The Audyssey Pro Installer Kit Thread (FAQ in post #1) - Page 40 - AVS Forum | Home Theater Discussions And Reviews
 92Likes
Old 02-11-2012, 07:19 AM
GPBURNS's Avatar
Quoted: 133 Post(s)
Liked: 302
if same as the 80.1, need to connect to back.
and heads up, the connection is really tight.
would recommend to keep cable connected
for future use.
15400 Watts of Seaton Power -Quad SubMersived
GPBURNS is offline
Old 02-11-2012, 08:31 AM
mjf_uk's Avatar
Pro Kits are back in stock. I got shipping confirmation in the early hours of this morning.
mjf_uk is offline
Old 02-11-2012, 08:51 AM
jmschnur's Avatar
What is the story on the 80.3 firmware update?
jmschnur is offline
Old 02-11-2012, 08:56 AM
bslep's Avatar
Quoted: 98 Post(s)
Liked: 81
for future use.
The 80.2 doesn't have an auxilary input on the back.
bslep is offline
Old 02-11-2012, 09:28 AM
mjf_uk's Avatar
I don't know about the 80.3, as I've only been getting updates on the 5509. I guess they'll most likely be in the same update though. The latest I've heard about the 5509 is that they are testing another firmware from Onkyo and will release the update as soon as they're happy that everything is good.
mjf_uk is offline
Old 02-11-2012, 09:33 AM
Wireless member
pepar's Avatar
Quoted: 1021 Post(s)
Liked: 526
for future use.
Audyssey mic plugs into "Game."
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
Old 02-11-2012, 09:39 AM
bslep's Avatar
Quoted: 98 Post(s)
Liked: 81
Thanks! I assume the top/white rca connection? Where in the world do any of the instructions tell you that?
bslep is offline
Old 02-11-2012, 11:03 AM
Wireless member
pepar's Avatar
Liked: 526
Yes, left channel. The instructions are in the MultEQ Pro software. Each screen has detailed instructions for step at hand.
Jeff
pepar is offline
Old 02-11-2012, 11:31 AM
bslep's Avatar
Quoted: 98 Post(s)
Liked: 81
Jeff
Thanks so much Jeff. I wanted to get everything straight before I tried it. Bob
bslep is offline
Old 02-12-2012, 08:58 AM
Digione's Avatar
Quoted: 22 Post(s)
Liked: 35
I would like to use the Audyssey Pro Mic and pre-amp as a calibrated source for REW and AudioTools. Does anybody know of a way of converting the Audyssey Pro mic calibration file into a flat Excel spreadsheet so that I can import it into both of these applications?
Digione is offline
Old 02-12-2012, 10:03 AM
mjf_uk's Avatar
Sounds like a good idea if it's possible. I'm sure it will be better than the Radio Shack Meter I was thinking about using. I'd also be interested to know if this is possible.
mjf_uk is offline
Old 02-12-2012, 11:34 AM
Digione's Avatar
Quoted: 22 Post(s)
Liked: 35
The Audyssey Pro mic is calibrated within 0.5dB from 20Hz to 20KHz when used in conjunction with its EQ file. It is a terrible waste of a resource not to be able to use it with other acoustic software applications.
I have looked at lots of web sites, programs and "tools" to look at the mic .apm file but its header does not appear as a standard .apm file. I am therefore unable to open it except with a Hex editor. This did not help me
Any software engineers out there that can help here?
Digione is offline
Old 02-12-2012, 12:54 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 7036 Post(s)
Liked: 3928
This has been discussed before. To my knowledge, no one has successfully obtained a calibration file that will let you use the Pro mic with REW. I believe a suggestion was made that you could send the mic to a place like Cross Spectrum Labs (http://www.cross-spectrum.com/) to get it professionally calibrated, but for the cost of the calibration, you could purchase a mic like the EMM-6, which comes with a calibration file and works well with REW.
One such discussion: http://www.avsforum.com/avs-vb/showt...5#post19966155
AustinJerry is offline
Old 02-12-2012, 02:17 PM
Wireless member
pepar's Avatar
Liked: 526
Yes, AJ, anyone wanting to use the Pro mic in an application other than the Pro software would need to send it out to be calibrated. I did it, but it was a waste of money as it cost about the same as what they sell the calibrated EMM-6 for.
Jeff
pepar is offline
Old 02-12-2012, 04:00 PM
Digione's Avatar
Quoted: 22 Post(s)
Liked: 35
Jeff
Well thats a pity. Looks like the EMM-6 is in my future.
Digione is offline
Old 02-12-2012, 04:25 PM
Wireless member
pepar's Avatar
Liked: 526
Get the 0° and 180° calibration files.
pepar is offline
Old 02-12-2012, 04:36 PM
Liked: 3928
If the mic is pointed at the ceiling, isn't the 90 degree calibration file the right one? I am assuming that the mic in REW should be pointed vertically like the Audyssey mic, correct?
Old 02-12-2012, 06:48 PM
Wireless member
pepar's Avatar
Liked: 526
I misspoke. Pointed at the ceiling, you need the 90 degree cal. But there are measurements that are taken with the mic pointed directly at a speaker and that is the zero axis.
Jeff
pepar is offline
Old 02-15-2012, 04:31 PM
Digione's Avatar
Quoted: 22 Post(s)
Liked: 35
Jeff
Noted, I will get as many calibrations as my bank account will allow.
Digione is offline
Old 02-16-2012, 06:59 PM
HTPCat's Avatar
Quoted: 600 Post(s)
Liked: 344
Just got my pro kit and purchased the licensce for my denon 4311 - I am about to activate the license and it says I need to use the last 6 digits of the MAC address which I have located in 3 places. 2 show an uppercase letter (the back of the AVR & the box) and the setup menu shows lowercase and hex will be different for upper and lowercase right so which one do I use?
HTPCat
"I have a need to feed the hole with more Audio & Video toys"
HTPCat is offline
Old 02-16-2012, 07:15 PM
Wireless member
pepar's Avatar
Liked: 526
it is not case sensitive.
pepar is offline
Old 02-16-2012, 07:46 PM
HTPCat's Avatar
Quoted: 600 Post(s)
Liked: 344
Thanks good to know - the audyssey pro installer site indicates that it is case sensitive.
HTPCat
HTPCat is offline
Old 02-16-2012, 07:55 PM
Liked: 3928
You cannot go wrong by entering the MAC address exactly as it is shown in the menu, i.e. preserving the case. This way whether it is case sensitive or not becomes a moot point.
Old 02-18-2012, 09:58 AM
HTPCat's Avatar
Quoted: 600 Post(s)
Liked: 344
A few more questions from a newbe : for 1st placement of the mic @MLP do you place in the center of ears with top of mic at ear height? Or do you place mic at either right or left ear position?
I have my denon 4311 & a HTPC connected to my network and have the Denon's ip address will this be all I need to do for connecting other than the mic? And finally where does the mic connect on the Denon 4311? Your help is always appreciated.
HTPCat
HTPCat is offline
Old 02-18-2012, 10:12 AM
Liked: 3928
I place the tip of the mic where the center of my head would be, not where the side of my head would be.
The network plays no role in a Pro calibration on a 4311. There is a Serial-to-USB cable that connects to the RS232 port on the back of the AVR, with the other end connected to a computer's USB port. A laptop is the most convenient computer to use. The Pro mic has a standard RCA plug that connects to the AUX input port behind the drop-down panel on the front of the 4311. It connects to the LEFT AUX IN port.
Old 02-18-2012, 10:18 AM
kbarnes701's Avatar
Quoted: 6774 Post(s)
Liked: 5128
It really doesn’t matter. It's not necessary to get it to millimeter accuracy. Just set the mic to where you think your ears/head will be when listening - they won’t stay in that same place throughout an entire movie unless you watch with your head in a vice. My 'nominal' ear height when listening is 35 inches, so that's how I set my mic - but I know full well that I will move around while the movie is on, certainly by an inch or two.
kbarnes701 is online now
Old 02-18-2012, 10:33 AM
Liked: 3928
Originally Posted by kbarnes701 View Post
It really doesn't matter. It's not necessary to get it to millimeter accuracy. Just set the mic to where you think your ears/head will be when listening - they won't stay in that same place throughout an entire movie unless you watch with your head in a vice. My 'nominal' ear height when listening is 35 inches, so that's how I set my mic - but I know full well that I will move around while the movie is on, certainly by an inch or two.
I don't disagree, but accuracy has a lot to do with repeatability. We both have read countless posts about repeating calibrations over and over again until you get "a good one". I have found that by being accurate, I can get a good, predictable calibration every time.
Old 02-18-2012, 10:40 AM
kbarnes701's Avatar
Liked: 5128
Yes that is a fair point. Where I tend to become bemused is when I see people agonising over mic placement to the fraction of an inch. It isn't that critical and Chris himself has said this on more than one occasion. For example, the usual advice is to space the mic positions out by putting them 2 feet apart and I have read of people getting out a measuring tape and measuring this to the fraction of an inch! It just isn't necessary - approximately two feet apart is good enough. But yes, wrt to repeating a set of measurements in another calibration, I agree totally that it is easier and more certain to give a consistent, reliable result if you can put the mic back into the same place. I know from experience where my mic needs to go to be able to repeat a calibration consistently, but I don't fret overmuch about getting it right to a quarter of an inch
Old 02-18-2012, 02:29 PM - Thread Starter
SoundofMind's Avatar
Liked: 166
It really doesn't matter. It's not necessary to get it to millimeter accuracy...
That is a pinhead response.
Any cool HTP cat knows that the first position is arguably unique irt meriting this degree of attention and accuracy. Pos #1 sets the levels and delays for all channels, hence the SOP SoM recommendation for the mic to ideally be positioned between where your ears would be. This assumes a properly placed MLP as that precludes breaking more important mic position rules and insures best SQ.
Yes, I still like playing with Dalis.
SoundofMind is offline
Old 02-18-2012, 02:51 PM
kbarnes701's Avatar
Liked: 5128
It really makes no difference if you move the mic by 1 inch for the first position. It can't possibly be accurate for the actual listening position, except for people who put their head into a vice when watching a movie.
When I watch a movie, sometimes I sit upright, sometimes I slouch, sometimes I lean on the left armrest, sometimes on the right sometimes I recline my chair more, sometimes less. So where would I put the mic for the MLP out of those 6 choices? So long as it is pretty much in the ballpark it will be OK.
And of course, this isn't even to mention the case where people (me for example) have their couch up against the wall and their head is too close to the wall to put the mic at the actual listening position and they have to set it about 18 inches or more away from the wall, which puts it somewhere in front of where their head has to go.
Close enough is good enough - unless of course you really do sit with your head in a vice (vise I believe they’re called in your neck of the woods )....
I'm not suggesting anyone takes a totally cavalier attitude to mic placement, because that would be wrong. Just saying that it isn’t necessary, or even practically possible, to get it down to a half inch... and even if one does, it will be wrong the next time they move their head while watching their movie.
Denon Avr4310ci Receiver , Audyssey
