Receiver under $300 (jamo 606 & Bic f12) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 08-20-2011, 03:57 PM - Thread Starter
Sucio's Avatar
What would be a good receiver for under $300.00? I currently have the jamo 606 and Bic f12 sub.
I was looking at the refurbished 1911 from macmall.
http://www.macmall.com/p/Denon-Home-...71~pdp.gidibbj
I know it's 7.1 but maybe in the near future i'll upgrade from 5.1 to 7.1
Denon 590
http://www.amazon.com/Denon-AVR590-5...3876488&sr=8-3
onkyo 509
http://www.abt.com/product/52627/Onk...mpaign=froogle
Sucio is offline
post #2 of 14 Old 08-20-2011, 06:26 PM
bommai's Avatar
Quoted: 195 Post(s)
Liked: 49
Have you looked in craigslist?
bommai is offline
post #3 of 14 Old 08-20-2011, 06:53 PM
der_kommissar's Avatar
What about Sony STR-DH820 for $280 at amazon?
http://www.amazon.com/Sony-STRDH820-...3887988&sr=8-1
der_kommissar is offline
post #4 of 14 Old 08-20-2011, 07:31 PM - Thread Starter
Sucio's Avatar
I haven't looked in craigslist, is there a certain model i should get?
Sucio is offline
post #5 of 14 Old 08-20-2011, 08:22 PM
bladerunner6's Avatar
Quoted: 20 Post(s)
Liked: 59
Denon 590
onkyo 509
The Onkyo is way less expensive at Newegg.
bladerunner6 is offline
post #6 of 14 Old 08-20-2011, 08:36 PM
trumbull247's Avatar
You should get the receiver that has the features you need.
Do you want/need...
2nd zone?
Networking?
Upconversion?
Upscaling?
macro remote?
Do you have...
Wii?
VCR?
Turntable?
Ipod?
Android?
NAS?
HTPC?
trumbull247 is offline
post #7 of 14 Old 08-20-2011, 11:52 PM - Thread Starter
Sucio's Avatar
Do you want/need...
2nd zone? Yes
Networking?Yes
Upconversion?Doesn't matter
Upscaling?doesnt matter
macro remote? Dont know
Do you have...
Wii? No, I have a PS3
VCR?no
Turntable?no
Ipod?yes
Android?yes
NAS?
HTPC?yes
I'm looking for a good beginner receiver... It'll be used for 50/50 music/movies.
Sucio is offline
post #8 of 14 Old 08-21-2011, 12:07 AM
Then for you, I would get the NR509.
By the way "macro remote"(for future reference) is when a remote has buttons to fire off a series of commands.
Just for "giggles", look up the NR709. Go to Amazon and look at the picture of the remote. The second row of buttons(labeled "activities") are the "macros"...
What it means(like I have mine set)...when you press "My TV" it fires off....
1. receiver
2. power
3. Cable/Sat
4. power
5 TV power
Which with the NR509 remote...you'll push those 5 buttons individually(and yes, that remote will control your Cable/Sat box, BD player and whatever else)
You will need to use an external amp for the 2nd zone(computer speakers...another 2 channel stereo...)
post #9 of 14 Old 08-21-2011, 04:20 AM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
I would get the Denon 1611 over the older Denon 590.
http://www.vanns.com/shop/servlet/it..._c=site_search
But if you want networking the Onkyo 509 is your best bet.
http://www.amazon.com/Onkyo-TX-NR509...3921992&sr=8-1
Afro GT
afrogt is offline
post #10 of 14 Old 08-21-2011, 07:36 AM
murph101's Avatar
Quoted: 14 Post(s)
I say the 509...if it has the features you want. Amazon a bit cheaper than Abt right now ($253.09).
murph101 is offline
post #11 of 14 Old 08-21-2011, 10:03 AM - Thread Starter
Sucio's Avatar
Thank you Trumbull, I have a harmony one control, which does the same thing too.
Wouldn't the 1911 be a better option than the 1611?
I have a lot of research to do...
Sucio is offline
post #12 of 14 Old 08-21-2011, 10:07 AM
afrogt's Avatar
Liked: 757
Onkyo 1911 adds a USB input for ipod and a video scaler which you said you don't
need. If you can get it under your $300 limit then sure go ahead get the 1911. Does it come with a warranty or do you have to buy one seperately? The 1611 comes with a 2 year warranty.
but it still doesn't offer networking if that's important to you.
Afro GT
afrogt is offline
post #13 of 14 Old 08-24-2011, 12:15 AM - Thread Starter
Sucio's Avatar
So i narrowed it down to the Denon 1911 or the Yamaha A700. What do you guys recommend? Both can be had for under 300.
Thank you guys!
Sucio is offline
post #14 of 14 Old 08-24-2011, 03:19 AM
jdsmoothie's Avatar
Quoted: 12154 Post(s)
Liked: 5535
Neither of those models features "networking." You would need to get the newer Denon 1912 or Yamaha A710 for networking.
jdsmoothie is offline
