"Offical" Yamaha RX-A810 - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 107 Old 12-02-2013, 05:32 AM
kriktsemaj99's Avatar
Quoted: 665 Post(s)
Liked: 383
Originally Posted by trellaine201 View Post
It now says straight on the receiver. I have never seen anything on the receiver. Im not sure why it shows straight etc
But even though its on straight its only showing right/left and sub. 2.1 channels.
Did you hit the INFO button on the remote? Pressing that will change the type of information displayed on the front panel.
In STRAIGHT mode it will show 2.1 for two channel sources, but it will show 5.1 etc. for movies. If you want to use all your speakers even for 2 channel music then STRAIGHT is not what you want, so press SUR. DECODE or MUSIC repeatedly to choose a format.
kriktsemaj99 is offline
post #92 of 107 Old 12-02-2013, 05:55 AM
trellaine201's Avatar
Quoted: 13 Post(s)
Cool. Thanks. I got rid of that display.
And i want whatever is "native" to come through the speakers. I have 5 spaekers and a sub (5.1)
But i am sure fox network shows in 5.1 and the receiver doesnt switch. It stays 2.1 in straight mode.
I will have to see if it switches when my xbox etc is playing.
trellaine201 is offline
post #93 of 107 Old 09-11-2014, 05:07 PM
Quoted: 51 Post(s)
Liked: 1
I just found one of these refurbished, and ordered it. Anything this older model is missing that the newer ones have? It saved me a couple hundred bucks over the RX-830A, which plays FLAC. But I can live without that feature.
NetTechie is offline
post #94 of 107 Old 09-11-2014, 05:51 PM
gce
gce's Avatar
Quoted: 47 Post(s)
The RX-A810 does play FLAC up to 96/24bit.
gce is offline
post #95 of 107 Old 09-11-2014, 05:56 PM
Quoted: 51 Post(s)
Liked: 1
SWEET!! This must be through a firmware update? I did not see a mention of FLAC in the manual or other docs on the Yamaha site.
post #96 of 107 Old 09-11-2014, 07:17 PM
gce
gce's Avatar
Quoted: 47 Post(s)
Page 64 Of your PDF Manual. Its just a short little blurb, but it's there.
gce is offline
post #97 of 107 Old 09-12-2014, 02:09 AM
Quoted: 51 Post(s)
Liked: 1
Yup, it is there. No kidding. So basically this 810 has everything the 840 has pretty much? I didn't see much difference looking at specs.
post #98 of 107 Old 09-12-2014, 06:46 AM
Sven37's Avatar
The two other notable changes that I can think of is the YPAO room correction is different. The 810 doesn't have the reflected sound control features. Also, the 810 is missing the 4k pass-through and upscaling.
Sven37 is offline
post #99 of 107 Old 09-12-2014, 07:25 AM
Quoted: 51 Post(s)
Liked: 1
Thanks for pointing that out, I noticed the YPAO name had something added to it. New version I guess? I think I'm gonna get the newer ones with that, as it may be even better sounding. I canceled my order for the 810.
post #100 of 107 Old 09-24-2014, 09:17 AM
frankie1974's Avatar
Hi m8s can anyone explain this problem i have my rx-810 connected to a samsung 65inch tv 6400 series , now heres what happens i hear a click noise coming from the tv next the rx-810 loses connection for about 3 seconds this means i lose signal to my epson tw9100 then reconnects and all is fine this happens around the 90 min mark give a few minutes , the only way to stop it is to remove the hdmi from the tv to the rx-810 any ideas
thank you
frankie1974 is offline
post #101 of 107 Old 09-26-2014, 07:25 AM
anyone
post #102 of 107 Old 01-02-2015, 04:22 AM
mjlaan's Avatar
Smile Loosing signal on AV810
Hello Franky,
I seem to have the same problem. Sometimes during a movie suddenly my screen goed black for about 3 or 4 seconds, audio
is still there. It looks like the receiver has no video signal or is searching. It's the same when I start a movie or serie, the first
3 seconds there is sound, but no video.
I do have my TV on HDMI out 1, Epson beamer on HDMI2. My TV was out when the problem occured. Or perhaps it was
going on power standby, causing the issue.
I have:
RX AV810
Mede8er MED600X3D
Epson EH-TW7200
I've updated my firmware yesterday, did not have this problem several weeks ago. I will try to update also the firmware of my Mede8er.
Curious if you still have the problem, or know how to solve it.
Kind regards, Marijn
mjlaan is offline
post #103 of 107 Old 05-01-2015, 11:39 AM
briandx's Avatar
Quoted: 99 Post(s)
Liked: 41
Originally Posted by mjlaan View Post
Hello Franky,
I have:
RX AV810
Mede8er MED600X3D
Epson EH-TW7200
FYI... The latest firmware update fixes music streaming issue, such as Pandora.
briandx is offline
post #104 of 107 Old 12-29-2015, 11:28 AM
Liked: 0
HI,
I have the yamaha rx a810.
I cannot fast forward mp3 when I use a usb. Do I do something wrong or this receiver cannot fast forward any song when using usb stick?
thanks a lot!
lakeshorgr is offline
post #105 of 107 Old 01-05-2016, 04:46 AM
saikatbiswas82's Avatar
Quoted: 12 Post(s)
Liked: 2
Hi All,
Could anyone of you please confirm whether Yamaha A810 uses any op-amp in its circuits?
If no, the question ends here.
If yes, what op-amps are they? Can we upgrade the op-amps with discrete ones?
-Thanks,
Saikat
saikatbiswas82 is offline
post #106 of 107 Old 06-17-2016, 10:28 AM
P0wer1's Avatar
Anyone has the previous firmware updates? I can ping the address and it would connect for like 1-3mins and then it lost connection. Would like to restore to previous firmware. I currently have version 1.76
P0wer1 is offline
post #107 of 107 Old 08-15-2017, 05:20 AM
xr3tf's Avatar
No sound
I purchased a used A810. Upon testing it, I found that everything seems perfectly fine but there is no sound what so ever - not on speakers, headphones or even pre-amp outputs.
The tuner seems to tune and al other functionality seems in order. I cannot however get the display to show the speakers that are supposed to be selected in the various sound modes.
Have done factory reset, no joy.
Have run the YPAO setup - all the speakers show on the display at the start, but it then fails with E-10 - Internal Error.
Have I missed something? I have not yet done a firmware update.
If not, where could I source some fault finding documentation for this unit?
xr3tf is offline
Yamaha Rx A810bl Receiver
