I Need Speaker Selector Advice - AVS Forum
post #1 of 5 Old 07-26-2011, 09:33 AM - Thread Starter
chaslamb's Avatar
Which speaker selector should I get?
I have a denon a/v receiver which I plug main surround sound into zone 1, and 4 other rooms into zone 2 via a radioshack speaker selector ($40)
The speaker selector is a bad one, volume decreases when I activate other rooms, volume control in 1 room affects volume in another room. I have done research and these are known issues with this particular speaker selector.
I need some advice on a better speaker selector. I haven't been able to find too much info on this subject online
I am by no means an audiophile, I don't need the latest, greatest, and have a budget to keep in mind. On the other hand, I would like something that won't affect quality/volume when I am playing music in multiple rooms
Any ideas?
chaslamb is offline
post #2 of 5 Old 07-26-2011, 09:46 AM
neworder71's Avatar
Any ideas?
While there are better speaker switches they all will face the same problem, X power comes out of your receiver at Y volume control position. As you add or subtract speakers via the switch the amount of power each speaker gets will vary and therefore the volume will vary. You can deal with this by adding volume controls in each room or adding a switch with volume controls.
Also add to this that if your speakers vary you will hear different volumes from room to room due the variance in the efficiency of each speaker.
You could add separate amps for each pr, so the power stays constant as other prs are added or subtracted. Much more money than a switch.
I wouldn't put it past the home automation guys to have some sort of system that feeds back the volume level and auto adjusts it, but if they do it will be big bucks.
neworder71 is offline
post #3 of 5 Old 07-26-2011, 12:39 PM
MichaelJHuman's Avatar
Quoted: 165 Post(s)
Liked: 99
Maybe a fixed voltage system, but that calls for a fixed voltage amp, and converters at each speaker I think?
Otherwise, I would guess there's no simple fix.
I am not an expert on the topic, though.
"But this one goes up to 11"
MichaelJHuman is online now
post #4 of 5 Old 07-26-2011, 04:30 PM - Thread Starter
chaslamb's Avatar
I have volume controls in each room
The main problem with the radioshack selector is that when you adjust volume of A in 1 room it also adjusts B, but doesn't affect C or D
On the other hand, when you adjust C in 1 room, D is affected and vice versa
Again, this is a known problem with this speaker selector (4 ports)
Is there a selector that doesn't have this issue?
chaslamb is offline
post #5 of 5 Old 07-30-2011, 01:46 PM
Brian B's Avatar
Liked: 24
http://www.nilesaudio.com/product_se....php?catcdID=7
High and low power choices with and without volume.
B.
Brian B is offline
User Tag List
