Onkyo SC5509 Processor - Page 7 - AVS Forum | Home Theater Discussions And Reviews
post #181 of 286 Old 01-23-2012, 07:27 PM
DMark1's Avatar
Originally Posted by bobpaule View Post
You bet, the dealer network have been screaming for mercy ever since distribution companies like Markertek started dishing out the Onkyos at decent prices.
Bob - where do you see Onkyos on Markertek's website?? I searched their site with no results for "Onkyo"....?
Fine Music, Movies, Wine, and Friends - A Life Well Lived!
DMark1 is offline
post #182 of 286 Old 02-08-2012, 03:13 AM
atledreier's Avatar
Is this true balanced or semi, like the 5508?
"Unplugging the signal cable is pretty much the ultimate in component isolation. Now if you removed the AC power and it still did it you should look for the little blond girl saying "they're he-re."
atledreier is offline
post #183 of 286 Old 02-08-2012, 07:13 AM
Kal Rubinson's Avatar
Quoted: 685 Post(s)
Liked: 468
That question still comes up although, when it comes to digital processors, it is somewhat irrelevant. So, what do you mean by semi-balanced?
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #184 of 286 Old 02-10-2012, 12:27 AM
atledreier's Avatar
I take 'semi' balanced to be that the DSP and internal signal path is single ended, but converted to balanced for transmission.
post #185 of 286 Old 02-10-2012, 01:27 AM
gurkey's Avatar
Quoted: 129 Post(s)
Liked: 93
It's the same design as the 5508, nothing changed much.
gurkey is online now
post #186 of 286 Old 02-10-2012, 07:46 AM
runnernorth's Avatar
Do you know if the 5509 uses the same remote network codes as the 5508 ?
kindly
Jan
runnernorth is offline
post #187 of 286 Old 02-10-2012, 07:53 AM
Theresa's Avatar
Liked: 51
Well, there would be the codes for Spotify which the 5508 doesn't have.
Theresa is offline
post #188 of 286 Old 02-10-2012, 08:11 AM
Theresa, you´re right, that i forgot..too bad ...
kindly
Jan
post #189 of 286 Old 02-10-2012, 05:47 PM
mjf_uk's Avatar
I thought this as well, but I think there is far more below the surface than the specs suggest. I can't confirm anything for sure, but I believe that there are a number of changes/upgrades that are not apparent from the specs.
If anyone would like to contest this, then I have on simple thing to say that potentially proves my point. Audyssey Pro support was supposed to be implemented back in November, but 3 months later we are still waiting for confirmation. If things were so similar and so simple, it would not have taken this long.
mjf_uk is offline
post #190 of 286 Old 02-11-2012, 05:48 AM
Hey , I've just updated my 5509 through network,
But now after the update I can't control it with the remote, on the display it says: completed.
Do you know what to do, should I just turn it off and then on with the st.by. button??
kindly
Jan
post #191 of 286 Old 02-11-2012, 05:56 AM
Oh, now I got it, read the manual again, it says, turn off the av controller by pushing the st.by. Button on front panel.
kindly
Jan
post #192 of 286 Old 02-11-2012, 08:34 AM
-after updating the firmware, I listened to Adele Royal Albert hall-DTS-HD MSTR, and I have to say, that the update actually improved the SQ, in my ears anyway, it gave some more clarity, especially to her vocal. ;-)
kindly
Jan
post #193 of 286 Old 02-11-2012, 09:22 AM
gurkey's Avatar
Quoted: 129 Post(s)
Liked: 93
The SM for the 5509 / 3009 / 5009 (actually the same) doesn't show much of a difference concerning the hardware.
post #194 of 286 Old 02-11-2012, 09:24 AM
mjf_uk's Avatar
My post was in reply to the 5509 being the same as the 5508.
mjf_uk is offline
post #195 of 286 Old 02-11-2012, 04:37 PM
Johnla's Avatar
Quoted: 39 Post(s)
Liked: 30
That fact that Audyssey Pro support was has not been enabled any faster, really offers no proof at all. This is something where two entirely separate companies have to sign off on it, Onkyo/Integra and Audyssey. And more than likely, if it was just up to Onlyo/Integra, they would to be probably be prone to just having it enabled right away, while on the other hand you can bet that Audyssey is for sure running a test mule unit through it's paces before they sign off on it. Onkyo/Integra has screwed up a few firmware releases in the past that in a few cases somewhat made Audyssey look to be the one at fault of a new problem that the new firmware created, when they really were not.
Johnla is offline
post #196 of 286 Old 02-12-2012, 07:38 AM
mjf_uk's Avatar
It's not conclusive proof, but the fact that Onkyo haven't been able to supply a firmware to Audyssey that their engineers are happy with, suggests that it's more than just the differences in the video side of things between the 5508 and 5509. If they were so similar, they would be running off almost the same firmware, but they clearly aren't. You have to ask why would there be any difference in the sound processing that would cause problems for Audssey, because as faf as the specs are concerned they are exactly the same in that respect.
mjf_uk is offline
post #197 of 286 Old 02-12-2012, 02:11 PM
gurkey's Avatar
Quoted: 129 Post(s)
Liked: 93
This is no proof or evidence at all.
The 5xx9 units have a newer, different firmware. Even if the hardware would be identical, they still have to reprogramm for including Audyssey Pro. Bugs happen in software all the time even during the slightest changes.
post #198 of 286 Old 02-12-2012, 03:43 PM
mjf_uk's Avatar
I guess I'll just shut the hell up then.
mjf_uk is offline
post #199 of 286 Old 02-12-2012, 11:22 PM
Cam Man's Avatar
Location: Tucson, AZ, Telluride, CO, & Los Angeles,CA, USA
Quoted: 381 Post(s)
Liked: 405
i guess i'll just shut the hell up then.
lol!
Cam Man is offline
post #200 of 286 Old 02-12-2012, 11:28 PM
heja's Avatar
I agree, but can you explain?
heja is offline
post #201 of 286 Old 02-27-2012, 06:41 PM
Joseph MAK's Avatar
I would like to use the 12v trigger to turn on my amplifier. I don't have mono miniplug cable in hand. Can a use a stereo miniplug cable instead?
Joseph MAK is offline
post #202 of 286 Old 02-27-2012, 07:22 PM
Quoted: 685 Post(s)
Liked: 468
All the digital processing is single-ended.
Kal Rubinson
post #203 of 286 Old 03-17-2012, 06:59 AM
mjf_uk's Avatar
There is now a new firmware for the 5509 adding Pro Support and the Audyssey software is available for download.
The TX-NR3009 and TX-NR5009 are also supported, but not the US model.
mjf_uk is offline
post #204 of 286 Old 03-18-2012, 05:10 PM
gurkey's Avatar
Quoted: 129 Post(s)
Liked: 93
Several users, which updated the 5509, 5009 and 3009 yesterday with the latest firmware are reporting a much improved bass and surround sound staging although nothing has been stated by Onkyo about a new Audyssey treatment / revision / changes.
post #205 of 286 Old 03-19-2012, 01:06 PM
mjf_uk's Avatar
Is that just by installing the firmware or did they also run a new calibration?
mjf_uk is offline
post #206 of 286 Old 03-19-2012, 02:38 PM
gurkey's Avatar
Quoted: 129 Post(s)
Liked: 93
I really don't know...
post #207 of 286 Old 03-20-2012, 01:44 AM
gurkey's Avatar
Quoted: 129 Post(s)
Liked: 93
Callback action March 19th 2012:
Onkyo has a callback going on for several AVR models of the year 2011 generation due to sub standard parts. The 1009 and 5009 are among those.
You should check, if the 5009 you have is among those, who have to be serviced. This refers among others to all 5009s units manufactured between November 2011 and January 2012. Check with you local Onkyo distributor, if your unit is affected.
PS.:
Here is the link to the Onkyo UK site.
http://www.uk.onkyo.com/en/articles/...ice-80521.html
post #208 of 286 Old 03-20-2012, 01:10 PM
mjf_uk's Avatar
I'd be insisting on a brand new one. Legally they would have to replace it, not just offer to repair it.
mjf_uk is offline
post #209 of 286 Old 03-20-2012, 03:11 PM
Bill Mac's Avatar
Quoted: 1277 Post(s)
Liked: 1469
I can't believe Onkyo is having further issues with their AVRs. After the issue with the serial cable (correct part?) that some experienced with the xx08 series you would think QC would be ramped up. Too bad as Onkyo makes great AVR/prepros but their reliability issues are really hurting their reputation.
Bill
My SACD collection and HRAudio.net Library, getting larger as my wallet gets smaller ;-).
Emotiva XMC-1, Wyred 4 Sound SX-500s, ST-500, ST-250, Oppo BDP-103/105D, Panasonic TC-P60GT50 plasma, Panamax 5100EX, Salk HT2-TLs, Salk 1801b center, Salk 1801TL (surrounds) and two Rythmik F12SEs.
Bill Mac is online now
post #210 of 286 Old 03-22-2012, 04:13 AM
Webmonkey's Avatar
Quoted: 52 Post(s)
Liked: 31
Any serious reviews of the 5509 out yet? When I try to google I get reviews of 5508 instead :-(
Webmonkey is offline
Onkyo Prsc5509 9 2 Channel 3d Ready Preamplifier , Onkyo Pr Sc5507 Pre Amplifier Home Theater Av Controller Preamp 9 2 Channel New , Marantz Av8801
