The "Official" Pioneer Elite SC-55/SC-57 Owners Thread - Page 34 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #991 of 4081 Old 10-29-2011, 01:20 AM
dmoney76's Avatar
I have a sc-25, do the new units have any sub eq In The mcacc?also anyone have issues with it dropping dolby when watching tv?
dmoney76 is offline
post #992 of 4081 Old 10-29-2011, 03:47 AM
Jarrod2750's Avatar
Quoted: 31 Post(s)
I'm considering upgrading to the 55 from a 94. My front speakers are biamped using a Yamaha m 1. When I upgrade I want to still biamp. Would you recommend instead of the Yamaha a pioneer elite m90 or emotiva upa 5? My speakers are klipsch epic cf 3's and I plan on having a 9.2 system. Thanks!
Marantz AV8802A, (2) Parasound 2125 V2,(2)Parasound 2250, Panamax 5400
Klipsch Epic CF3 V1, KV 4, (4) RS7,(2)KG1.5, (2)CDT5650
Panasonic GTS60,Pioneer elite bdp23, Pioneer PL1000A
Squeezbox Touch, Vortexbox, PS4, Coinop Xbox
Jarrod2750 is offline
post #993 of 4081 Old 10-29-2011, 05:17 AM
ccotenj's Avatar
Liked: 101
no sub eq.
i suggest you not bother bi-amping... i would also suggest that even a bargain basement avr will EASILY drive your speakers to ear bleeding levels, and that any additional amplification is merely jewelry...
- chris
ccotenj is offline
post #994 of 4081 Old 10-29-2011, 09:19 AM
Jarrod2750's Avatar
Quoted: 31 Post(s)
Originally Posted by ccotenj View Post
no sub eq.
I've notice an improvement with biamping currently , just trying to get an opinion on whether I should upgrade my Yamaha amp to a pioneer or emo when I go from the 94 to 55.
post #995 of 4081 Old 10-29-2011, 09:23 AM
ccotenj's Avatar
Liked: 101
even if you choose to ignore the first part of my post, the second part answers your question...
but i doubt that will change your beliefs, either....
- chris
ccotenj is offline
post #996 of 4081 Old 10-29-2011, 10:33 AM
purdyd's Avatar
My second biggest disappointment is home media gallery (hmg)
As far as I can tell it is 720x480 4:3 and there is no way to display a 1920x1080 jpeg directly onto a 1080p display
The dlna client in hmg is very primitive searching for music is time consuming and visually it is very spartan
The pause function doesn't work when streaming from a dlna server
Now I can understand pioneer's decision to have limited graphics in the receiver since there is icontrolav2
But that app does nothing to improve on the limitations of hmg and in fact is worse since it does not display as much information on songs as even the very primitive hmg onscreen display
Which leads to disappointment 3, icontrolav doesn't do everything that the remote does
And I would say the only way to find this out is to buy these things and use them as the documentation is almost completely lacking
purdyd is offline
post #997 of 4081 Old 10-29-2011, 01:25 PM
kimvette's Avatar
Originally Posted by purdyd View Post
I think icontrolav is the future
If you don't have an iPad with this receiver you are really missing out
Wow, that looks far more useful and less gimmicky than the iPhone version.
kimvette is offline
post #998 of 4081 Old 10-29-2011, 06:50 PM
turnne1's Avatar
Quoted: 1755 Post(s)
Liked: 410
are you saying that because of his speakers...or
generally speaking?
Warren
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Hisense H50C Yamaha A2050 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 51E8000 Sony DA5400ES Mirage Omni sat speaker system
turnne1 is offline
post #999 of 4081 Old 10-29-2011, 06:51 PM
purdyd's Avatar
Just for zone control it is worth using icontrolav2
The graphics are good but they didn't use all that room effectively, in particular for hmg
Viewing calibration data is really cool feature but you can't actually run mcacc from the iPad
purdyd is offline
post #1000 of 4081 Old 10-30-2011, 09:04 AM
Borda's Avatar
Originally Posted by coltsfreak18 View Post
I don't know what that means; if it means bi-amping, then yes, but if it means tri-amping (I get that from the t), then no.
Are you saying that you don't have front height or front wide channels?
The front height channel is used to bi-amp the front speakers in a 7.1 channel, the front wide outputs bi-amp the speaker B selection, and the surround back channel bi-amps either the center channel or the surround channels. Your speakers MUST be bi-ampable and have two sets of red/black speaker connectors (one high and one low). If your front height channel connectors are free, then you can connect those to the fronts and bi-amp them through the setup menu.
Technically, bi-amping does not double the power output; it does increase it, and it helps the crossover very much.
Sorry.
First, congratulations to all of the forum and excuse me for the english.
I began to read this threadd because i was interested in buying a new receiver to replace my very old Pioneer. I have just been ordering the SC-57 but i still have not received it (live in Brazil ... rs).
I want to make biamping in the frontal speakers of two systems, that will receive the same source. 5.1 system A and a couple of stereo B. By which i could understand of the manual, i can use any of amplifiers available to make the biamping.
For example: with the front speakers A connected in Front, would use Front Height for biamping and in set B connected in Front Wide, would use Surround Back. Am I correct?
My doubt, is how the receiver will know who is the set A and set B, if i put the B in Front Height? Is this possible?
Please to meet you.
Borda is offline
post #1001 of 4081 Old 10-30-2011, 12:02 PM
Jarrod2750's Avatar
Quoted: 31 Post(s)
generally speaking?
Warren
Since I'm the poster I'm curious too.
post #1002 of 4081 Old 10-30-2011, 12:35 PM
dv573's Avatar
I am new to this forum so if not posted to the correct location, please point me in the right direction.
I would like to use my Denon AVR 5600 as an external amplifier to drive some outdoor speakers I have.
I have already connected seven speakers to my SC-57 in my main listening area plus a pair of speakers in zone 2 (dining room) and zone 3 (kitchen). I know there are several pre-out jacks but they seem designed to provide addtional power to existing speaker selections.
Is there a way to add my Denon to this system so I can drive 2 or more sets of additional speakers while using the Pioneer as the source for whatever input I choose?
Thanks for any help you can provide
dv573 is offline
post #1003 of 4081 Old 10-30-2011, 01:47 PM
audio777's Avatar
Yea, ME TOO!
audio777 is offline
post #1004 of 4081 Old 10-30-2011, 01:58 PM
zoetmb's Avatar
Quoted: 67 Post(s)
Liked: 62
The problem with the remote. Is that it really needs twice as many keys and doesn't have a display or feedback from the receiver
Yes, but buying a $500 iPad increases the cost of the receiver by a third. I don't want to have to spend that kind of money just for a better remote. While i appreciate that it's supported, Pioneer still needs to improve its own physical remote and the overall UI of the receiver. Besides, if you carry the iPad with you and you have a family, then you have the "remote" if they're home and want to watch/listen (or vice-versa).
In fact, I think the screen on the Pioneer itself should be a small bitmapped display (perhaps iPhone sized). I bet it would add only around $100 to the cost of the receiver. Maybe it even pops out to become the remote. That would provide a better UI and it would be upgradable.
zoetmb is offline
post #1005 of 4081 Old 10-30-2011, 02:04 PM
zoetmb's Avatar
Quoted: 67 Post(s)
Liked: 62
You can use the VCR out jacks to drive the Denon. But (AFAIK) it would be the same signal you're listening to on the main system. You couldn't, for example, be watching a movie in the house and listening to a CD via the Pioneer for the outdoor speakers. But if that's what you want to do, just hookup a CD player to the Denon and keep the systems separate. Frankly, I've never understood this great desire to use Zones if you have to add another amplifier anyway.
zoetmb is offline
post #1006 of 4081 Old 10-30-2011, 03:29 PM
purdyd's Avatar
You can use an iPod or iPhone too or any number of android solutions, in my house there are two iPods,an iPhone, and iPad, if You weren't going to take advantage of AirPlay you should have got yourself one of the smoking deals on the sc37s
And as far as 'taking the remote with you" that it why there is the cheap current remote
You want pioneer to develop a remote that is just like an iPod only cheaper? It ain't going to happen
Just look at the cost of the wifi adaptor
You can buy an rf remote for your receiver, it is last years sc37 remote, of course it will set you back $300 and it doesn't have a screen
The sc57 cheaper this yea than the sc37 and I am guessing that remote is a big reason
So if you were willing too pay $100 more just for a screen, that would have been hard to see anyway, go fork over $200 for an iPod and you can stream music all day long over AirPlay
purdyd is offline
post #1007 of 4081 Old 10-30-2011, 03:38 PM
graphicguy's Avatar
Chris...I concur. I've tried bi-amping with two sets of different speakers, with two different AVRs/amps. No improvement. Matter of fact, less wiring is always better than more.
Music so high you can't get over it....music so low you can't get under it!
graphicguy is offline
post #1008 of 4081 Old 10-30-2011, 04:32 PM
purdyd's Avatar
Please to meet you.
It appears you can not biamp front and speaker b
Check the diagrams in the us manual and see if one of them matches what you need
http://www.pioneerelectronics.com/St...ions060711.pdf
purdyd is offline
post #1009 of 4081 Old 10-30-2011, 09:25 PM
Fanaticalism's Avatar
That is because your cables weren't resolving enough. You need something like Audioquest WEL signature cables at 11k for a 3ft run! The issue arises where now your cables are TOO resolving for the speakers holding the biamping back so you then have to upgrade your speakers to something like a Wilson Audio AX at a bare minimum, but then the electronics... OH WHAT A VICIOUS CIRCLE!
Fanaticalism is offline
post #1010 of 4081 Old 10-31-2011, 04:52 AM
patwho's Avatar
Hello, I need some help. I want either the 55 or 57. I have a 5.1 system and will not be upgrading any time soon. What are the differences between the two. What is the ten speaker config. The rest is pretty self explanatory. Are the amps the same? Thanks Pat
patwho is offline
post #1011 of 4081 Old 10-31-2011, 08:12 AM
kimvette's Avatar
Most of those questions are answered multiple times in this thread already - there is a lot of great info here and you would do yourself well to read through it.
As far as the 10-speaker layout, here is what the AVR supports:
(1) front center
(2) front wide
(2) front height
(2) front mains
(2) surround
(2) rear surround
(2) LFE (subwoofer)
So there is a total of 11.2 (-2.0) you can select from, since this AVR is limited to 9.2 channel processing.
Check out pp 13-15 and 17-21 of the manual* for info on speaker configurations.
* downloadable here: http://www.pioneerelectronics.com/St...ions060711.pdf - both the SC-55 and SC-57 are covered in the same user manual.
kimvette is offline
post #1012 of 4081 Old 10-31-2011, 08:12 AM
Swamibob's Avatar
Quoted: 35 Post(s)
Amps are rated the same power, but the 55 is THX select certified, and the 57 THX ultra certified. Don't really know why since they both are rated at 140 watts.
The only other differences I know of are in the fine adjustments for exact speaker settinges, which down to .5" is close enough for me. The auto room correction is supposed to be slightly better on the 57 also. It wasn't worth another $400 to me so I went with the SC-55 and I love it.
Swamibob is offline
post #1013 of 4081 Old 10-31-2011, 09:45 AM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
Filmixer went through both recievers at the start of this tread, go there!
bsoko2 is offline
post #1014 of 4081 Old 10-31-2011, 09:46 AM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
Over the weekend, I replaced my SC-37 with the SC-57. All I can say is "Wow", big difference.
Bill
bsoko2 is offline
post #1015 of 4081 Old 10-31-2011, 10:17 AM
patwho's Avatar
Hello, Thank you all , I did read but I guess I'm a newbie I did not really understand so thanks again!!
patwho is offline
post #1016 of 4081 Old 10-31-2011, 11:21 AM
graphicguy's Avatar
I knew it was something I was overlooking.
PS....need an opinion here. I've decided to sell my slightly (and I do mean slightly) used SC27. Suggestions on if AVS or eBay is better?
post #1017 of 4081 Old 10-31-2011, 12:04 PM
ccotenj's Avatar
Liked: 101
selling it to fund those cables?
ime, i've had good luck selling quite a few things here... might get a few less dollars for it, but that's likely made up by not having to pay fleabay fees...
- chris
ccotenj is offline
post #1018 of 4081 Old 10-31-2011, 12:25 PM
graphicguy's Avatar
Chris...kind of leaning towards selling it here. At least it would have a dedicated audience vs the "will it fit in my trunk to power my '82 Honda's speakers?" group that could turn up on "fleabay".
I've only sold one thing here. Turned out well. Probably give it another shot.
The SC27 is an excellent AVR (as are all the SCs). My Denon 4311 fits perfectly for what I'm using it for (especially Audyssey XT32 and dual sub integration).
Now, I have to take pics and put it "for sale".
post #1019 of 4081 Old 10-31-2011, 01:00 PM
ccotenj's Avatar
Liked: 101
might as well... you don't HAVE to sell it (shame on you for not adding on to the land of misfit a/v equipment btw ), so if it sits for a few weeks, it's no biggie...
yup, it is a great avr... you should have no problems selling it for a decent price...
i see you are liking life on the dark side...
- chris
ccotenj is offline
post #1020 of 4081 Old 10-31-2011, 10:39 PM
emilsal's Avatar
Does anyone know how to force the sc-57 to output rgb 16-235? Out of the box the only mode that looks correct with my PRO141-FD is YUV 4:4:4. From my calibrators recommendation its probably best that i leave my Kuro's colorspace hard coded to 16-235. Thanks!
emilsal is offline
Pioneer Elite Sc 57 Sc57 9 1 Channel 3d Ready A V Receiver , Pioneer Elite Sc 55 Sc55 9 1 Channel 3d Ready A V Receiver
