The Official Onkyo TX-NR1009 Thread - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #331 of 357 Old 01-12-2014, 09:22 AM
iamluvinlife's Avatar
Originally Posted by DCblackhole View Post
Yes everything works as it should. You just have to unplug every HDMI device from the receiver before you power cycle. I don't think the rest of the steps (resets) are actually necessary. Tech support walked me through the process of the hard reset without telling me I should disconnect everything connected to the HDMI board.
thanks, it didn't work. i unplugged everything but main1 hdmi out to the tv and turned everything on. then unplugged all the power again. when i pressed the tv power the onkyo turned on. the receiver even says tv/cd like it should just no sound. I'm suspecting now that my hdmi in the wall is v1.3.
Thanks, Chris
iamluvinlife is offline
post #332 of 357 Old 03-03-2014, 05:45 PM
#1Tester's Avatar
Not sure if this will help anyone but my receiver is fairly finicky(buggy) as well and sometimes i will not hear any audio from source( TV-for example) after turning both on...what i found that works (but its a pain) is to cycle the TV "input" source from TV to HDMI (Onkyo receiver) and back to TV...I then get the over the air DDigital 5.1 audio back....only once or twice have i had to shut everything off and restart to get it to work correctly.Note: I connected a digital audio cable from TV to the Onkyo and this also eliminated the no audio from TV, BUT, this totally defeats the purpose of using a single cable(HDMI-ARC)....:-(
#1Tester is offline
post #333 of 357 Old 03-31-2014, 07:52 PM
joepaiii's Avatar
Quoted: 31 Post(s)
Looks like my hdmi board has bit the dust. I have been having intermittent problems over the last few weeks where I was needing to power cycle the receiver in order to get audio through my hdmi inputs. Well today, it has stopped working completely. I called support earlier and they suggested a firmware update and a factory reset. I did that and the receiver was working for a little while. Turned it off and came back to it a few hours later, no audio at all through the hdmi inputs.
Time to go in for service. I am sending an email off to the parts department to find out if there is anything they can do since the unit is only six months out of warranty .
joepaiii is online now
post #334 of 357 Old 04-01-2014, 11:09 AM
allan0210's Avatar
Quoted: 18 Post(s)
Thats bad luck the HDMI boards are the only thing that concern me with Onkyo kit, hope you get a fix
Just a daft thought its not maybe a HDMI cable fault
Allan
allan0210 is offline
post #335 of 357 Old 04-01-2014, 06:24 PM
joepaiii's Avatar
Quoted: 31 Post(s)
Allan
I'll find out for sure when I swap my old 606 back in.
post #336 of 357 Old 04-01-2014, 08:19 PM
joepaiii's Avatar
Quoted: 31 Post(s)
606 worked fine the with all the same cables and components. Bad 1009. Hope onkyo comes through on the out of warranty repair.
post #337 of 357 Old 04-02-2014, 11:57 AM
allan0210's Avatar
Quoted: 18 Post(s)
Fingers crossed not sure how well they do out of warranty
Allan
post #338 of 357 Old 04-04-2014, 04:32 PM
aaron52's Avatar
Anyone get a 929 in place of the 1009?
Looking at the 929 specifically for the bluetooth capability...
aaron52 is offline
post #339 of 357 Old 04-04-2014, 06:37 PM
joepaiii's Avatar
Quoted: 31 Post(s)
Allan
Thanks - must have worked. Onkyo came through and is taking care of the work. Dropped the unit off this morning and should be a week or two to get it back.
allan0210 likes this.
post #340 of 357 Old 04-04-2014, 06:49 PM
joepaiii's Avatar
Quoted: 31 Post(s)
I would be thinking about it a little harder if it had Airplay support, really wish they had that built in. One nice thing is that unlike the 1009 the 929 does support a powered zone 2 and 7.1 in the main room since it had 9 channels. The 1009 has 9 channels as well but you can only use 5.1 in the main room if you want powered zone 2. Or you could run 5.1 plus front wide/high and powered zone 2. I am still bitter about that one...
post #341 of 357 Old 04-05-2014, 04:28 PM
DCblackhole's Avatar
Sorry this is like 3 months late... But you have to disconnect all of the HDMI cables. Meaning every single one of them. I made them same mistake of leaving the main out connected and that was the cause of hours of frustration.
DCblackhole is offline
post #342 of 357 Old 04-09-2014, 01:28 AM
allan0210's Avatar
Quoted: 18 Post(s)
Hi folks
Well yesterday i took delivery of the Onkyo 3010 and will be selling my loved 1009 really enjoyed it but XT32 was a big pull for me
Allan
post #343 of 357 Old 04-09-2014, 01:29 AM
allan0210's Avatar
Quoted: 18 Post(s)
This what i like about Onkyo they may have failures but they do seem to take care of you when things go wrong hope you have it back soon
Allan
post #344 of 357 Old 05-30-2014, 05:13 PM
zekes69's Avatar
Onkyo won't fix mine because I lost the invoice, I can't hate on them for that but its a known problem with the HDMI boards. My question is if i pay to get it fixed am I going to have the same problem? If so I think I will just trash it or give it to the highest bidder on ebay and get some separates. I have to say it was a great unit when it was working but having to hard reset it every couple days for the last month of its life sucked, I had to redo all my settings every time
zekes69 is offline
post #345 of 357 Old 07-08-2014, 03:41 PM
Liked: 0
Onkyo TX-NR1009 - No speaker lights on amp
Hi- I'm at a loss with :-(
I have lost audio and there are no speaker lights on the amp- how do I bring back these lights and get audio back ??
Cheers
Andy
Analogue Kid is offline
post #346 of 357 Old 08-28-2014, 11:49 AM
kubu4's Avatar
jopaiii - Any update on the repair?
I'm sending my unit out this week for the same issue. Excited that Onkyo is doing a one time warranty extension to repair the problem (my unit's about 1yr over the warranty period), but I'm just hoping they put a more robust HDMI board in this time...
kubu4 is offline
post #347 of 357 Old 08-28-2014, 01:49 PM
dgater's Avatar
Liked: 36
Here you go! 08/19/2014 Loss of Audio/Network Connection Customer Care Program
You should not need an invoice
curtind1 likes this.
dgater is offline
post #348 of 357 Old 10-22-2014, 12:16 PM
posmoo's Avatar
So it appears the sub hdmi out is no longer operating. Is this the HDMI board going dead like I've heard about? My 1009 was purchased in late 2011 I believe. I have no shot at getting this repaired on their dime, right?
posmoo is offline
post #349 of 357 Old 10-23-2014, 05:03 AM
gingerman's Avatar
They just fixed mine at no charge about 6 months after the standard warranty had expired. You will need a receipt from an authorized dealer though. They sent me a shipping box, prepaid labels, and it wasn't gone much more than a week. They say the issues are due to a defective network chip or card but they are absolutely related to the HDMI issues many of us have seen.
gingerman is offline
post #350 of 357 Old 12-05-2014, 02:26 PM
My audio just went out too. They are sending me a box to send unit to them. I'm done with onkyo after this. Bad hdmi board on 905 and now bad audio on 1009....junk.
post #351 of 357 Old 02-23-2015, 07:44 AM
patela2oh's Avatar
Anyone had those network control cut out? I have had 3 bad hdmi boards in 3 years. I'm so done with this thing...
I use ip control with a rti setup and as of this morning it no longer responds to any inputs over ip. Network sees it though
patela2oh is offline
post #352 of 357 Old 02-23-2015, 09:44 AM
I think the network cut out is related to the audio cut out I had. They replaced it under a special warranty, google it and you should find a site to check if it qualifies.
post #353 of 357 Old 04-01-2015, 07:26 AM
bob brennan's Avatar
Quoted: 124 Post(s)
Liked: 159
Onkyo has extended the warranty for this issue through 2018 - follow the link - I had my 809 repaired @ no cost - they send you a box, labels etc.
http://forums.onkyousa.com/viewtopic...80c7b440ec19fd
LG OLED 77G7P - Panasonic TC-P65ZT60 OPPO UDP-203 - Toshiba HD-DVD-3A – Harmony ONE
Marantz SR7011 - Definitive Technology - Studio Monitor 65 (2) - CS8040HD - Studio Monitor 45 (2) - Super Cube 6000
bob brennan is offline
post #354 of 357 Old 05-05-2015, 10:26 PM
Quoted: 106 Post(s)
Liked: 29
Well guys I just bought this reciever for $300. Good deal? Works great so far. Hoping nothing cuts out on me...
bradtheman2 is offline
post #355 of 357 Old 05-06-2015, 09:26 PM
lionorion's Avatar
Seems like a good deal. Especially since Onkyo bumped out the warranty another three years for a known defect with the HDMI board/Ethernet connection!
lionorion is offline
post #356 of 357 Old 05-06-2015, 10:18 PM
Quoted: 106 Post(s)
Liked: 29
Yeah mine works fine... I was wondering if I should still send it in or wait. My serial number says I qualify.
post #357 of 357 Old 07-17-2015, 06:29 AM
Quoted: 25 Post(s)
Liked: 3
I am confused on how to get a pristine, unprocessed video signal through the 1009 and out via HDMI...or if this is even possible. According to the manual if Monitor Out resolution is set to Through, then the unit sends a video signal at the same resolution and without conversion out via HDMI Main or Sub. When I set this, however, the unit still outputs what is selected in Picture Adjust...and according to the manual even selecting Direct in Picture Adjust causes the unit to change resolution although no conversion is done.
What I want is a video signal passing through the 1009 that looks just like if I connected my PS3 or Oppo BDP-93 directly to my TV, but the video signal coming from the 1009 is always slightly duller compared with a direct connection.
Does anyone know the magical settings to use? Since the OSD is only output via HDMI Main, would connecting to my TV via HDMI Sub allow for a purer signal?
ebefspz is offline
