Marantz NR1601 Receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 07-25-2011, 03:51 AM - Thread Starter
NewPrometheus's Avatar
Quoted: 14 Post(s)
Product Sheet
Seldom in the course of our musical odysseys, do we come across products that outperform similar products many times more expensive. I think this is such a product! Specifically, the sound quality from this diminutive model is shockingly impressive! Therefore, I am creating this thread for owners of this model to discuss and compare notes.
Thank you.
NewPrometheus is offline
post #2 of 10 Old 07-28-2011, 08:42 PM
flyingvfreak's Avatar
I guess no body owns one but me , Im am very impressed with this, I got it in the Bedroom, I liked it cause it was slim,But I like it even more for what it can do. Very good Quality even for being made in China But what Receiver is not these days
flyingvfreak is offline
post #3 of 10 Old 08-01-2011, 05:54 AM - Thread Starter
Quoted: 14 Post(s)
Rest assured, you are not the only one. It is a very impressive receiver indeed!
You've got it in your bedroom?! What do you have in your listening room / home theater room? What other equipment are you pairing with it?
Cheers!
post #4 of 10 Old 12-25-2012, 04:20 PM
rockislandman's Avatar
Hi, I just purchased a used NR1601. I would like to use the "extra" two channels to drive another set of speakers (simutaneously) in another nearby area when listening to stereo sources. My main set-up will be 5.1, no height or back surrounds. Is there a way of using "MULTI CH STEREO" to output to these speakers via say back surround connections. Any other suggestions? It is OK if the speakers output some sound when in 5.1 as my current set-up they receive the L/R surround info.
rockislandman is offline
post #5 of 10 Old 12-25-2012, 04:27 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Originally Posted by rockislandman View Post
Hi, I just purchased a used NR1601. I would like to use the "extra" two channels to drive another set of speakers (simutaneously) in another nearby area when listening to stereo sources. My main set-up will be 5.1, no height or back surrounds. Is there a way of using "MULTI CH STEREO" to output to these speakers via say back surround connections. Any other suggestions? It is OK if the speakers output some sound when in 5.1 as my current set-up the receive the L/R surround info.
That receiver has Front B terminals. Why not just use them for your nearby area? then it will play whatever is being played in the main room.
Afro GT
afrogt is online now
post #6 of 10 Old 12-25-2012, 07:28 PM
I thought about that option, but I do not think that both "A" and "B" can be played at the same time. I need (as a minimum) both Front mains AND second area to play at the same time
post #7 of 10 Old 12-25-2012, 07:41 PM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5501
Yes, you can configure it as you describe by connecting to the Surr Back speaker posts and setting the surround mode to Mult CH Stereo, although setting them up as "Front B" as afrogt suggests is likely the better configuration as you can then use the SPKR remote button to turn the Front B speakers ON. And yes, you can play the Front A and B together which is why there is an A+B setting.
jdsmoothie is online now
post #8 of 10 Old 12-26-2012, 04:10 AM
Great. Thanks for the information. I will tinker with those two options.
post #9 of 10 Old 02-14-2013, 10:33 AM
Knox Harrington's Avatar
My HK 245 just said good night for the last time.
I'm looking at replacing with a Marantz NR1602 or 1603 or even maybe a Denon AVR 2113-CI.
Anybody have any thoughts, comments about the above?
Any information is appreciated.
Knox Harrington is offline
post #10 of 10 Old 01-30-2015, 04:39 PM
eltee49's Avatar
Necropost, I know, but I just received a used Marantz NR1601.
My local cable runs through a non HDMI box, it is a DTA box which outputs to a coax. Does the NR1601 have coax cable input and can I run audio and video output from the cable, through the NR1601, to the TV?
eltee49 is offline
Marantz Nr1601 Audio Video Receiver Black
