The "OFFICIAL" Pioneer Elite VSX-52 / 53 Owner's Thread - Page 53 - AVS Forum | Home Theater Discussions And Reviews
post #1561 of 1592 Old 04-03-2014, 09:04 AM
KGB173's Avatar
Originally Posted by grigorianvlad View Post
Why is it that the best ideas always occur to someone else? Yep, that would be test to begin with! Thanks, comrade KGB! biggrin.gif
on a separate note, i've got my own item I've been trying to figure out on and off. it's a zone 2 question. it works fine when i turn on zone 2 and want to replicate what i'm watching on TV in zone 1. it also works fine when i connect through the app into pandora. what doesn't work is when i use use pandora on my phone and beam to the TV via chormecast or if i use the TV app. benefit of chromecast or TV is that the pandora app is more functional and easier to navigate.
any thoughts?
KGB173 is offline
post #1562 of 1592 Old 04-03-2014, 12:13 PM
DanGraney's Avatar
Check on VSX if your HDMI isnt set to THROUGH (AMP is the correct setting).
Check on VSX if your FIXED PCM isnt set to ON (OFF is the correct setting).
Try the second HDMI monitor out jack (if this is a VSX-53, I think VSX-52 has only one).
Try a different HDMI cable
Try an optical out just as a test of your HDMI board
Ran home at lunch time, took a few minutes to check...
HDMI was set to AMP
FIXED PCM was set to OFF
I'll try a different HDMI cable, a digital optical cable and, most importantly, a straight connection from the DirecTV to the TV.
I would love for this to be something wonky vs. having to get a new box shipped... so many shows and series to set to record. They need cloud-based record lists you can simply download to any DVR.
DanGraney is online now
post #1563 of 1592 Old 04-03-2014, 05:14 PM
grasshoppers's Avatar
Quoted: 695 Post(s)
Liked: 410
HDMI was set to AMP
Just a quick note dierctv boxes can be problematic with HDMI into
Any AVR . I got tired of messing with it. Ran HDMI into the tv.
Then got an optical (can also be coax digital) in to the AVR ...no more issues.
Edit-optical out from directv box into AVR. (Optical in)
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is online now
post #1564 of 1592 Old 04-04-2014, 06:21 AM
DanGraney's Avatar
Yeah, I tried running digital coax to the AVR, that was a bust. I was on the phone with DirecTV 3 times and finally told them I just wanted to exchange my box.
Sadly, I have to have a tech come to achieve this, but I'm hoping that the new Genie will play nice... I don't know what has happened, but the HR34 and VSX-50 just do not want to play nice together with audio.
post #1565 of 1592 Old 04-04-2014, 06:37 AM
Quoted: 695 Post(s)
Liked: 410
Interesting, FWIW, when you get the new Genie I would still
Lean to using HDMI into the TV, optical/coax into the AVR.
This will hopefully future proof you from problems when Directv
Does any "updates" on the Genie. IMHO
Rythmik F12 subs
post #1566 of 1592 Old 04-04-2014, 06:42 AM
DanGraney's Avatar
This will hopefully future proof you from problems when Directive
And I do think I'll do that in the interim... to make matters more interesting, my TV (Samsung PN63C8000) features ARC, so it should actually send the audio out via the HDMI in (to a particular input). But I cannot, for the life of me, figure out how to "activate" the output of it from the TV or input it into the AVR.
(It will make it a little easier considering that the HR44 also has a digital optical out, unlike the 34's digital coax only)
post #1567 of 1592 Old 04-05-2014, 12:22 PM
mycross3's Avatar
I'm having a problem with my vsx 53. I purchased this system a year ago from BB. I have a 3d blu ray player, ps3, and a direct tv  genie hooked to the receiver by hdmi cables and a single out going to my TV. It has been working find until today, no sound or video. I'm getting no HDMI SIGNAL to my TV. I was able to view/hear by disconnecting each device from the receiver and connecting them directly to my tv's hdmi port. I plugged my iPad to the receiver and I get no sound or video, however every 30 seconds my tv will flash an orange display with the iPad controls on my tv. Has anyone seen this before?
Thanks, Will
mycross3 is offline
post #1568 of 1592 Old 04-07-2014, 09:02 AM
DanGraney's Avatar
Well, got the new HR44 and have zero problems... HMDI audio out is working again, back to full 1080p and no HDCP error message suggesting I switch to component cables (that was a new one). I'm thinking the old HR34 had a bum HDMI out.
post #1569 of 1592 Old 08-31-2014, 10:14 PM
ihbond's Avatar
Need some help folks:
I have a comcast cable box :Motorola DCH3416
Brand New Sony XBR55X850B
Pioneer vsx-52
Sony TV has a IR blaster to control the cable box. I am hooked up via HDMI from Cable box to AVR to TV. VSX set to standby mode
When I turn off the power to the tv, it also turns off the cable box. But after 15-20 seconds the cable top box turns back on and the audio can be heard through the receiver, but the tv is off (as expected)..
When I go through the IR blaster testing, it properly shuts of the cable box. Now the sony setup does keep the TV on so you can make sure the setup does turn off the cable top box (shown in a PIP screen)
So is it possible that the receiver senses something and turns back the cable box on ? Is there a setting i am missing ?Perhaps the sony causing the issue ?
Any thoughts, or suggestions or more clarification ?
Ian
ihbond is offline
post #1570 of 1592 Old 09-19-2014, 07:37 AM
ihbond's Avatar
well, ended up going the tv ARC,
Pioneer vsx-52
Ian
Well ended up going through the TV's ARC..
Even make things more interesting, I decided to opt out of the 4k tv, to 1080p lcd then to a Samsung plasma f8500...
I learned a lot in the last couple of weeks. resolution is not the only thing to base a tv on.
So, ironically I will be using the cable, ps4, and Blu-Ray through the vsx-52 (some TOSLINK out some HDMI), and not have everything going through the TV's ATC (it only does 2 LPCM channels or 5.2 DTS that is hard to control)
ihbond is offline
post #1571 of 1592 Old 09-24-2014, 07:07 PM
Smsoto0055's Avatar
Has anyone had an issue where there receiver crapped out on them while under warranty? I have a VSX-53 which something catastrophic happened to the other day. It was working fine the night before. I went out during the day and when I returned it wouldn't work. It had the blue light flashing so I took it to an authorized repair center not too far away and they said it was not repairable. I contacted Pioneer and they said they have to contact the shop and verify a few things. It's 3-5 day turn around they say. Since it's under warranty and it's not repairable what happens now? What do they consider a "comparable unit?" Thanks
Smsoto0055 is offline
post #1572 of 1592 Old 09-24-2014, 07:14 PM
AVS Club Gold
Mike Garrett's Avatar
Quoted: 4089 Post(s)
Liked: 2460
Pioneer now available through AVS. Call us for pricing.
mike@avscience.com
Sony, JVC, Epson, Denon, Marantz, Yamaha, Onkyo, Triad, Atlantic Tech, M&K, RBH, SVS, Polk, Stewart, Seymour, Falcon, DNP, SI, Screen Excellence, Carada, MicroLite & more.
Mike Garrett is online now
post #1573 of 1592 Old 10-17-2014, 07:30 AM
Liked: 0
Hello to all....
Do you all know of anyway to stream music from an iPad or android device while using the other inputs for xb1/ps4???...
I'm guessing it's multi zone.????..but idk how to set that up.
I know about AirPlay and hmg but I want to stream music while playing the video game in the same room.
Please help me figure this out if at all possible..
Willie James is offline
post #1574 of 1592 Old 10-26-2014, 02:02 PM
grigorianvlad's Avatar
Quoted: 106 Post(s)
Liked: 605
Hi, guys. I got an external DAC, Peachtree Audio DACITx .
The source is a PC, which has the DAC configured at 192kHz 24 bit, so does media player software (via WASAPI).
The DAC is connected to the PC via USB. The VSX-53 is connected using RCA cables.
But when I press STATUS on AVR remote, it says 48kHz (Studio Quality). Why is my 192khz is downconverted by VSX-53 to 48Khz. It should be pure analog signal.
DAC: Wyred4Sound DAC1LE || BD Player: Pioneer Elite BDP-41FD || Processor: Marantz AV8801 11.2 Ch || Power Amps: ARC VS110, Emotiva XPR-2 (600W), Emotiva XPA-5 Gen 2 & UPA-500 (200W/80W) || L/R Speakers: Eminent LFT-8b , Magnepan 2.7, Center : Polk LSiM-704C, Sur: Polk LSiM-703 || Sub 1: Rythmik F25 (800W). Sub 2: Sunfire True Signature TS-EQ12 (2,700W) || Cables: MIT terminator 2 Biwire, 4, Exp; Cardas Crosslink || Power: Panamax M5300 || HP: HifiMan HE560
grigorianvlad is offline
post #1575 of 1592 Old 11-20-2014, 02:51 PM
Quoted: 106 Post(s)
Liked: 605
Have a question. My Media Server used to be connected to my VSX-53 with an HDMI cord. I didnt like Pioneer's built-in DAC, so bought an external DAC, Peachtree Audio DACIT*x .
It is connect to the PC via a USB cord, and to the VSX-53 with two RCA interconnects.
Here is my question. The external DAC has a much more musical sound so I need to combine it with HDMI video from the PC. But Pioneer doesnt allow HDMI input to be combined with anything. Once I chose HDMI, all audio inputs become unavailable. So, I am forced to feed PC video directly to the TV using an RGB computer monitor cord.
How do I make my VSX-53 combine DAC RCA audio inputs with PC video HDMI input?
post #1576 of 1592 Old 12-29-2014, 08:19 AM
Liked: 0
Hello I have owned a VSX 53 for a wile now and I have always had a problem with hdmi pass through. It never seemed to be much of an issue so I have been kinda lazy about it. When I bought the receiver it wasn't warranted so I wasn't able to get it fixed or something. I'm just wondering if anyone else ever had this problem or if there was a way to fix it. So here is the problem.
About 50% of the time when I turn the TV or projector on, the receiver won't show the blue hdmi light. I then have to turn the reciever off and then back on. But after I do this it usually gets the handshake. Unfortunately it seems like it's getting worse.
I also have multiple hdmi inputs hooked up and it does it with all of them. So it's not an input problem. I do have video conversion turned on in the receiver. Does that matter much?
Thanks for any help.
greganato is offline
post #1577 of 1592 Old 03-01-2015, 06:02 PM
Liked: 0
Originally Posted by mycross3 View Post
<p>I'm having a problem with my vsx 53. I purchased this system a year ago from BB. I have a 3d blu ray player, ps3, and a direct tv  genie hooked to the receiver by hdmi cables and a single out going to my TV. It has been working find until today, no sound or video. I'm getting no HDMI SIGNAL to my TV. I was able to view/hear by disconnecting each device from the receiver and connecting them directly to my tv's hdmi port. I plugged my iPad to the receiver and I get no sound or video, however every 30 seconds my tv will flash an orange display with the iPad controls on my tv. Has anyone seen this before?</p>
<p> </p>
<p>Thanks, Will</p>
Mycross3 I was able to fix the Orange screen and no video by unplugging the unit overnight. I had the same problem that you did with no HDMI video with sound. Apparently this is caused by a power surge. Other models showed the same fix for similar issues. Hope that helps.
TNTPILOT96 is offline
post #1578 of 1592 Old 03-16-2015, 04:17 PM
tomtastic's Avatar
Quoted: 526 Post(s)
Liked: 177
My VSX-53 just started flashing UE22. Googling isn't bringing me anything I want to hear. I tried resetting to factory, unplugging everything. It just won't go away. I guess this is the end. Well, I barely knew her. She was only 3 years old, I guess they don't make them like they used to. I've got receivers over 15 years old still operating.
This line intentionally left blank.
tomtastic is offline
post #1579 of 1592 Old 03-18-2015, 08:00 AM
jab336's Avatar
Ue-22
I got this error in December. After googling I found it is a bad main board. I got this on my VSX-52. I found using a heat gun on the DTS chip of the board fixed the error for about 3 months before the error came back (reflow). However when I did this I lost ARC and HDMI hanshake issues occur. I love the unit but knew i needed a new board. I found a new VSX-53 for the same price as the main board. Part AWX9826 was $363 bought the new VSX-53 for $395. Board on the VSX-53 is AWX9825 and is $383. I know I should have purchased a different unit but I enjoy these units and the features. I have read that a replacement board will fix the issue as the new boards correted a firmware chip issue do to the build and not needing the reflow. I am taking a gamble on the new VSX-53 but if I can get another 2.5 years out of it by then I can get a new Pioneer/Onkyo unit that has all the bells and whistles and none of the kinks that may occur this year as the (2) companies meld together. And it will be a D3 (SC series) or better class reciever.
jab336 is offline
post #1580 of 1592 Old 03-19-2015, 02:53 PM
tomtastic's Avatar
Quoted: 526 Post(s)
Liked: 177
Yeah, hell with it. I'm not getting mine repaired. I've been here before, cost nearly as much to fix as replace. Not worth it. I'll replace with new.
post #1581 of 1592 Old 03-20-2015, 07:49 PM
jab336's Avatar
New VSX-53 Arrived
Well as stated in the previous post. I replaced the VSX-52 with the new VSX-53 which arrived yesterday. One thing I have noticed is that the Build year of my VSX-52 which went south and got the flashing UE-22 (but still working and very functional) was May 2011 and the new VSX-53 is August 2012, My question is when did Pioneer correct the main display board issue? I see it as if it was corrected in the 15 months between builds then I should hopefully get a long happy life with my new cost effective slight upgrade. If not then I just bought a new bridge for the next 2.5 years till I upgrade to a D class Pioneer/Onkyo.
jab336 is offline
post #1582 of 1592 Old 08-14-2015, 06:14 AM
Liked: 0
VSX-53, No Audio
Newbie here - first post. My son and a couple of his buddies were messing around with my receiver (VSX-53), seeing what all they could do. What they ultimately did was to kill any and all audio signal. Everything still seems to function: all the lights illuminate, the amp clicks upon initial startup, then again a few seconds later, I can scroll through all the different functions, etc.
What I can't do is get an audio signal, which is what I currently have this thing set up for. I've tried an iPod and a CD player (through the RCA jacks) and even a tape deck, all to no avail. Although the tuner indicates its locked onto a signal ... nada on the audio. I've tried all sorts of speaker connection combinations and can't get output from any configuration. I can't even get sound out of the headphone jack. I removed the top and checked all fuses by pulling them and testing with a mulitimeter. All were fine.
I'm hoping they gave a command that turned off the audio and that all I have to do is find and reverse it and that,someone that's actually familiar with this thing (versus a guy like me, who simply uses -or used - it for music) can point me in the right direction. I've poured over the owner's manual in an attempt to solve this little mystery and have come up empty. Is it really dead or is this something simple?
nkowi is offline
post #1583 of 1592 Old 08-15-2015, 06:04 PM
Liked: 0
No one?
nkowi is offline
post #1584 of 1592 Old 09-13-2015, 09:49 AM
jmmcnew's Avatar
I have recently gotten my first subwoofer (Goldenear forcefield 5). I calibrated my fronts as large and put the system into swplus mode. When I play an audio cd on my bluray play through the bd input, the system turns on the subwoofer. However when I play the same cd from my pc with hdmi connected to the DVD input, the subwoofer does not turn on. Is there some setting I need to change on my receiver(vsx52)? Thank you
jmmcnew is offline
post #1585 of 1592 Old 01-18-2016, 09:32 PM
semicycler's Avatar
Older thread, hoping someone can help. I have a VSX-52 and it's been working fine for me. Been thinking of speaker upgrades but wanted to play with the AVR speaker settings first.
When switching inputs with the selector dial the volume level is dramatically different on one digital channel versus another. Normally the master volume from my HDMI input from the TiVo is around -30dB. Switching to one of the digital optical fiber inputs and the sound is way too loud, causing a quick dash to turn down the master volume to -60dB or so. For the life of me I cannot find a setting in the manual to correct this. I want to adjust volume levels separately by input - turn down the digital fiber input for example so that it sounds about as loud as the other inputs.
Is there a way to adjust the overall levels on the various inputs so that when selecting an input the overall volume is roughly the same across all inputs?
semicycler is offline
post #1586 of 1592 Old 02-08-2016, 08:51 PM
wozman's Avatar
Quoted: 16 Post(s)
I own the Pioneer VSX-1326-K (Canadian Box Store Version of the VSX-53 Elite) I believe.
Have it partnered up with a Pioneer Plasma 5020FD Kuro display. everything has been solid since the get go, (5 plus years) until this past few months. I have been experiencing the "8 blue flashes" on my Plasma display when I try to switch receiver HDMI inputs on my Logitech Remote. Or change activities (Logitech Remote) from watching TV or watching Blu-Ray or Watching HTPC or playing PS4. all my preset activites on my remote. IF I start from a cold start and select watch TV there are no issues, turns everything on properly, and can watch regular programming from my Rogers Cable Box. However if I try to watch a blu-ray and try that activity TV begins to flash 8 times, but I can still hear sound playing as if my Movie has started. At first I thought it was a TV issue, and focused on that, and had someone locally who services Pioneer displays order me the "part for the board" that need to get replaced. (I have seen that discussion in the other thread on this forum already regarding the 8 blue light flashes for Pioneer TV) however after completing that and having him install it....., I am still having this same issues. I find it really weird that watching TV with my Rogers Cable Box, doesn't give me any issue so I assumed that it wasn't a "handshake" issue with the receiver. Now I am beginning to think that it is a handshake issue with my Receiver? or am I incorrect. I am almost at a lose for words.....
Could it be a faulty HDMI cable? but if it was a faulty HDMI Cable then I shouldn't be hearing any sound correct? ......cause I am hearing the sound, but my Display doesn't appear, and it sends the Kuro to do the 8 blue light flashes. I don't get it .......even after we switched the board with the new part that was required today......
Again, is it possible that the Receiver doesn't like the TV all of a sudden? I find that weird cause I didn't change anything to my setup. No firmware updates etc. Nothing.
OR can HDMI cables go faulty? and still play sound and stop communicating display with a TV?
I would greatly appreciate any feedback here, Don;t want to dump either my Display or Receiver to the curb.....just yet.
Display#1: Pioneer Kuro Plasma PDP-5020FD (Living RM)
Display#2: Panasonic Plasma TC-P55ST60 (Rec-RM)
Receiver: Pioneer VSX-1326-k (Living RM) & Pioneer Elite SC-95 (Rec-RM)
Speakers: Bose 6 Series III (LivingRM) & Pioneer SP-FS52 (L&R) SP-C22 (Center) SP-BS22A (L&R Rear Atmos Ready)
Sources: Panasonic BDT360 -- Sony BDP-S350 -- PS3 & PS4 -- HTPC
wozman is offline
post #1587 of 1592 Old 02-10-2016, 11:00 AM
pspoar's Avatar
Wozman, HDMI cables can fail over time. Why don't you grab one from a dollar store (for $3.00) and see if that cures the issue. I always try to start with the simplest solution first.
I also have the 1326, but haven't had any issues with it so far (knock on wood).
Good luck!
pspoar is offline
post #1588 of 1592 Old 02-10-2016, 11:01 AM
pspoar's Avatar
Good luck!
pspoar is offline
post #1589 of 1592 Old 04-09-2016, 11:23 AM
Liked: 0
I've always used avs for reference, but never had to ask a question until now! This avs-52 is a little more complicated than I had anticipated. What I'd like to do at the moment is set it up with two floor speakers and two bookshelf speakers and listen to music through those, essentially as a quadrophonic receiver. Most of what I've found on here assumes at least a subwoofer will be used... Without a sub, what is the best way to work this four channel setup with this rig?
Thanks for any insight you can provide!
Fast_Eddy79 is offline
post #1590 of 1592 Old 04-09-2016, 11:26 AM
Liked: 0
I meant Vsx-52 of course... Avs on the brain!
taboola here
