The Audyssey Pro Installer Kit Thread (FAQ in post #1) - Page 42 - AVS Forum | Home Theater Discussions And Reviews
 91Likes
Old 02-27-2012, 11:59 AM
counsil's Avatar
Originally Posted by jmschnur View Post
I just installed 3.5 .i had been using 3.4. With the same data it had different priorities for my mains.
3.4 : 80. Hz, 40hz, 70 hz, 60 hz
3.5: 80hz, 70hz, 40hz, 60 hz
Is the algorithm different for priortization in 3.5?
This has been my experience:
Audyssey makes bug fixes in every release of Audyssy MultEQ Pro but they do not publish, nor admit to, them unless you ask about a specific bug that they just happened to fix in a newer release. They are very tight lipped regarding bug fixes and I don't blame them.
Consumer:
Installer:
Never argue with an idiot; they drag you down to their level and beat you with experience.
Counsil Basement HT
counsil is offline
Old 02-27-2012, 02:35 PM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6630 Post(s)
Liked: 3661
Consumer:
Installer:
The issue Jmschnur has reported is likely not related to the software upgrade. Rather, it is the way the software works. For example, I ran a Pro calibration over the weekend and recorded the recommended crossovers in a worksheet. To see if the calculation algorithm results in consistent recommendations, I loaded the saved measurements from the weekend calibration and let Pro run he calculations a second time.
As you can see in the attached file, the second set of recommendations do not match the first. Strangely, 40 Hz disappears completely from the second set of recommendations. Perhaps this is a bug, or perhaps the algorithm is so complex that it returns different results each time (which would be upsetting).
So, is it a bug and, if so, is it significant to warrant a case with Audyssey TS?
Edit: why can't I see the attached PDF on my iPad???
Pro Crossover Test.pdf 262.63671875k . file
AustinJerry is online now
Old 02-27-2012, 02:57 PM
jmschnur's Avatar
Since you have the records, could you ask Luke about this ? In my case 80 was top for both. 40 and 70 were reversed.
jmschnur is offline
Old 02-27-2012, 03:33 PM
Liked: 3661
Sure, I'll be glad to.
Old 02-27-2012, 04:44 PM
GPBURNS's Avatar
Quoted: 125 Post(s)
Liked: 286
thats really odd
I always save a few calibration
and reload a lot
but have never seen that happen
hmmm - be interesting to hear their response
post it on ask Audyssey
15400 Watts of Seaton Power -Quad SubMersived
GPBURNS is offline
Old 02-27-2012, 05:33 PM
S_rangeBrew's Avatar
Quoted: 20 Post(s)
Liked: 43
Originally Posted by hclarkx View Post
I'd like to toss this subject out for comment since I don't recall seeing it in any of the Audyssey forums. When I first got my hands on a Pro Installer kit I used it to help identify the best sub locations in my HT. I moved the sub to the feasible locations and ran a single mic location & measurement first at my chair and then at my wife's chair. I looked at the two "before" plots and moved the subs around until I found the best locations. Since I had two subs, I picked locations where the two subs would be highly complementary at the two seats. This was before the SubEQ came along but might still be worth doing to ensure the needed corrections are well within the SubEQ's correction capability. For those without a SubEQ, it's even more beneficial.
What I particularly found was that the poor sub locations could indeed cause problems that were well beyond full correction by Audyssey. One was a dip in the response that was about 20 db deep. It fell at a different frequency at each seat. As you experts might guess, that was with a sub on the right or left walls about even with the seats. The direct wave and reflected wave are both strong and meet out-of-phase at the seat.
I ended up with one corner sub to the left of the mains and one to the right at a point 2/3 of the way across the wall (this spot excites fewer of the lower room modes). Neither sub had peaks or valleys beyond about 8 db and both were less with both subs connected. Not surprisingly, both subs are equidistant from the listening position.
REW can be used for this purpose, but most of those on this forum have the Pro kit and can easily use it for this purpose.
If this isn't clear, let me know. If it makes sense, maybe it can go into the second post in the thread on use of the Pro kit.
Thank you for the excellent post. I'm using dual subwoofers with XT32, and will be using REW to fine tune the initial placement in the near future. This placement will be especially critical for me, as I will be replacing my current subwoofers with infinite baffle manifolds, which require holes to be cut in the floor. It's nice to hear of some real world experience with these types of measurements.
S_rangeBrew is offline
Old 02-27-2012, 09:22 PM
calentz's Avatar
Quoted: 58 Post(s)
Liked: 42
Originally Posted by GPBURNS View Post
thats really odd
and reload a lot
If memory serves me correctly, it is recommended to run the COMPLETE cal because dropping the former cal's data into a new run gives inconsistent results. (Saving & using former cals are OK as long as no changes [to them] are made at that time)
--Carl
calentz is online now
Old 02-27-2012, 09:37 PM
jmschnur's Avatar
No changes. Just the data reloaded to change the effect of xovers. Priortization was different but I used 3.4 first then 3.5.
jmschnur is offline
Old 02-27-2012, 11:05 PM
Liked: 3661
Let me clarify:
- You can't re-start a calibration by loading original measurements and adding new measurements with MultEQ XT32. This is a known issue that Audyssey has acknowledged. If you want to add more measurements, you have to start over.
- You can load original measurements to select different crossovers, run the curve editor, etc. You don't have to start over as long as you don't add measurements.
Old 02-28-2012, 01:30 AM
streetsmart88's Avatar
Originally Posted by AustinJerry View Post
Let me clarify:
Jerry,
I thought that this issue affected only those cases when you had 2 subwoofers and that the issue was resolved if you eq'd the 2 subs as one through a Y-connection?
Are you saying that you can't load measurements and then add more measurements, whether you have 1 or 2 subs?
Mark
streetsmart88 is offline
Old 02-28-2012, 04:05 AM
GPBURNS's Avatar
Quoted: 125 Post(s)
Liked: 286
I always had a few different saved (completed) calculations -
depending on how many viewers.
bigger the crowd - larger the spread on my data points
GPBURNS is offline
Old 02-28-2012, 04:08 AM
GPBURNS's Avatar
Quoted: 125 Post(s)
Liked: 286
Originally Posted by streetsmart88 View Post
Jerry,
Mark
I have not had chance to run pro on my 80.3 (waiting on firmware)
that is major bug if true -
being able to continue measurements was great feature on my 80.1
GPBURNS is offline
Old 02-28-2012, 04:19 AM
gurkey's Avatar
Quoted: 129 Post(s)
Liked: 91
I don't think that it makes any sense to be able to "continue" earlier measurements because even a small deviation of the measuring process or mike position might invalidate the older measurements in comparison to the new ones.
gurkey is offline
Old 02-28-2012, 05:11 AM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5071
kbarnes701 is offline
Old 02-28-2012, 05:14 AM
I'm not sure I understand what you're trying to say. This is a great feature of Pro because it takes a very long time to take the measurements. You can do 8 mic positions, save and then reload in the future, at which time you continue with positions 9-15 or whatever. There should be no way you "invalidate" older measurements.
Mark
Old 02-28-2012, 05:19 AM
Originally Posted by kbarnes701 View Post
WOOT!! My Pro kit has arrived. All I need now is some Firmware....
Meanwhile, you can stare at and admire the mic?
Mark
Old 02-28-2012, 05:23 AM
Answer Seeking / Sharing
cavchameleon's Avatar
Quoted: 194 Post(s)
Liked: 219
Mark
I agree with this especially if nothing has changed in the room and you are just 'adding' more measurements. I usually do 15, but have added more later (did them in approximately the same positions, just a couple inches higher). In the end, the results looked the same though, so as Chris pointed out in the past, there is a point where more measurements do not yield better/different results. It would really depend on the room.
Ray
"Listen with an open heart and mind."
cavchameleon is offline
Old 02-28-2012, 05:24 AM
kbarnes701's Avatar
Liked: 5071
Mark
Yep. Just unpacked everything out of the carry-case, admired, and packed away again...
Old 02-28-2012, 05:29 AM
Quoted: 194 Post(s)
Liked: 219
That's funny! Did the same thing when I got mine since I did not have time in my schedule to run it for a couple weeks. It'll be worth the wait in the end!
Ray
Old 02-28-2012, 05:32 AM - Thread Starter
SoundofMind's Avatar
Liked: 166
Good points. Great idea, I added some links in the second post. BTW, I'd mentioned this "value-added feature" of using Pro for sub placement here. I listed some "pros and cons" of Pro as a measurement tool here. It was then pointed out to me by fellows with dedicated measuring systems, and more experience measuring than I, that systems like REW, OmniMic, etc., are better and faster. The most dedicated measurers point out that the graphs with far less smoothing can reveal much more, and thus be even more useful, than the Pro graphs.
Yes, I still like playing with Dalis.
SoundofMind is offline
Old 02-28-2012, 07:41 AM
Liked: 3661
Jerry,
Mark
Here is the issue as I experienced it. When you re-start Pro, load the original measurement file, and start with the first new measurement position, the software will go through the sub distance measurement again, i.e. chirp sub1, then chirp sub2, then chirp both subs together. Since the sub distances were already determined during the first set of measurements, it's unclear how this second sub measurement affects the results. Luke at Audyssey has acknowledged that this is a software limitation (bug) that cannot be fixed, given the limited processing power allocated to RC in today's AVR's.
My thinking is that this bug would affect systems with either one or multiple subs. However, I have not tested the one-sub scenario.
Old 02-28-2012, 09:03 AM
Wireless member
pepar's Avatar
Quoted: 916 Post(s)
Liked: 503
Any news on that?
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
Old 02-28-2012, 09:04 AM
Wireless member
pepar's Avatar
Quoted: 916 Post(s)
Liked: 503
I don't even generate then anymore.
pepar is offline
gurkey's Avatar
Quoted: 129 Post(s)
Liked: 91
February is almost over by now ... and nothing here yet
gurkey is offline
Old 02-28-2012, 09:09 AM
kbarnes701's Avatar
Liked: 5071
Old 02-28-2012, 09:25 AM
Wireless member
pepar's Avatar
Quoted: 916 Post(s)
Liked: 503
2012?
pepar is offline
Old 02-28-2012, 09:33 AM
GPBURNS's Avatar
Quoted: 125 Post(s)
Liked: 286
Mark
exactly
being able to control ambient noise with 3 teenagers
for extended period is not that easy
my best results have been in the 16-22 measurement range
takes awhile with 7.2 speakers
GPBURNS is offline
Old 02-28-2012, 10:30 AM
jxhopper's Avatar
Quoted: 33 Post(s)
OK. So I have the 4311 with XT32. I am very happy with Audyssey XT32 (compared to the lower XT in my older Onkyo receiver). Dual sub calibration is much better.
I am looking for feedback from other 4311 owners who have made the jump to Audyssey Pro. What were your results... and do you feel the investment was justified... given the cost of the installer kit?
Jx
jxhopper is offline
Old 02-28-2012, 11:01 AM
HTPCat's Avatar
Quoted: 499 Post(s)
Liked: 293
Jx
I bought mine used for a little less than new, my thinking was that if the results weren't much of an improvement I could always sell it. I had moved from Denon 4310 with XT to 4311 with XT32 and was impressed with the significant improvment in SQ with my room so I wasn't really expecting much more from the pro, but I think it has made a worthy improvement upon XT32, especially in clarifying the mid range and expanding the soundstage to completly surround me in sound. For me the ability to measure many more mic positions and the nice boom/mic setup was itself worth the price of the pro kit.
HTPCat
"I have a need to feed the hole with more Audio & Video toys"
HTPCat is offline
Old 02-28-2012, 11:07 AM
Quoted: 194 Post(s)
Liked: 219
^^^ I concur. The 'sound bubble' just seems a bit larger with the Pro and the integration of mains with the sub seem smoother. I feel it was worth it. The only 'issue' is that it takes a lot longer to do the measurements (I timed it at 4min 50 sec per measurement position in my system - 11.2, well, technically 11.1).
Ray
Denon Avr4310ci Receiver , Audyssey
