The Audyssey Pro Installer Kit Thread (FAQ in post #1) - Page 211 - AVS Forum | Home Theater Discussions And Reviews
 91Likes
post #6301 of 6316 Old 01-05-2017, 08:36 PM
Scott Horton, techht.com
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Originally Posted by IP2GSR View Post
I tried to log onto the Audyssey Pro Installer page but also found you need a serial number to get started.
In lieu of that......Would someone with a login ID mind looking up to see if the Pro Kit is compatible with the Marantz SR7008 receiver.
I know that it is compatible with the SR7007 and the SR7010 but can't confirm the model I own.
Kal..... if BobbyHollywood is not interested in your ProKit I might be.
Dave
The Marantz SR7008 is listed in the device drop-down.
IP2GSR likes this.
GetGray is online now
post #6302 of 6316 Old 01-05-2017, 08:39 PM
Liked: 0
Thanks a lot for taking the time!
IP2GSR is offline
post #6303 of 6316 Old 01-05-2017, 09:05 PM
GetGray's Avatar
Quoted: 170 Post(s)
Liked: 146
Welcome. If you need a new Pro kit, contact me off-line.
post #6304 of 6316 Old 01-08-2017, 12:45 PM
Kal Rubinson's Avatar
Quoted: 682 Post(s)
Liked: 461
Dave
I have 2.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #6305 of 6316 Old 01-16-2017, 05:05 PM
MBrown2020's Avatar
Quoted: 30 Post(s)
Pro Software transferring wrong distances to AVR
When doing a pro calibration on a Marantz AV-8802a, the pro
software (Version 4.1.0.88) distances for the speakers are not
transferring to the AVR correctly. The levels all transfer correctly , though.
Audyssey Pro Distances // When checking results in AVR
LF 11.8ft // 11.9ft
RF 11.8ft // 12.0ft
CEN 12.9ft // 13.1ft
L Surround 4.7ft // 4.8ft
R Surround 4.8ft // 4.9ft
L Back 4.8ft // 4.9ft
R Back 4.9ft // 4.9ft
L Height 14.9ft // 15.1ft
R Height 15.0ft // 15.2ft
Sub 15.6ft // 15.8ft
As you can see, some are correct and some are slightly different. I
have reset the AVR and did another calibration with the same results. Is this a bug? Anyone else experience this?
Should I just manually change the distances in the AVR?
Thanks for any help!
EDIT:
I set the pro software to meters and everything transferred correctly. Audyssey sent the info to marantz, but marantz will have to issue a firmware update to address the feet not tranferring correctly
jsgrise likes this.
MBrown2020 is offline
post #6306 of 6316 Old 01-26-2017, 01:45 PM
jsgrise's Avatar
Quoted: 179 Post(s)
Liked: 81
Hey guys, very interesting read here! Since I am always looking to improve the sound of my theater (bit of OCD here), I am thinking of making the jump to Audyssey Pro to work with my Marantz SR-7010.
How much of an improvement does it makes over XT32? Is the customization of the curves the biggest asset?
Do you guys have an idea where I can buy one in Canada?
Thank you for your help!
Dedicated HT | DUAL 18" Dayton RSS460HO Custom Build | Sonus Faber Venere 1.5s | Sonus Faber Venere Centre | Sonus Faber Venere Walls | Marantz SR-7010 | Behringer iNuke 6000DSP | Velodyne SMS-1 | JVC D-ILA RS-46 w/ 128" 16:9 1.4 | Custom Bass Traps and Acoustic Panels (11)
jsgrise is online now
post #6307 of 6316 Old 01-27-2017, 01:51 AM
AV_mike's Avatar
Quoted: 90 Post(s)
Liked: 86
The Pro kit is of marginal value for most users, especially when taking it's cost into account. It's main advantage is not being limited to 8 positions ( allows up to 32), but unless you've got a really big multi seat cinema that won't be an issue. The curve editor is very limited, maximum boost/cut is 3dB, and the interface is poor.
The pro points are the ability to turn off the Midrange Compensation Dip, and the far superior individually calibrated microphone and preamp. As well as the facility to choose the best crossover prior to the final correction calculation.
My original Eiffel Tower mic gave poor bass balance, when measured with REW using a calibrated mic (CSL), but the Pro Kit always gave perfect balance - so I have to conclude that my standard mic whilst being within it's cal limits, was not that good.
Also, please be aware that the Pro Kit does NOT improve the filter capabilities of XT32 - it can only improve the input data (and that's not guaranteed).
Regards, Mike.
alebonau likes this.
AV_mike is online now
post #6308 of 6316 Old 01-27-2017, 06:23 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Just to supplement that, the +/-3dB curve adjustments have always been enough for me. Even a +1dB tweak can be effective. IMO, if someone needs more boost/cut than 3dB, I would suggest that they are fixing something that should be addressed elsewhere.
Someone on another thread wanted to boost bass by 8dB. I had so much to say about that with much of it questioning his system, his room and even more importantly, what he thought bass response should be. Not knowing how to do that "tactfully" that discussion went ... undiscussed.
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is online now
post #6309 of 6316 Old 01-27-2017, 09:58 AM
AV_mike's Avatar
Quoted: 90 Post(s)
Liked: 86
Jeff
I personally agree with you, but a common request on the forums appears to be implementing 'house curves' - that virtually always turn out to be huge boost at the bass end - with figures of +10dB being 'common', but more usually about +6dB. This sort of curve manipulation is not the purpose of the Pro curve editor - and is simply beyond it's capabilities.
Best regards, Mike.
post #6310 of 6316 Old 01-27-2017, 10:05 AM
genesplitter's Avatar
Quoted: 30 Post(s)
Liked: 25
Does the Pro Kit allow you to limit corrections to only the frequencies below the room transition frequency (typically 300 Hz - 500 Hz) and therefore leave frequencies above the transition frequency uncorrected.
Marantz SR-7009 AVR, iNuke 6000DSP, DIY LinkwitzLab speakers, MartyCube + JohnnySub, BenQ W1070, Roku stick, Plex, next project: diy AT spandex screen
genesplitter is offline
post #6311 of 6316 Old 01-27-2017, 10:10 AM
AV_mike's Avatar
Quoted: 90 Post(s)
Liked: 86
NO.
post #6312 of 6316 Old 01-27-2017, 10:16 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Best regards, Mike.
Exactly! And getting to why someone feels that they need +6dB to +10dB bass boost is beyond the capabilities of this forum.
pepar is online now
post #6313 of 6316 Old 01-28-2017, 06:38 AM
Archaea's Avatar
Quoted: 2866 Post(s)
Liked: 2447
Reference vs. preference.
I'm just gonna drop this here.
http://www.innerfidelity.com/content...ZBpCoJeq0Iy.97
It appears in studies done by Toole, Olive, Harmon Kardon etc, that most people prefer a house curve of 9-10dB favoring the lower end of the audible spectrum.
Archaea is offline
post #6314 of 6316 Old 01-28-2017, 07:14 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Yeah, reference vs. preference. But I seriously doubt that many bass goosers' House Curves have the magical 10dB downward slope from 20Hz to 20KHz fabled in story and song.
Jeff
pepar is online now
post #6315 of 6316 Unread Today, 09:06 AM
bobdit's Avatar
I have one that I no longer need as I dont own an audyssey pro receiver anymore. I am in the Toronto area if you are interested.
bobdit is offline
post #6316 of 6316 Unread Today, 02:38 PM
jsgrise's Avatar
Quoted: 179 Post(s)
Liked: 81
Just PMed you.
Denon Avr4310ci Receiver , Audyssey
