The "official" Yamaha AVENTAGE RX-A710/810/1010/2010/3010 thread - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 26Likes
post #61 of 3135 Old 10-30-2011, 09:32 AM
DeanRS57's Avatar
Originally Posted by iraweiss View Post
Question for RX-A2010 or 3010 owners.
I have a Salamander Archetype system and the shelves are 16" deep. I'm trying to see if the receivers will fit on the shelf. The shelves are an open design. http://www.salamanderdesigns.com/products/av.jsp
What is the distance between the front of the front foot and the back of the rear foot of either of these receivers?
It's a good thing you are planning... I just went with the receiver I liked most and paid no attention to the size. Had to get a little creative with placement last night =).
DeanRS57 is offline
post #62 of 3135 Old 10-30-2011, 08:14 PM
shelly40's Avatar
Quoted: 143 Post(s)
Liked: 53
Question about the 2010.......
Is the crossover freqs global, or can they be set per channel ?
And if they can be set per channel, what is the range of adjustment ?
Sorry if this is in the manual, but if it is, I couldn't find it .....
Shelly
shelly40 is online now
post #63 of 3135 Old 10-30-2011, 08:35 PM
MTBDan's Avatar
I'm a little confused - does the A3010 have different components/circuit design than the V3071???
As far as I can see on the Yamaha site they are the same other than some mechanical build issues, and here in Australia a 4yrs as opposed to 12 month warranty.
I had almost bought a A3010 when got caught up on the fact that for potentially $500 less I can pick up the V3071.
Anyone have any info on this??
MTBDan is offline
post #64 of 3135 Old 10-30-2011, 11:16 PM
DeanRS57's Avatar
Shelly
Can be set per channel, F/C/Surr/Back Surr, etc.
40, 60, 80, 90, 100, 110, 120, 160
Each sub can have its level/distance set independently.
DeanRS57 is offline
post #65 of 3135 Old 10-31-2011, 03:43 AM
nussman's Avatar
My A3010 seems to have problems with hdmi blacklevel.
PC output 0-255 (hdmi) => Yamaha A3010 => output 16-235
I dont find an option to change this behavior.
Can anybody confirm this?
nussman is offline
post #66 of 3135 Old 10-31-2011, 09:48 AM
kriktsemaj99's Avatar
Quoted: 647 Post(s)
Liked: 366
Can you describe the test you did and how you can tell it's the 3010 and not the display that's clipping the levels? Anything is possible, but after the stink over video clipping a few years back, I thought Yamaha would be careful not to do that anymore.
kriktsemaj99 is online now
post #67 of 3135 Old 10-31-2011, 11:23 AM
nussman's Avatar
First test (PC output 0-255):
On my Samsung TV you have to choose between hdmi blacklevel normal (16-235) and low (0-255).
Samsung hdmi blacklevel "low" => clipping
Samsung hdmi blacklevel "normal" => no clipping
Second test (Samsung hdmi blacklevel "normal"):
PC output 0-255 and 16-235 makes no difference at all.
So I guess the Yamaha does something.
nussman is offline
post #68 of 3135 Old 10-31-2011, 02:01 PM
Quoted: 647 Post(s)
Liked: 366
You don't say what test pattern you are sending from the PC, and how you can tell there's clipping. But I always found it easier to test with a real DVD or Blu-ray player that sends known levels. PC levels can be affected by graphic card settings.
post #69 of 3135 Old 10-31-2011, 02:36 PM
nussman's Avatar
That's not the problem.
PC or Video levels can be set easly by the graphic card driver (I am using ati HD5670 card).
In my tests i used several test dvds, normal dvds and blurays.
nussman is offline
post #70 of 3135 Old 11-01-2011, 12:18 PM
dukedallas2005's Avatar
Ear-gasm is what I call listening to the Aventage 3010 at level -15 cranking out 110Db's surround mode = 9ch Stereo with a 9.1 Klipsch setup...Listen to: Beat Service feat Emma Lock - Not Out...
Make sure wife and kids are away... and all surrounding loose hosehold items are taped down.
Amazing! This is why we spend all our hard earned $$$ :-)
dukedallas2005 is offline
post #71 of 3135 Old 11-01-2011, 08:36 PM
lakinsdad's Avatar
Anyone here have an hr24 Or any DVR. From directv?
I'm getting occasional audio drop outs. I have a 2010. Only notice it on the DVR nothing else.
lakinsdad is offline
post #72 of 3135 Old 11-02-2011, 05:54 AM
rdgrimes's Avatar
Quoted: 2166 Post(s)
Liked: 1493
Not unexpected with DTV DVRs, especially when playing recorded content. You might reduce it by using optical for audio instead of HDMI. This has been an issue with DTV for as long as I can remember, and they always blame it on the channel provider. FWIW, Dish has the same issues.
rdgrimes is online now
post #73 of 3135 Old 11-02-2011, 05:45 PM
lakinsdad's Avatar
Thanks .
Hey, Does anyone know when "Receiver Manger" will be updated to use on the New Aventage AVR's?
post #74 of 3135 Old 11-02-2011, 09:02 PM
moneypitt's Avatar
With the party mode in the RX-A810 for zone 2 are the digital inputs sent to zone 2 or is it just the analog like in the RX-A710?
Moneypitt
moneypitt is offline
post #75 of 3135 Old 11-03-2011, 07:47 AM
jtenn's Avatar
Quoted: 39 Post(s)
Originally Posted by Linejudgemick View Post
I just ordered a 710 to replace an H/K 254 that the HDMI died. I hope this sounds as sweet as the H/K did, but I wasn't going to spring for another and worry about it going south in a couple years again. Has anyone played both and have an opinion on the SQ difference between Yamaha and Harman Kardon?
Have you received your 710 yet? If so what do you think of it compared to the 254?
jtenn is offline
post #76 of 3135 Old 11-03-2011, 11:51 AM
Quoted: 647 Post(s)
Liked: 366
I don't know, but I think someone got the x67 version simply by asking Yamaha support. It's worth a try.
post #77 of 3135 Old 11-04-2011, 09:36 AM
moneypitt's Avatar
Moneypitt
Anyone with a RX-A that has Party Mode help me out here.
Moneypitt
post #78 of 3135 Old 11-04-2011, 10:15 AM
Quoted: 647 Post(s)
Liked: 366
Party Mode routes the main zone output (after the DACs) to the other zones, so it works with any input (analog or digital), but of course it means zone 2 can only play the same source as the main zone.
post #79 of 3135 Old 11-04-2011, 10:16 AM
chuck211273's Avatar
Tried the 3067 Version available here in Germany, doesn´t work with the 3010 for me. It simply doesn´t find the receiver.
Bye
Lars
chuck211273 is offline
post #80 of 3135 Old 11-04-2011, 12:04 PM
moneypitt's Avatar
Thank you, looks like I need to sell the 710 and get the 810
post #81 of 3135 Old 11-04-2011, 12:23 PM
Quoted: 647 Post(s)
Liked: 366
I didn't expect the x67 verison to work. What I really meant was it's worth a try asking Yamaha if they can give you the 3010 version. Yamaha support in some countries would probably be more likely to do that that others.
post #82 of 3135 Old 11-04-2011, 06:56 PM
awake33's Avatar
I too am looking for Receiver Manager for the RX-A2010.
For anyone interested, I finally got my hands on the RS232/IP/IR codes/commands, excel sheets, and examples for the YNC/YNCA protocols. Going to use DemoPad to create a home automation setup that integrates them. Also have a link that includes a location of not only these files, but many other models from Yamaha as well as codes for various models of 12 other brands.
PM me if you want it.
awake33 is offline
post #83 of 3135 Old 11-06-2011, 06:10 AM
rana_kirti's Avatar
Anyone tried out the Presence Speakers...?
1. In what ways does it add to the movie experience ?
2. Is it useful for all types of movies or only particular genres or particular types of scenes ?
Rana
a few funny stories from my life ------->http://www.kirtirana.blogspot.com
rana_kirti is offline
post #84 of 3135 Old 11-06-2011, 06:57 PM
glabate's Avatar
I bought the Rx-V750 about 7 years ago and it has been great. Never a problem. I am looking to upgrade my home theater system, and am looking at the RX-A700 or 710. Any idea as to how they compare? It is worth the cost to upgrade?
glabate is offline
post #85 of 3135 Old 11-06-2011, 10:27 PM
jazzmaster221's Avatar
they in large the field of sound I must say very discreetly but it's a pleasing addition to my HOME theater audio experience....so overwhelming that I now look for movies with a 5 star audio rating ...going back and watching those from my library again adding a new perspective on 7.1, true hd and dts hd.. instead of just looking for the top PQ
jazzmaster221 is offline
post #86 of 3135 Old 11-07-2011, 01:06 PM
sjwinick's Avatar
has anyone come across receiver manager for the 3010?
sjwinick is offline
post #87 of 3135 Old 11-07-2011, 05:45 PM
muohio's Avatar
Subscribing to thread. Owned a RX-V2700 for 6 years now and looking forward to the 2010 which should arrive any day now.
muohio is offline
post #88 of 3135 Old 11-07-2011, 05:51 PM
awake33's Avatar
Your going to love it. Mine replaced an Onkyo 605, and blows it away musically. It sounds better for movies too, but the difference for music really surprised me.
awake33 is offline
post #89 of 3135 Old 11-07-2011, 05:55 PM
muohio's Avatar
I can only imagine that Yamaha has made improvements in sound quality over the years. The V2700 was pretty much the same position in the model line and nearly $200 lower in price as the current 2010. Amazing how they can pack more features and better components in a unit and charge less six years later. If only cars worked the same way.
muohio is offline
post #90 of 3135 Old 11-08-2011, 02:22 AM
Blackrose666's Avatar
Here is a link to the receiver manager software for the following Aus models:
RX-V1071
RX-V2071
RX-V3071
RX-A1010
RX-A2010
RX-A3010
http://www.mediafire.com/?zv3h04kvdzi43d4
Please share on other forums etc, it helps keep the link alive.
http://forums.whirlpool.net.au/forum...m?t=1772748#r6
Blackrose666 is offline
Receivers Amplifiers , Yamaha Rx A1010bl Receiver , Yamaha Rx A2010 Receiver , Yamaha Rx A3010 Receiver , Yamaha Rx A710bl Receiver , Yamaha Rx A810bl Receiver
