The "Official" Pioneer Elite SC-55/SC-57 Owners Thread - Page 94 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
Old 04-14-2012, 09:27 AM
ccotenj's Avatar
Liked: 101
Originally Posted by zoetmb View Post
But in my opinion (and I'm an ex-recording engineer), I think sub-woofer EQ might be overrated. It's just not that broad a frequency band to require EQ. If it's too loud, either turn it down via its volume control or if it doesn't have one, turn it down via the Pioneer manual setup settings. The one exception to that is if it resonates at one particular frequency. If that's the case, then EQ actually would be helpful, although a well-designed sub-woofer shouldn't have that problem.
your opinion in this case would be incorrect...
in the great majority of home environments, subwoofer eq is the most important part of an eq'ing scheme... that is where most of the problems live...
as far as the "hear it as the engineer intended it"... that is what room correction attempts to achieve... by using it, you ameliorate the effects of your room on the signal, thus making what hits your ears "more accurate"... not using rc will rarely result in "more accurate" sound..
- chris
ccotenj is offline
Old 04-14-2012, 02:05 PM
purdyd's Avatar
I haven't listened to the 4311, because I got burnt by Denon some years ago and I won't go back there, so I don't know whether it sounds better or worse than the Pioneer.
that is heresy in this forum,
Didn't you know this is the really the Denon 4311 forum and to say you don't think subwoofer equalization is needed will get you a mandatory tongue lashing?
It doesn't matter if it is true or not and there is no way you could enjoy listening to your music without having that feature.?
purdyd is offline
Old 04-15-2012, 04:04 AM
Joost80's Avatar
didn't you know this is the really the denon 4311 forum and to say you don't think subwoofer equalization is needed will get you a mandatory tongue lashing?
:d:d:d
Joost80 is offline
Old 04-15-2012, 11:36 AM
joepags's Avatar
Too funny!!!!!
joepags is offline
Old 04-15-2012, 01:56 PM
sdrucker's Avatar
Quoted: 680 Post(s)
Liked: 455
Walkamo should shake your hand and use your quotes in a testimonial. Also, since I see that the newest Pioneer AVRs (non-Elite; the VSX-122) on the US Pioneer site have actual firmware updates, Purdyd should be a happy man and have his faith restored. Maybe there's an SC-61 in his future:-)
Audio Gear: Trinnov Altitude 16/24, NAD M27 and Wyred4Sound MMC-7 amps
Display: Panasonic VT50, Lumagen Radiance Mini. Misc.: Oppo 103, Samsung K8500 UHD player, JRiver
Speakers: PSB Imagine T2, Center, Imagine T Wides and Side Surrounds, Imagine S rear surrounds,
PSB Imagine XA Dolby AE Speakers (4), HSU ULS-15 subs (4) - 9.4.4
sdrucker is online now
Old 04-15-2012, 02:16 PM
ss9001's Avatar
Quoted: 338 Post(s)
Liked: 397
A miracle has happened!
- Improve the stability of HDMI connection.
- Improve the stability of NETWORK features.
- Other improvement.
Bug fixes...better than nothing
Steve
ss9001 is offline
Old 04-15-2012, 02:31 PM
sdrucker's Avatar
Quoted: 680 Post(s)
Liked: 455
But it IS a firmware update. The Audio Gods must be smiling down on Pioneer.
Old 04-15-2012, 06:28 PM
tmc1971's Avatar
Quoted: 38 Post(s)
Liked: 26
i came home today and my sc55 doesnt seem to be sending hdmi signal to tv anymore. any suggestions ? it worked fine for weeks...just all of a sudden it wont send signal
thanks
tmc1971 is offline
Old 04-15-2012, 09:12 PM
purdyd's Avatar
Just because I disagree at times with you and a couple of other extremely vocal posters does not make me a Pioneer zealot.
And if Pioneer really wants to impress me, they would update ALL elite pioneer receivers, not just the ones released this year.
purdyd is offline
Old 04-15-2012, 10:00 PM
sdrucker's Avatar
Quoted: 680 Post(s)
Liked: 455
Point taken, on both fronts.
Old 04-16-2012, 04:37 AM
DeleriumTremens's Avatar
On the Zone 2 -- thank you. ended up using RCA's to "CD" and can run it from that fine. Appreciate the help.
Sound is still bright, but I'll keep working through it. My guess is that it is just a lot of tweaking that needs to happen.
DeleriumTremens is offline
Old 04-16-2012, 06:39 AM
Chris Blount's Avatar
Quoted: 25 Post(s)
OK, so for me, SC-55 is really bright. Very clear and crisp but too bright. How do you all suggest to "warm" the sound a bit. I tried using the X-Curve feature but that seems to deaden the sound more than anything else. I then tried using the equilizer on the iPad app and I guess that sort of works. Any other suggestions?
Chris Blount
Chris Blount is offline
Old 04-16-2012, 07:09 AM
Kurolicious's Avatar
Quoted: 31 Post(s)
Have you tried engaging the THX Cinema mode? This will re-equalize your system to curb the highs and give it a more "warm" sound.
Kurolicious is offline
Old 04-16-2012, 09:39 AM
Quoted: 25 Post(s)
I will give that a shot. Thanks.
Chris Blount
Old 04-16-2012, 10:05 AM
sdrucker's Avatar
Quoted: 680 Post(s)
Liked: 455
The other thing you can look at are the DAC filter settings. They can adjusted under the audio parameters IIRC:
http://www.avsforum.com/avs-vb/showp...&postcount=270
I think 'slow' is supposed to have warmer sound than 'sharp' or 'short'
Old 04-16-2012, 10:14 AM
bsoko2's Avatar
Quoted: 71 Post(s)
Liked: 78
Audio Parameters try using the Tone controls. Boost the bass 1 or 2 db.
bsoko2 is offline
Old 04-16-2012, 11:07 AM
fourminutesong's Avatar
Hello!
Very new to this forum. Lots of great info and enthusiasm here. Just got the SC-55 over the weekend and am loving it so far. The Airplay feature is excellent with the Ext.Stereo feature on and we're loving the iControl app when watching TV. Just had 2 quick questions for any SC-55 experts out there.
1) I have all of my HDMI components (DirecTV, BluRay, XBOX 360, Apple TV, etc) going into the receiver with one high quality HDMI cable going into the TV. I've noticed a slight color shift on the TV now. Nothing dramatic but wondering if this is normal when not running your HD cable service right into your TV. Is it worth getting re-calibrated now that its running into the receiver first? Has anyone else experienced a degradation of signal? Maybe I'm crazy but the color seems a bit off now.
2) I have a fairly inexpensive Crosley turntable that I tried running into the Phono input last night but got an incredible amount of distortion. The Crosley doesn't have a ground, whereas the phono input does. Wondering if the distortion would be normal in this case or if there might be an issue with that input. Any ideas?
Any advice is much appreciated. Much to learn on this receiver!
Carey
fourminutesong is offline
Old 04-16-2012, 12:28 PM
Remote Man's Avatar
thanks
I have the same problem. My SC-55 worked great for a month then my TV stopped working but my projector works great.
Remote Man is offline
Old 04-16-2012, 01:20 PM
DonH50's Avatar
Quoted: 1795 Post(s)
Liked: 1330
Is sub EQ over rated? I am not sure... There are usually only a few modes below Pioneer's LF EQ, and it is hard to do anything with nulls using EQ anyway, so it might be less important than some believe. I do not know. That said, one difference between XT32 and MCACC is the number of filters, and I strongly suspect the much greater number of filters in XT32, many of which are used in the bass (not neccessarily subwoofer) region, are behind much of the perceived and measured improvement in the bass FR.
The assumption is XT32 does indeed have many more filters; I don't know for sure. Does MCACC only use the nine EQ bands and three PEQ ("standing wave") bands shown? Compared to hundreds with XT32...
All IMO - Don
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is offline
Old 04-16-2012, 05:14 PM
tmc1971's Avatar
Quoted: 38 Post(s)
Liked: 26
did you ever figure what to do ? Is it a defect ?
thanks
tmc1971 is offline
Old 04-16-2012, 05:54 PM
Remote Man's Avatar
thanks
I am still working on it. I had a Pioneer expert look at it and he couldn't fix the problem. He thinks that it is my TV's Hdmi board but I don't agree. I have a Pioneer 1130 HD and no problems until my purchase and use of the Pioneer sc 55. My projector outputs 1080p and my TV outputs 1080i so I think it's a resolution and handshaking problem that I don't know how to fix. Every source including cable, ps3, xbox360, apple tv and my blue ray works perfectly through my projector.
This site is supposed to be about helping Pioneer Elite SC 55/57 owners address set up problems but most of the dialogue is about Denon, Audessey and other topics. Give me a shout if you solve your problem and I will do likewise.
I might hook an old receiver up and see if the problem remains. I tried it with my 1080p kitchen tv and it worked fine.
D
Old 04-16-2012, 06:07 PM
tmc1971's Avatar
Quoted: 38 Post(s)
Liked: 26
[quote=Remote Man;21915086]I am still working on it. I had a Pioneer expert look at it and he couldn't fix the problem. He thinks that it is my TV's Hdmi board but I don't agree. I have a Pioneer 1130 HD and no problems until my purchase and use of the Pioneer sc 55. My projector outputs 1080p and my TV outputs 1080i so I think it's a resolution and handshaking problem that I don't know how to fix. Every source including cable, ps3, xbox360, apple tv and my blue ray works perfectly through my projector.
D[/QUOTE
Sounds like a pile a crap from Pioneer. I just connected all my devices direct ti tv and everything is ok. Problem is in the SC55...What a pi$$ off.I just got rid of my Onkyo due to all the issues,...now this 3 months into owning it...grrrrr
tmc1971 is offline
ccotenj's Avatar
Liked: 101
@remoteman...
your tv "outputs" 1080i? no... your tv is a 720p set... it "accepts" 1080i...
unfortunately, the knowledge base for pioneer units rests primarily with some of us who no longer use pioneer equipment... we can still help, if you like, as it appears that the current owners are better at complaining than explaining...
my initial guess is that you are trying to force 1080p... what do you have the video settings in the avr set to?
step 1: turn OFF video processing in the avr (as well as hdmi control on ALL devices)... see what that gets you... then we can go from there...
- chris
ccotenj is offline
Old 04-16-2012, 06:10 PM
ccotenj's Avatar
Liked: 101
[quote=tmc1971;21915136]
D[/QUOTE
nope, you can't draw the assumption that the problem is with the avr... simply connecting directly to the display and having it all work does NOT imply that the issue is with the repeater, it could be (and is, in most cases) the source and/or the sink not playing nice with a repeater in the chain...
- chris
ccotenj is offline
Old 04-16-2012, 06:20 PM
tmc1971's Avatar
Quoted: 38 Post(s)
Liked: 26
[quote=ccotenj;21915143]
thanks...ill keep that in mind...im just ticked off...just put finishing touches on my system 2 weeks ago
tmc1971 is offline
Old 04-16-2012, 08:09 PM
Originally Posted by fourminutesong View Post
Hello!
Carey
If anyone is reading this for newbies - is anyone having receiver menu and remote problems? I have to press the video (or audio) parameter button about a dozen times for the menu to actually work. I can see it flickering between the tuner and the audio parameters until it actually sticks on the right menu. It does this for every other menu as well. On top of this it is skipping to 2 integers instead of 1 - as in, when going from Tuner presets and trying to go from 1 to 2 to 3 it just goes 1 to 3 to 5 and so on.
Seems very temperamental. Wondering if its a software issue or if I've got a lemon? The remote and receiver and on screen menus do not seem to be good friends.
Old 04-16-2012, 08:25 PM
Anyone?
Old 04-16-2012, 08:40 PM
purdyd's Avatar
Sorry, there are a lot of posters on here who don't own these receivers and would rather tell you why you should have bought another brand
Again, I would play with the digital filters, Page 62 dfilter, but default is short which is supposed to be warm
Also I assume you ran mcacc and are playing with it on?
The default mcacc can tend to reduce the bass as the measurements are made after the bass has had time to echo around
You need to look at the reverb graphs and see if that is happening
The solution is to run mcacc and specify the delay time, 50 msec is a good place to start but again, you need to see the reverb graph
Here is a reference that explains this
http://www.pioneerelectronics.com/St...ctions0708.pdf
purdyd is offline
Old 04-16-2012, 08:42 PM
purdyd's Avatar
Anyone?
Sounds like a bad remote
Do you have any other remotes you can program to control the receiver?
purdyd is offline
Old 04-16-2012, 08:51 PM
Remote Man's Avatar
Originally Posted by ccotenj View Post
@remoteman...
Thanks for responding. I turned off video processing and HDMI control with no change.
D
Pioneer Elite Sc 57 Sc57 9 1 Channel 3d Ready A V Receiver , Pioneer Elite Sc 55 Sc55 9 1 Channel 3d Ready A V Receiver
