some improvement over XT with its higher resolution filters, I see no evidence that it addresses the fundamental issues I'm seeing. The issue with sub distance is very real, although whether it shows up or not may be situation. In a few cases, the distance Audyssey chose for me put a big null right at the crossover frequency for my center channel. I suspect this may be one of the reasons users frequently report loss of bass when running Audyssey.
Why don't I just upgrade to XT32? Easy. The AVRs that feature it are a lot more expensive, and it's another (mostly) black box solution like XT. I've spent many hours fighting with Audyssey, trying to get it to not do the stupid things that I see in my room measurements and hear with listening. Many of these issues appear to have little to do with filter resolution and more to do with the weighting scheme itself and my inability to see what it's doing under the hood. I've solved *that* problem with my own corrections. Now I just want to keep Dynamic EQ because apart from its handling of surrounds, it makes a big improvement to low level listening.
Anyway, I will try the correction with a loopback configuration sometime in the future and report back.
post #6043 of 6060 Old 03-18-2015, 11:14 AM
Liked: 1199
There were extensive discussions of XT vs. XT32 in the Audyssey thread. Search is your friend. Here is a measurement of the AVR pre-outs that highlight the difference I mentioned:
I understand that a new AVR is a significant expense, but if it meets your objectives, it may well be worth it. I suggested you audition an AVR with XT32 and return it if you feel it isn't what you are looking for. I think I have exhausted the advice I can offer.
AV_mike likes this.
post #6044 of 6060 Old 03-18-2015, 11:22 AM
kbarnes701's Avatar
Liked: 2985
post #6045 of 6060 Old 03-19-2015, 09:45 PM
Liked: 0
I saw something on here about getting a audyssey pro kit from sonny?
Anyway I'm new here, reading way too much, collecting bookmarks, ordering new gear, replacing old gear. Real quick, please tell me to easy way to get a pro kit given the bs audio shops give me when I ask about buying one? I have denon avr-x4000 and I'm pretty sure it's compatible.
Thanks in advance.
donnatronious is offline
post #6046 of 6060 Old 03-20-2015, 06:56 AM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 77 Post(s)
Liked: 76
Thanks in advance.
See the Audyssey Pro FAQ. It will point you to me. I sell them all the time. Contact me off-avs.
I think this will get you to the Pro kit FAQ (Never sure anymore with the new forum software, has some to do with your settings but anyway...)
Scott
scott@techht.com
GetGray is offline
post #6047 of 6060 Old 03-27-2015, 07:41 PM
BCWookie's Avatar
Help with Audyessey pro on marantz 8802
I am attempting to do a Audyssey pro cal on a new Marantz 8802. When I start the measuring stage I keep getting error saying com port open error. I have tried unplugging network cable, doing reset, all firmware up to date. I have also switched the usb input from the serial to USB adapter. This is a brand new kit so I have never done a successful calibration with this equipment. Any ideas much appreciated.
Marantz AV 8802
Goldenear 7.2.4
Oppo 105D
HTPC
BCWookie is online now
post #6048 of 6060 Old 03-27-2015, 08:14 PM
Liked: 1199
Unless something has changed, the network is not used for a Pro calibration on Marantz. The laptop is connected to the AVR using the serial-to-USB cable. And the cable from the mic amp is plugged into the left channel RCA connection on the AVR from panel. Is this how you have everything connected?
When you launch the Pro software, you should be asked to select the AVR model you are using. After making the selection, there should be a pop-up asking you for the license key. Have you reached this point and successfully entered the license key?
Next step is to start taking measurements, at which time the mic needs to be connected properly (left RCA input on front panel as described earlier). Where exactly in this sequence is your attempt to calibrate failing?
post #6049 of 6060 Old 03-27-2015, 08:57 PM
BCWookie's Avatar
I can get all the way to the measurement phase. I start with sub levels and it reports numbers, but then with come up with com port open error. I can then stop the sub measure after and move forward to first position measure. It will start and show L Front then center etc but will then give me the same error. When I push the ok to clear the error, It resets and wants me to start the fist position again. I seems to be related to the com port or SERIAL to USB adapter(it s the one that came from AUdyessey).
Another question while I have your ear, I have done a standard Audyssey calibration, since pro is not working for me, and my sub trim is -6.5. I remember reading that it is best if this is +/- 3.5 for headroom. So should I redo calibration with sub grain lower?
Thanks for any and all help
Marantz AV 8802
Goldenear 7.2.4
Oppo 105D
HTPC
post #6050 of 6060 Old 03-27-2015, 09:15 PM
Liked: 1199
I would not be concerned about the sub trim. As for the failure to complete the measurements, I don't have any more advice to offer on the error you are getting. Perhaps someone else will have some insight.
post #6051 of 6060 Old 03-27-2015, 11:57 PM
retate's Avatar
Quoted: 24 Post(s)
Liked: 27
The Marantz AV8802 for a pro calibration does connect via the RS232 port the same as previous Marantz products.
Bob
retate is offline
post #6052 of 6060 Old 03-28-2015, 12:13 AM
retate's Avatar
Quoted: 24 Post(s)
Liked: 27
I suspect the problem is with the USB to serial/RS232 adapter. Some things to consider:
- Update to the latest driver the USB adapter if you are running a version of Windows prior to Windows 8.x. Drivers in past have been available from the web site for the chip vendor for the RS232 adapter.
- Do not connect the USB connection via a hub.
- Try different USB ports. The support chip support on either a desktop or a laptop may vary with the port.
- Try a different USB to serial adapter if you have one.
- If you have a computer with an actual RS232 port try that.
- If you are using an RS232 cable between the USB adapter and the Marantz, try a different RS232 cable. Some RS232 cables do not support all connections, and some are wired as crossover cables.
I can confirm that with a 5.1 channel configuration that I have been run a Pro calibration on an AV8802. I was not using the USB to serial adapter that came with my Pro kit which is from several years ago because the chip set on the adapter that was supplied at that time is not supported on Windows 8.x.
Bob
retate is offline
post #6053 of 6060 Old 03-28-2015, 06:38 AM
Liked: 1199
I seem to recall previous discussions regarding getting a different brand Serial-to-USB cable to solve communications issues, so you may be onto something there, Bob. Perhaps you could recommend the brand cable you are using? However, I would think Audyssey would keep current and provide working cables, assuming the OP's Kit is recently purchased.
post #6054 of 6060 Old 03-28-2015, 07:20 AM
Wireless member
pepar's Avatar
Quoted: 306 Post(s)
Liked: 193
I have no doubt that it is a Windoze driver issue wrt the USB-to-serial adapter. When I had a processor that calibrated via serial, and moved to Win 7 I fixed my com port timeout errors be going to the manufacturer of the chipset (of the adapter) and getting their driver.
The advice previously given is spot on. if you have a desktop PC you can probably use its RS232 port if it has one, or attach to the RS232 motherboard header to bring it to the backplane ... or get an add-in card if it has neither.
If sticking with the laptop, look closely at port communications setting - try different baud settings.
I will add that my quality of life improved dramatically when my next processor calibrated over Ethernet.
Jeff
pepar is offline
post #6055 of 6060 Old 03-29-2015, 05:41 AM
Ganymed4's Avatar
Quoted: 52 Post(s)
Liked: 62
I would also consider a reset of the AV8802. I experienced several problems with Onkyo PR-SC5509 and Pro and always a reset of the pre/pro helped. However, this error description sounds more like the interface of the computer.
Ganymed4 is offline
post #6056 of 6060 Old 03-29-2015, 02:31 PM
retate's Avatar
Quoted: 24 Post(s)
Liked: 27
I am using the following USB to serial interface note that it is version 2 of the product. The only disadvantage to this product is that it is designed to connect via the connector being screwed to it which is also the case with the Marantz. Thus, although the male-female orientation is correct to connect to the Marantz the nuts to screw into prevent making a connection so I use a RS-232 straight through cable (male to female) which screws into both the adapter and the Marantz.
http://www.trendnet.com/products/pro...prod=265_TU-S9
I would also assume that Audyssey would keep current and provide working cables. My Pro kit was purchased in 2009 so the fact that the chipset in the serial adapter is end-of-life in terms of support on current operating systems is common practice. The drivers for the Prolific chipset which is used by multiple USB to serial adapter vendors can be found here. For Windows 8 and 8.1 there has been no need to go to the vendor website for drivers as they can be installed automatically via Windows download.
http://www.prolific.com.tw/US/ShowPr...id=225&pcid=41
The most common problem in serial communications that are somewhat working that I have encountered is that flow control is not working as required. Thus, a failure may be encountered when Audyssey is transferring data either to or from the AVR or processor. There are multiple reasons for flow control problems which are beyond what can be covered in a short post.
Bob
retate is offline
post #6057 of 6060 Old 04-12-2015, 06:48 AM - Thread Starter
SoundofMind's Avatar
Liked: 162
Hi guys. As some of the regulars know, I've been MIA from AVS for some time now due to family circumstances. I had hoped real life would settle down and I could enjoy being an active part of this great community again, but that's not happened yet.
So I skim a few threads once in a while and respond to PMs. As such, it was brought to my attention via PM that the links to the Audyssey FAQ in posts 1 and 2 on this thread were no longer working, so I fixed them.
Best to all,
SoM
Yes, I still like playing with Dalis.
SoundofMind is online now
post #6058 of 6060 Old 04-12-2015, 07:09 AM
kbarnes701's Avatar
Liked: 2985
Best to all,
SoM
It's terrific to see you back, even if only briefly. I hope you are sitting in that very special chair of yours on a regular basis and enjoying your music!
post #6059 of 6060 Old 04-12-2015, 12:26 PM
Wireless member
pepar's Avatar
Quoted: 306 Post(s)
Liked: 193
Best to all,
SoM
We are very glad to read a post from you as some of us had feared the worst for you.
Warmest regards,
Jeff
pepar is offline
post #6060 of 6060 Unread Today, 05:54 AM - Thread Starter
Liked: 162
Thanks, Keith. After all the many years upgrading and tweaking the system with help from so many here, I cherish those times I can just plop down at the end of the day and escape into music or film for a bit.
Warmest regards,
Jeff
Oops, geeze, my apologies Jeff. I mistakenly thought you had been informed long ago that I wouldn't be posting as family matters would be eating up all my time and energy.
I miss you guys, the tech talk and the interesting and spirited debates. But I know how addictive this forum can be for me so for now I must return to my virtual hiatus. Best to you all.
Denon Avr4310ci Receiver , Audyssey
