The "Official" Pioneer Elite SC-55/SC-57 Owners Thread - Page 137 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #4081 of 4090 Old 12-30-2016, 12:35 PM
MillPhoto's Avatar
SC-57 virtually no sound
Hi fellow SC-57 owners.
I was recabling today to add a 4k video switch since our receiver will not switch 4k video. Started having sound issues. Tried HDMI input, digital (optical) etc. Nothing. Also no longer able to get the OSD to show on the TV when I plugged it back into HDMI1 out.
Went into menu using front panel and ran the speaker test. Volume increases to 0db on the display as usual but only the quietest of sound from the speakers. I can hear the test tones but barely.
I have a bad feeling about this. Anyone have a similar experience or can suggest some checks I can do? I was hoping it was something I did wrong but when the receiver can't even amplify generated tones - it sounds more ominous...
Thanks in advance.
Update: A factory reset got my volume levels back but I've now noticed a new problem.
I am running the speaker config in 5.1 with Front and Center BiAmp and standard Surrounds (no sub at the moment as it is out for repair).
The right front channel and surrounds seem to work fine.
The left front and center channels are not getting anything on the low frequency side. Hi frequency works fine. So all dialog sounds like a transistor radio and all bass comes from the right. This is apparent with channel test tones or content.
Again, any suggestions welcome.
Cheers,
Frank
MillPhoto is offline
post #4082 of 4090 Old 06-12-2017, 01:49 PM
Edllguy's Avatar
Quoted: 155 Post(s)
Liked: 69
^^^Has this been resolved?
Sorry to be repetitious but it looks like the common UE22-Error defect has occurred with your system. Can you update us?
Edllguy is offline
post #4083 of 4090 Old 06-24-2017, 08:12 PM
Liked: 0
Pioneer Elite SC-55
Hi,
I have a SC55 and I have two problems with it :
1- I connected my tv receiver using hdmi and optic but the receiver keeps reverting to the hdmi and bypass the optic even if in the input menu opt-1 is selected.... Could my optic cable be defective ?
2- When on tuner mode I can ear the radio unless I max out the sound. Tuner is the only input that has that problem. TV, PS3, HMG all work normaly ...
Anyone can help me ?
thevaliant is offline
post #4084 of 4090 Old 06-26-2017, 01:02 PM
erick granato's Avatar
Quoted: 38 Post(s)
Liked: 31
Does anybody know if you can apply scaling and video processing to each HDMI input independently?
erick granato is offline
post #4085 of 4090 Old 07-15-2017, 12:09 PM
Quoted: 13 Post(s)
Liked: 0
what would be a reasonable price for an used elite sc-55 from craigslist? The ue22 error, and description says the hdmi takes a minute to warm up? but its described as working and as like new. Would pioneer still take care of me if ue22 pops up later?
midfield99 is offline
post #4086 of 4090 Old 07-15-2017, 12:14 PM
Quoted: 13 Post(s)
Liked: 0
Oh, probably should mention this, this will be my first home theater audio setup. I live in an apartment, and might stick with a 3.1 at the start. Will mainly be using it with my pc and 4k tv, or both because I'll mainly be using my tv hooked up to my pc. So most features might be a tiny bit overkill. But the price is close to $100.
post #4087 of 4090 Old 07-15-2017, 01:36 PM
timjohnson1717's Avatar
Quoted: 85 Post(s)
Liked: 81
HDMI is digital, it doesn't take time to "warm up" I would stay well away from this.
timjohnson1717 is offline
post #4088 of 4090 Old 09-07-2017, 09:15 AM
Kurolicious's Avatar
Quoted: 32 Post(s)
Does anyone know where I can get a replacement remote control for an SC-57?
Kurolicious is offline
post #4089 of 4090 Old 09-07-2017, 01:40 PM
popalock's Avatar
Quoted: 1315 Post(s)
Liked: 1814
http://www.remotes.com/pioneer-p/pioneer-axd7612.htm
You are welcome...
popalock is offline
post #4090 of 4090 Old 09-07-2017, 02:22 PM
popalock's Avatar
Liked: 1814
Now my question... Where can one find a replacement OEM MCAAC mic? Link please?
popalock is offline
Pioneer Elite Sc 55 Sc55 9 1 Channel 3d Ready A V Receiver , Pioneer Elite Sc 57 Sc57 9 1 Channel 3d Ready A V Receiver
