The Audyssey Pro Installer Kit Thread (FAQ in post #1) - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 91Likes
Old 07-22-2011, 05:44 PM
GPBURNS's Avatar
Quoted: 125 Post(s)
Liked: 286
Originally Posted by Gooddoc View Post
Its the nature of their design. They're high efficiency pro drivers and have solid output to 25-30 Hz and roll off 2nd order below, but they handle transients extremely well within the driver's range. I don't have a huge desire to chase the sub 20 Hz region so its a tradeoff I accept.
cool - just curious
15400 Watts of Seaton Power -Quad SubMersived
GPBURNS is offline
Old 07-22-2011, 06:30 PM
Gooddoc's Avatar
Quoted: 2688 Post(s)
Liked: 1854
No problem . As far as I can tell I have little to no room gain down there, which is a bit of a bummer. No free lunch for me....
Gooddoc is online now
Old 07-23-2011, 05:08 PM
bodosom's Avatar
Quoted: 205 Post(s)
Liked: 68
Originally Posted by Bobkbusch View Post
Audyssey listed them as Large after the calibration and if I recall correctly, I switched the crossovers to 80hz.
Was 80 the first choice?
bodosom is offline
Old 07-24-2011, 08:45 AM
Bobkbusch's Avatar
I don't recall. I've done six different calibrations just playing around and now have the system sounding great!
My front L & R speakers have built-in powered subs. I turned down the gain and level matched them (somewhat, but not perfectly) and this verified the discrepancy I was seeing between the two speakers.
I also noted my final Audyssey certificate shows the sub level somewhat below the reference line.
I played with my Velodyne DD-15 built-in equalizer prior to my last few calibrations. The Velodyne graph isn't flat but only varies from 83-76db from 20-100Hz. That is consistent for all three listening positions on my front row of seats.
However, Audyssey Pro seems to hear a significant spike on the low end and appears to trim down the sub to 4-5db below reference to compensate. At least that is how I interpret the graphs.
Attachment 218291
EDIT: BTW, the Audyssey Certifcate I've attached here doesn't seem to display the "reference" line on some of the graphs (e.g. subwoofer graph) that clearly show up when I view the same certificate on the Audyssey web site. Don't know why, I printed the .pdf using CutePDF and perhaps that alters the certificate somewhat when doing the print conversion.
Audyssey Customer Certificate.pdf 163.671875k . file
Bobkbusch is offline
Old 07-24-2011, 10:38 AM
Gooddoc's Avatar
Liked: 1854
My certificates show the same 4-5 dB drop from the reference line. However, when I measure the FR independent of Audyssey, the subs are properly leveled.
Old 07-24-2011, 10:59 AM
Bobkbusch's Avatar
Thanks for that info...good to know!
Old 07-24-2011, 11:45 AM
** Man of Leisure **
AustinJerry's Avatar
Quoted: 6552 Post(s)
Liked: 3629
This is actually a good question. In my calibration, the suggested crossovers are in the order 40, 60, and 80 Hz. I like to route everything below 80 Hz to the subs, so that's what I choose. However, Audyssey documentation has never been clear exactly how the order is determined, or what the consequences of selecting a crossover further down the order might be.
AustinJerry is online now
Old 07-24-2011, 12:01 PM
Gooddoc's Avatar
Liked: 1854
I have seen Audyssey comment that the list is ranked with first being most prefered, last least. But Audyssey is myopic in that it is not considering other factors that might make a higher crossover a better choice, such as the need to unload an amp to increase headroom at higher volumes or whether your flavor of Audyssey has higher resolution filters for the sub compared to the satellites.
Old 07-24-2011, 12:23 PM - Thread Starter
SoundofMind's Avatar
Liked: 166
^Yes, I recall reading that as well. Most preferred yielding the overall smoothest curve in the bass region, I presume?
The first time, out of habit, and so I could compare to the settings I used with XT, I chose 80 all around. As I now have XT32 (no built-in advantage to the sub channel) and an Ext amp, I then took the saved 8 pos data file and reloaded it, this time with the recommended xovers (40 on FR/L, etc). It sounded damn good with all @ 80 and sounds damn good now. Is it better now? Geeze, I dunno- these are not easy to A/B.
Yes, I still like playing with Dalis.
SoundofMind is offline
Old 07-24-2011, 12:33 PM
Gooddoc's Avatar
Liked: 1854
No, a/b'ing is not easy, subjective, and highly dependent on the experience of the listener. Taking independent measurements can objectively reveal whether the FR curve improves along the crossover point.
Old 07-24-2011, 12:40 PM
counsil's Avatar
For the folks that aren't familiar with how Audyssey Pro works...
Audyssey Pro optimizes the XO region based upon the XOs you select in the software (MultEQ Pro). This makes it even harder to A/B changing the XOs because you have to connect your laptop to your receiver, re-load the measurements (if you were smart enough to save them off in the first place ), select the different XOs, then have Audyssey re-optimize the filters using the new XOs.
Audyssey (Chris K.) discourages changing XOs in the receiver after calibrating it with Audyssey Pro.
Never argue with an idiot; they drag you down to their level and beat you with experience.
Counsil Basement HT
counsil is offline
Old 07-24-2011, 12:47 PM
counsil's Avatar
Here is an example of how well Audyssey Pro optimizes the XO region. I chose 80Hz vs the top recommended choices (they were large, 40, 60, then 80).
Blue - Audyssey off, Red - Audyssey on
Counsil Basement HT
counsil is offline
Old 07-24-2011, 12:54 PM - Thread Starter
Liked: 166
^Excellent clarification. With XT, I had 80Hz all around for HT, but had not run Pro. In the Denon, you can set the xovers for Stereo mode to a different setting which it will retain. I ran 2.1 with 60 Hz xover for stereo, as it tightened the bass ever so slightly-my fronts are very capable towers.
Now with XT32, I ran Pro and as I just posted, the fronts are 40. I tried switching the fronts to 80 for stereo and it sounded remarkably worse! My conclusion:the filters are audibly optimized for the crossover chosen when prompted in the Pro screen. Of course, with both the Pro crossover calibrations I've tried, 80 and 40, the bass is significantly better than anything I've had before.
Old 07-26-2011, 09:11 PM
bodosom's Avatar
Quoted: 205 Post(s)
Liked: 68
A couple years ago there was a thread about a subjective and objective evaluation of room correction products. The main thrust was that subjective preference is for a smooth sloping response from elevated bass to a rolled off high. Audyssey does the latter, modulo the mid-range dip, . Has anyone tried this with the pro kit, possibly with some external help?
This does make me think about the not uncommon observation that Audyssey needs a bit of LF boost.
bodosom is offline
Old 07-26-2011, 09:24 PM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
You can add a house curve but it's limited to +/-3db in the target curve editor. I added one to my Pro calibration but I can't say it made a big difference.
mjaudio is offline
Old 07-26-2011, 09:35 PM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
I use a curve that is +1dB at 150Hz, locked at Reference at 250Hz, and applied to mains only, i.e. not sub channel. It is also +1dB at 20k, locked to Reference at 12k and 22k.
With my 885 I had all sorts of tweaks to mids and highs, and still wasn't happy. With the exception of the two I just mentioned, all of those others went away when the 5508 arrived.
Jeff
"The future is already here, it's just not evenly distributed." W. Gibson
"I like the future, I'm in it." F. Theater
pepar is offline
Old 07-26-2011, 09:46 PM
noah katz's Avatar
Quoted: 882 Post(s)
Liked: 304
I wouldn't say that, as Audyssey only rolls off starting in the treble, and flat below that.
Noah
noah katz is online now
Old 07-26-2011, 10:14 PM
bodosom's Avatar
Quoted: 205 Post(s)
Liked: 68
a smooth sloping response from elevated bass to a rolled off high. Audyssey does the latter, modulo the mid-range dip.
When I said the latter I meant: "to a rolled off high" as opposed to the former: "from elevated bass".
bodosom is offline
Old 07-26-2011, 10:26 PM
bodosom's Avatar
Quoted: 205 Post(s)
Liked: 68
One might expect that. The winning slope was 10dB.
One might also expect that if the resulting in-room response at MLP matches the calculated FR.
bodosom is offline
Old 07-27-2011, 05:11 AM
muad'dib's Avatar
Quoted: 144 Post(s)
Liked: 49
Hello.
If anyone is selling their AUDESSY sound equalizer BLACK faceplate version,(unbalanced - RCA version) please PM me, I am very interested.
thanks
muad'dib is offline
Old 07-27-2011, 08:17 AM
fitzcaraldo215's Avatar
Quoted: 38 Post(s)
Liked: 42
Audyssey's target curve, except for the midrange dip, is based on and adapted from the SMPTE-X Curve. If you google the X-curve, you will see that it is based on research and subjective evaluations of farfield sound in theaters, going back decades. It is solid, accepted science. The amount of rolloff is dependent primarily on room volume, and Pro gives us three choices based on room size.
I am personally sold on the concept of a measured HF rolloff to give the subjective perception of flat response in farfield listening. My own subjective basis for this is the sound of the Philadelphia Orchestra Ondine SACD's vs. the live sound equivalent. I was in the audience when several of these recordings were made. Of course, I was not sitting where the mikes are, but then again, mikes do not hear like people do.
In general, I believe most hi fi speakers in most rooms, even the best and costliest speakers, deliver too much HF energy. The rolloff corrects for this in a way that I subjectively have come to feel is more like a live concert. And, I also believe that if it sounds right with music, where I have a live reference, it's going to sound right with movies. The great Gordon Holt of Stereophile also concluded many decades ago that a gentle rolloff starting in the next to top octave, which is what Audyssey does, provided sound that was subjectively closest to live sound using his own master tapes.
I also believe that bass response should be measurably flat. That is what sounds best (vs. live) to my ears by far.
On the other hand, I have never seen a reasonable explanation from Audyssey that convinces me that the 2K midrange dip is in any way preferable or even sensible with good equipment. My own listening to it off and on convinces me completely that it does not hold water. So, I eliminate it.
In general, applying Audyssey, particularly Pro has been a sonic revelation that, coupled with discrete Mch recording, has pushed my sound beyond absolutely anything I dreamed possible after many decades as an audiophile and frequent concert attendee. Other concert going friends are in complete agreement vs. the sound of live music. Absolutely no stereo at any price without DSP EQ, and I have heard quite a few at insanely high prices, comes remotely close.
fitzcaraldo215 is offline
Old 07-27-2011, 08:34 AM
markus767's Avatar
Quoted: 3636 Post(s)
Liked: 1295
Originally Posted by fitzcaraldo215 View Post
X Curve [...] is solid, accepted science.
Not really
http://www.dolby.com/uploadedFiles/z...%20Journal.pdf
http://www.hps4000.com/pages/general...al_x_curve.pdf
Markus
"In science, contrary evidence causes one to question a theory. In religion, contrary evidence causes one to question the evidence." - Floyd Toole
markus767 is offline
Old 07-27-2011, 10:20 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
I realized that I had been trying to improve detail and transparency .. things that cannot be EQ'd into gear that does not have it. Otherwise, we could make an HTIB sound like Classe.
pepar is offline
Old 07-27-2011, 10:22 AM
mjaudio's Avatar
Quoted: 39 Post(s)
Liked: 75
I agree with Fitz on the mid-range compensation. It must be speaker dependent but both my Von Schweikerts and Emerald Physics speaker prefer turning mid-comp off. The difference is a pronounced recess of vocals with mid-comp on, with it off the vocals are back to were they should be. These were all just 2 channel tests though and with movies the difference was not as big.
I enjoy my 5508 with Audyssey Pro but I have a hard time saying it is better musically than the Proceed AVP2, Meridian G68 or Halcro SSP-200 I had before. I know the Onkyo 886 was not even close musically, I really only used it for movies as I would get fatigued quickly for music but I have never run Pro on it.
mjaudio is offline
Old 07-27-2011, 07:29 PM
Quoted: 38 Post(s)
Liked: 42
I do not see your point. Nor do the papers refute the notion that the X-curve concept is the best we have got now, in spite of possible nits some have raised.
The conclusion to the first paper is:
"The X-curve is probably not perfect, and neither are the measurement techniques employed. It should be remembered that the X-curve represented a radical change in film sound practice and led to a revolution in film sound quality."
The second paper concludes:
"A new measurement system is needed. Whenever it arrives, the inventors will find themselves standing on the shoulders of Ioan Allen. Until we have a reliable method for measuring what something sounds like, it turns out that his original approach to the equalization of those older theatre speakers of the 1970's, remains the best solution to tuning a sound system."
Both papers illustrate the amount of scientific thinking and research that went into the concept. All that seems to square exactly with what I said. So, I have no idea what you think might be better. I know of no acoustician or speaker measurement guru who believes that measured, farfield in-room response should be anything other than rolled off. Do you? The only questions for quibbling seem to be how do you measure and by how much do you roll off?
Old 07-28-2011, 03:25 AM
markus767's Avatar
Liked: 1295
Do those statements sound like "solid, accepted science" to you? The X Curve is accepted but it's nothing I would call solid nor science.
Markus
Old 07-28-2011, 05:12 AM - Thread Starter
Liked: 166
...On the other hand, I have never seen a reasonable explanation from Audyssey that convinces me that the 2K midrange dip is in any way preferable or even sensible with good equipment. My own listening to it off and on convinces me completely that it does not hold water. So, I eliminate it...
I agree with Fitz on the mid-range compensation. It must be speaker dependent but both my Von Schweikerts and Emerald Physics speaker prefer turning mid-comp off. The difference is a pronounced recess of vocals with mid-comp on, with it off the vocals are back to were they should be. These were all just 2 channel tests though and with movies the difference was not as big...
Interesting. Luke told me that mid-range comp is especially well-suited to 2 way horn speakers. He suggested that I should certainly do one calibration with it off and give a listen. My DalisHelicon 400's are not horns and have a single 2way Xover set at 3K which would theoretically would not seem to match up well with the Audyssey 2.5K dip. I have not tried this yet but then it seems odd that the default for this option is "On".
Old 07-28-2011, 07:48 AM
cnm_mike's Avatar
Howdy,
I need some help. I have an 8805 and Audyssey Pro. When performing a calibration, the transfer of data takes forever via my wireless net. It takes hours to do an 8 point cal. Am I doing something wrong. Is there a way to speed things up?
Thanks for your help,
Mike
cnm_mike is offline
Old 07-28-2011, 08:04 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Originally Posted by cnm_mike View Post
Howdy,
Mike
Don't know anything about your wireless reception ... have you opened the wireless adapter's properties and looked at connection speed?
I always use wired connections for Pro cals ...
Jeff
pepar is offline
Old 07-28-2011, 08:05 AM
Wireless member
pepar's Avatar
Quoted: 911 Post(s)
Liked: 502
Markus, both conclude, however grudgingly, that it's the only scheme right now. Beyond that, I don't think either suggested a successor.
Do you have one?
Jeff
pepar is offline
Denon Avr4310ci Receiver , Audyssey
