The "Official" Pioneer Elite SC-55/SC-57 Owners Thread - Page 13 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #361 of 4090 Old 08-29-2011, 04:08 PM
bakerzdosen's Avatar
Originally Posted by wseight View Post
Hi!
I am considering to purchase a SC-55 and bring it with me to Europe.
To do so I need to be able to hook it up to a 220V 50 Hz power supply.
Converting the power from 220 to 110 V for the receiver is no problem, but it is a bit more troublesome to convert the frequency from 50 to 60 hz.
Does any of you know if the sc-55 receiver is capable of handling a power supply at 50hz without modification?
Would it even be able to handle 220v input, I know some devices do.
This is just an educated guess, but since they specifically state 120V ~60Hz in both the documentation AND on the unit itself, there is really no way that they actually mean "120V ~50-60Hz"
I think you're out of luck without conversion or a different unit.
bakerzdosen is offline
post #362 of 4090 Old 08-29-2011, 04:43 PM
ibre34's Avatar
Quoted: 12 Post(s)
The frecuency doesn't matter, it is only a problem with motors, but not with electronics.
I am using an SC-37 in south america (220V 50Hz as well) for a year now without any issues.
I just bought an SC-57 and is in his way here now.
I own a 120V Pioneer Kuro too... go figure....
ibre34 is offline
post #363 of 4090 Old 08-29-2011, 05:09 PM
coltsfreak18's Avatar
For the record, my SC-57 has a loose power cord.
What is dead can never die. Long live my 151!
coltsfreak18 is offline
post #364 of 4090 Old 08-29-2011, 07:57 PM
Bud B's Avatar
Hi all,
For those with Power Cord issues, I noticed this on my Elite VSX 52 and 53.
I had posted on the VSX 52 Owners Thread and also wrote that all I had was an old Computer 3 prong Grounded computer Power Cord!
No 2 prong IEC Power Cord.
Someone responded, use it, the ground will just not have anything to connect with, it does not make any difference!
I felt like an idiot and not seeing the forest for the trees!
So, I plugged in an old IEC Power Cord and it went in nice and snug.
So give it a try, if you have an old Power cord, Grounded or not!
Like I said it does not really matter if there is a ground, it's just the 2 conductors.
Plus with a grounded plug at the wall, surge protector, wherever the receptacle, it is always plugged in correctly.
Good Luck,
Bud B
Bud B is offline
post #365 of 4090 Old 08-29-2011, 08:44 PM
My receiver, for some unknown reason, is really glitching with HDMI right now. I turned it on tonight to watch directv...no picture. Ok, so I made sure the input was correct and that the directv would play if connected directly to the tv, which it did. I connected a new HDMI cable from the receiver to the tv, and that did nothing. As such, I became concerned and began to try other sources. Blu ray didn't work, neither did ps3, comcast, or xbox.
At this point, I'm really concerned. The tv won't even display the settings menu, and when it does intermittently it becomes all red and noisy. The same thing happens with the second HDMI out and with every input on my tv (pio pro-151FD). it also won't playback audio, except when I manually start the MCACC. And it won't pass through either video or audio when I set the receiver to passthrough. I checked all of my settings, made sure HDMI-cec was off on both the receiver and the tv. I tried different HDMI cables, different inputs on the receiver, different outputs on the receiver, and different inputs on the tv. Nothing works, and I'm mad. Is there anything I should do before a complete factory reset, and, if that fails, a replacement or repair. At this point, however, if this turns out to be defective, I might not replace it with the same model because I already replaced my first SC-57 due to a faulty speaker terminal. Incidentally, my iPad is no longer able to connect to my receiver through the internet when the receiver is in standby; however, that should be a settings issue.
post #366 of 4090 Old 08-29-2011, 11:23 PM
wseight's Avatar
Sounds good! Let me know how you get along when you get your unit(just to make sure there is no issues with the new model)
I'm a couple of weeks away from ordering the unit anyway.
Are you using a voltage converter 220->110V or do you just plug 220v into the (110V)receiver?
wseight is offline
post #367 of 4090 Old 08-30-2011, 05:33 AM
ibre34's Avatar
Quoted: 12 Post(s)
I am using a voltage converter of course
ibre34 is offline
post #368 of 4090 Old 08-30-2011, 10:21 AM
zxlr8's Avatar
The SC-55 does not allow multi-channel in while the sc-57 does. Look at the shot of backs of each component. This is important for most people.
The Spiral Staircase Theater Build Thread
zxlr88- Xbox live and PS Network
zxlr8 is offline
post #369 of 4090 Old 08-30-2011, 10:24 AM
sdrucker's Avatar
Quoted: 865 Post(s)
Liked: 591
Did you try turning power cycling the Pioneer set and AVR for a few minutes and then rebooting? I used to have an Elite Pro-1130HD set a few years back, and it was VERY tempramental about HDMI handshakes. Every so often it would lose the HDMI connection from my Denon DVD-5910, and reseating cables, swapping cables, or trying a different HDMI-enabled device on the port didn't help.
The same thing happened with our Tivo Series 3 connection to the Pro-1130. If a cable got loose, I'd have to reboot the Pioneer for an extended period, or it would never recover the handshake. And even then, the problem would resurface every few months. I finally ditched the Pioneer and got a Panasonic when we bought a Blu-Ray player (obviously a last resort, given the quality of Kuro). But we haven't had nearly the same kind of HDMI issues since.
Have you tried turning off PQLS as well? Or trying a different display?
Audio Gear: Trinnov Altitude 32 (24 channel), NAD M27 amps (3)
Video: JVC RS600, Seymour 100" UF Screen, Lumagen Radiance Pro 4444 (coming soon)
Misc.: Oppo 103, Oppo 203 UHD player, JRiver
Speakers: PSB Imagine T3 LCR, Imagine T Wides and Side Surround 1, T2 Side Surrounds, Imagine XB rears, PSB CS1000 ceilings (6), HSU ULS-15 Mk 2 subs (4) - 11.4.6
sdrucker is online now
post #370 of 4090 Old 08-30-2011, 11:20 AM
kimvette's Avatar
Power cable:
http://www.rowand.net/Shop/Tech/WireCapacityChart.htm
14 ga: 17A
110V * 17A = 1,870 watts
120V * 17A = 2,040 watts
I don't see why the 14ga cable they provide would be inadequate (aside from loose cord issues; mine isn't loose BTW).
kimvette is offline
post #371 of 4090 Old 08-30-2011, 12:14 PM
WiWavelength's Avatar
Quoted: 29 Post(s)
Liked: 24
Multichannel analog input may be important to a few people, but it is not important to "most people."
HDMI input can replace all or nearly all applications that previously required multichannel analog input. Even those few users seemingly wedded to older DVD-A/SACD universal players that lack HDMI output would be better served to replace them with HDMI equipped universal players, which can be had for ~$150.
AJ
WiWavelength is offline
post #372 of 4090 Old 08-30-2011, 12:29 PM
tgetzoff's Avatar
Originally Posted by Pacbellguy View Post
I'm having audio gaps with certain programming on my AT&T U-Verse box via HDMI and optical. It seems to be real common for some reason with audience applause segments, like during The Daily Show on Comedy Central or The Soup on E, but also was happening tonight on the MTV Video Music Awards during some of the louder commercials.
I thought it was the same HDMI problem that the U-Verse box is known about, but hooking it up via optical on my Denon corrected it. It still happens even with optical on the SC-57. It also happens with both HD 5.1 and standard programming.
Update: Ok... it seems to be happening with 2 channel digital sources. For tonight's MTV Awards, the commercials said they were 2-channel digital input and the audio gaps would happen, but as soon as awards came back to DD 5.1... audio was fine.
I had the same problem with AT&T Uverse and an Onkyo NR3008--frequent and constant audio drop outs, in both HDMI and optical, and it was especially bad during the Daily Show. It actually wasn't as bad during 5.1 DD broadcasts. You can "fix" this by changing your Uverse digital audio output option from "surround" to "stereo." Of course, you have to constantly change it back when listening to a 5.1 source. My fix? I switched back from Uverse to DirecTv. TV service providers are like the long distance carriers from 15 years ago--they offer lots of freebies to switch back (although now I'm locked into DirecTV for 2 years).
tgetzoff is offline
post #373 of 4090 Old 08-30-2011, 12:56 PM
zxlr8's Avatar
AJ
New bluray players will play dvdaudio over hdmi? With correct bass management?
zxlr8 is offline
post #374 of 4090 Old 08-30-2011, 01:16 PM
Quoted: 29 Post(s)
Liked: 24
Yep, where have you been? For at least the past three years, numerous BD universal players and DVD universal players have allowed DVD-A and SACD playback over HDMI. (Some output SACD as native DSD, some as decimated LPCM, while some offer the user selectable option of either DSD or LPCM.)
The AVR or pre/pro is responsible for bass management, which is almost always performed in the digital domain. That is why HDMI connection makes so much more sense.
AJ
post #375 of 4090 Old 08-30-2011, 01:55 PM
zxlr8's Avatar
OK. Cool. Color me impressed. But can you give me a few besides the Oppo?
zxlr8 is offline
post #376 of 4090 Old 08-30-2011, 03:49 PM
Hugme1's Avatar
Hugme1 is offline
post #377 of 4090 Old 08-30-2011, 06:13 PM
purdyd's Avatar
purdyd is offline
post #378 of 4090 Old 08-30-2011, 07:26 PM
How do you turn off pqls? And yes, I will try a different display next. I tried power cycling, factory resetting, and everything else, nothing.
post #379 of 4090 Old 08-30-2011, 07:51 PM
Quoted: 29 Post(s)
Liked: 24
Careful. Few if any Denon/Marantz universal DVD-A/SACD players can output SACD playback as high res audio via HDMI. Most require a proprietary Denon Link connection for DSD output, and/or they do output SACD playback via HDMI but downsample DSD to CD quality 16 bit 44.1 kHz LPCM.
So, the presence of HDMI on a universal player does not automatically imply the capability to output DVD-A and/or SACD as high res audio via HDMI.
AJ
post #380 of 4090 Old 08-30-2011, 08:04 PM
kimvette's Avatar
Put remote in receiver mode, then press home, select #4 System Setup, then e. HDMI setup and set control to OFF. Exit the menu by pressing Home again, and see if that resolves it.
kimvette is offline
post #381 of 4090 Old 08-30-2011, 08:04 PM
Samsara's Avatar
Before I drive myself crazy with more Googling, I'll just ask if my expectations are simply unreasonable. Can I not pair an HDMI video source with optical audio? Both work separately, but as soon as I add video to audio or vice versa, the optical drops out.
If this isn't possible, is this common across manufacturers? This is my first HDMI receiver, and with the secondary output, I was counting on it replacing the splitter I've been using.
Samsara is offline
post #382 of 4090 Old 08-30-2011, 08:06 PM
kimvette's Avatar
Yes, you can run S/PDIF alongside HDMI but you can run into audio/video sync issues on occasion.
kimvette is offline
post #383 of 4090 Old 08-30-2011, 10:24 PM - Thread Starter
FilmMixer's Avatar
Quoted: 1960 Post(s)
Liked: 2420
No... and I have to ask why you would want to and how it related to the secondary output (i.e. what exactly are you trying to accomplish?)
Both video and audio are encoded on the single stream, which is why you cannot strip one from the other.
FilmMixer is offline
post #384 of 4090 Old 08-31-2011, 05:59 AM
Samsara's Avatar
HTPC is doing DisplayPort to HDMI with no audio on that cable. I split this to the kitchen along with the analog audio from the PC to mirror what's in the living room. Just thought I'd have been able to simplify things a bit.
Samsara is offline
post #385 of 4090 Old 08-31-2011, 11:39 AM
purdyd's Avatar
Careful. Few if any Denon/Marantz universal DVD-A/SACD players can output SACD playback as high res audio via HDMI. Most require a proprietary Denon Link connection for DSD output, AJ
i'm not a Denon die hard but isn't Denon Link going away? and ilink for that matter?
i notice this new Denon universal player doesn't have it and claims DSD over HDMI
page 52
http://usa.denon.com/DocumentMaster/...ENG_IM_001.pdf
purdyd is offline
post #386 of 4090 Old 08-31-2011, 03:34 PM
Already done on both the display and receiver.
post #387 of 4090 Old 09-01-2011, 10:19 AM
DavidPotter's Avatar
I wanted to give an update since I posted that my SC-55's center channel failed. I took it to Magnolia Audio Video in Bellevue, they verified that the center channel wasn't working, and then gave me a new one. Great service.
One thing that may have contributed to the problem - just a guess. I didn't set the speaker settings of the unit before using it as it was getting late and my wife wanted to watch a movie. The unit defaults to 9.x channel mode, but I only have 5.1 channels. I also plugged my rear surround speakers into the SURROUND BACK posts instead of the SURROUND posts.
With the new one I configured it before doing anything else and then I ran Full Auto MCACC. Plus I plugged the rear speakers into the SURROUND posts like the manual says . I don't know if this had anything to do with the failure of the first one, but I thought I'd mention it because this time around everything seems to be working just fine.
My recommendation is to make sure you configure the unit before you do anything else. Oh, and if you only have one set of surrounds, plug them in to the SURROUND posts, not the SURROUND BACK posts.
DavidPotter is offline
post #388 of 4090 Old 09-01-2011, 12:07 PM
DonH50's Avatar
Quoted: 2172 Post(s)
Liked: 1756
That would not cause your failure (oh, could have caused problems if you had shorted the terminals, but the AVR would have said so and shut down). Be not concerned, and enjoy the new toy!
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
post #389 of 4090 Old 09-01-2011, 01:09 PM
patwho's Avatar
Hello I have a SC 27 and was wondering if upgrading to the Sc 55 would be better. Please talk me out as the upgrade bug is with me. Thanks
patwho is offline
post #390 of 4090 Old 09-01-2011, 02:25 PM
Quoted: 29 Post(s)
Liked: 24
i.Link, yes, it has mostly fallen out of favor. But Denon shows no signs of abandoning Denon Link, as Denon introduced its latest version, Denon Link 4th edition, just two years ago and continues to include it on some current AVRs and BDPs.
Recall what I wrote: "Few if any Denon/Marantz universal DVD-A/SACD players can output SACD playback as high res audio via HDMI." The 2012UDCI is one of those few (maybe the only?). It does not have Denon Link because it is only an entry level to mid range Denon player.
AJ
Pioneer Elite Sc 55 Sc55 9 1 Channel 3d Ready A V Receiver , Pioneer Elite Sc 57 Sc57 9 1 Channel 3d Ready A V Receiver
