The Official Onkyo TX-NR1009 Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #181 of 357 Old 04-30-2012, 09:31 PM
dctrombly's Avatar
I may be getting this receiver but I need to make a decision by tomorrow. I have 10 speakers around to use and am debating between 7.2 and 9.2, and I still have decide on which combination of wides, heights, or rear surrounds I want to use. I plan on getting a 2nd sub so x.2 is required.
-L,C, and R are all Triad Bronze. (4 ohm 200w max)
-2 Triad Bronze Satellites (These will be front wides or heights if I go that route - 8 ohm 125w max)
-Rest are Bowers & Wilkins M1 (8 ohm 100w max)
-1 Emotiva Ultra 12
I believe this receiver would run a 9.2 setup with these just fine, with room for upgrades.
I have a chance to get the 1009 for about $800. Are there any other better deals out there?
dctrombly is offline
post #182 of 357 Old 04-30-2012, 10:28 PM
Fastslappy's Avatar
Liked: 749
-1 Emotiva Ultra 12
that's a great deal
Mike
JAZZ IS NOT DEAD IT JUST SMELLS FUNNY ; FRANK ZAPPA
Fastslappy is offline
post #183 of 357 Old 05-01-2012, 11:14 AM
dctrombly's Avatar
Originally Posted by Fastslappy View Post
that's a great deal
Great enough to jump on ASAP? It's new in box BTW.
Would there be others to consider at around that price? I would consider refurbs as well.
post #184 of 357 Old 05-01-2012, 01:25 PM
02Lightning's Avatar
I would say yes, only other thing is make sure it's an authorized dealer.
02Lightning is offline
post #185 of 357 Old 05-01-2012, 02:24 PM
dctrombly's Avatar
It's from Best Buy so I'm pretty sure it is. This is the employee price BTW if anyone has friends there.
post #186 of 357 Old 05-01-2012, 02:49 PM
Davecraze's Avatar
Quoted: 184 Post(s)
Liked: 60
-1 Emotiva Ultra 12
No, there are not any better deals out there. Even as a refurb, the 1009 is normally around $949.
Davecraze is online now
post #187 of 357 Old 05-01-2012, 05:11 PM
Run!
post #188 of 357 Old 05-02-2012, 12:22 AM
allan0210's Avatar
Quoted: 17 Post(s)
Fantastic price and 9.1 as well go for it
allan0210 is offline
post #189 of 357 Old 05-02-2012, 04:33 PM
dctrombly's Avatar
I keep reading mixed opinions about this receiver doing 11.x surround processing. It boasts 11 speaker terminals, DTS Neo: X, and DSX 11.2 calibration, so with a separate power amp why could it not do it?
post #190 of 357 Old 05-02-2012, 08:29 PM
mbrennem's Avatar
You can only pick 2 of 3 from: (front high, front wide, rear surround) and thus there is no way to run 11 discrete channels on the 1009, no matter how the amplification is arranged. It simply does not do the signal processing for all 11 channels at the same time. Note that I am not including the sub(s) when I am talking about 11 discrete channels.
It does allow you to plug in 11 speakers and then you can toggle between the speaker configuration options FH+FW or FH+RS or FW+RS, but there is no FH+FW+RS option, even using the pre-outs.
So anyone trying to run 11 discrete channels will be disappointed. I believe the higher-end Denon models might do what you are looking for.
mbrennem is offline
post #191 of 357 Old 05-03-2012, 04:53 PM
boothbrave's Avatar
Yeah thanks for the feedback on the front heights. I'm looking forward to hooking them up. They should rock the house !
boothbrave is offline
post #192 of 357 Old 05-08-2012, 06:17 AM
spentan's Avatar
Just pulled the trigger on one of these to replace my onkyo SR876.
Can't wait,
spentan is offline
post #193 of 357 Old 05-09-2012, 10:31 AM
mbrennem's Avatar
Yesterday I finally took the time to mount wide speakers and rerun a full Audyssey calibration. I did some testing with some movie and concert clips and I am really impressed with the way the wides "open up" the front soundstage and make it totally seamless, especially when playing at or near reference volume.
From now on I will only be using the back surrounds when playing movies with true discrete 7.1 content. For 5.1 (and less) content I will be using heights+wides.
The next thing to test will be for 7.1 sources do I prefer front height + rear surrounds, or front wide + rear surrounds? I suspect front wides will win the day but I haven't tested it yet.
mbrennem is offline
post #194 of 357 Old 05-10-2012, 06:21 PM
#1Tester's Avatar
Originally Posted by mbrennem View Post
My personal preference is Audyssey DSX over the other modes (IIz/DTS:Neo X)
Since i red ur post and started tryin it i can't seem 2 get away from it. How can i describe it? It sort of creates a presence right in front of the television with a virtual realm all around it. Pretty cool! (7.1-height & surrounds)
#1Tester is offline
post #195 of 357 Old 05-10-2012, 07:01 PM
Fastslappy's Avatar
Liked: 749
that's what is called a seamless soundstage !
Mike
post #196 of 357 Old 05-24-2012, 05:10 AM
Vallhall's Avatar
Hi
Does the 1009 has screensaver. I cant find any imformation about that in the manual. Its importent as i have a plasma TV?
Thanks in advance
Vallhall is offline
post #197 of 357 Old 05-26-2012, 02:43 AM
Maxi_TK96's Avatar
Originally Posted by Vallhall View Post
Hi
Thanks in advance
I don't remember a screen saver being mentioned in the manual. Plasma TVs are susceptible to "burn in" if you leave bright and static stuff there for a long period of time. As far as display protection technologies go a traditional screen saver might not be the optimal solution for plasmas (meaning a screen saver's main purpose is not specifically to protect plasma displays). Search google for "plasma burn in" and you'll get a more comprehensive knowledge about what "burn in" really is and how to prevent it from happening to our set. You don't have to look further than the top search hits.
Maxi_TK96 is offline
post #198 of 357 Old 05-26-2012, 05:08 AM
Vallhall's Avatar
Many thanks for your time
I have another question. On the old 905 i had, i could push the cd button, tuner button etc directly on the remote and it turns on. On the 1009 i have to turn the amp on first and so choose input. On the 905 i could choose input directly even if it was off
Vallhall is offline
post #199 of 357 Old 05-28-2012, 10:29 AM
gingerman's Avatar
Tried to play a flac file yesterday that was 192k/24bit and it fails. I thought the DACs in this were capable of 192Khz 24bit, does anyone know the limits of this receiver?
gingerman is offline
post #200 of 357 Old 05-28-2012, 11:21 AM
Vallhall's Avatar
According "WhatHfi", the 5009 cant play flac files (192/24) either over DLNA
Vallhall is offline
post #201 of 357 Old 05-28-2012, 01:13 PM
mbrennem's Avatar
According to page 96 of the manual, it only supports FLAC up to 96kHz (8/16/24 bit), and it doesn't support FLAC at all for "remote playback".
P.S. I see no support for any format over 96 kHz, so I'm pretty sure a 192 kHz file will not work in any format on the 1009.
mbrennem is offline
post #202 of 357 Old 05-29-2012, 05:57 AM
gingerman's Avatar
Thanks guys. I've sent an email to hdtracks.com to see if I can download the 96/24 version of the album instead without having to buy it again. That is what I get for not reading the manual before trying something new.
post #203 of 357 Old 05-29-2012, 08:21 AM
mbrennem's Avatar
If that doesn't work out do a google search for "transcode FLAC 192 96" and you should be able to do it yourself with something like dbPowerAmp.
mbrennem is offline
post #204 of 357 Old 05-31-2012, 11:09 AM
freshane's Avatar
After 10 months onkyo has finally issued me a credit at a store where I bought the receiver from. Has there been any issues with this receiver. Heat and hdmi board problems were found on the 876. Im kinda pissed on how long it took them to take care of this and hesitant on purchasing another onkyo product if they are still having problems. Might see if I can put the credit towards a yamaha a1010 or a2010. Will god out tomorrow what I could do. Thanks for any info on this unit
freshane is offline
post #205 of 357 Old 05-31-2012, 06:21 PM
lionorion's Avatar
No issues. Knock on wood! ?
lionorion is offline
post #206 of 357 Old 06-01-2012, 12:52 AM
allan0210's Avatar
Quoted: 17 Post(s)
Mine is maybe 14 weeks old no issues yet i idid have three 809 failures with hdmi though they went very fast and got exchanged straight away. So my thoughts on Onkyo service in the UK is good
post #207 of 357 Old 06-01-2012, 10:30 PM
freshane's Avatar
Great to hear this unit is made better!! Looks like I'm getting a 1009 to replace an 876. Should be getting it next week, can't wait to get it setup and finally have my ht up and running again. I also got an extended warranty so I'm covered for 5 years
freshane is offline
post #208 of 357 Old 06-02-2012, 12:25 AM
allan0210's Avatar
Quoted: 17 Post(s)
Good call i also took a 5 year warranty..
I had the 875 and i find the 1009 blew its socks off lol
post #209 of 357 Old 06-02-2012, 02:14 PM
gingerman's Avatar
HDTracks.com credited my order for the 192/24 album so I can rebuy the 96/24 version. Works for me, but the 15% coupon I bought it with is expired so now I have to pay a little more or wait for the next sale. I also downloaded the conversion program maybe I'll try that.
This is my first Onkyo after owning Sherwood, Denon and B&K in the past. It works flawlessly and I don't have any overheating issues.
post #210 of 357 Old 06-02-2012, 02:46 PM
Vallhall's Avatar
And i had the same experience with the 905...the 1009 realy rocks.
The biggest difference between the Onkyo 905 and 1009 is the heat. The 1009 is at best warm, but the 905 i swear i could have boils my eggs on it at the same volume...low volume that is
Vallhall is offline
