The "official" Yamaha AVENTAGE RX-A710/810/1010/2010/3010 thread - Page 99 - AVS | Home Theater Discussions And Reviews
post #2941 of 2962 Old 11-12-2014, 09:06 AM
billmich's Avatar
Quoted: 134 Post(s)
Liked: 40
Originally Posted by John Weston View Post
I can no longer log into Rhapsody from my RX-A2010... Rhapsody support tells me they made a change and that Yamaha has to send out a firmware update to fix it... Will Yamaha even update this firmware considering its age? I am using ver 1.37 and everything else is working fine. Anyone else having this issue??
Looking at other threads, ...the XX30 models got the update for siriusXM/Rhapsody was available
billmich is offline
post #2942 of 2962 Old 11-12-2014, 09:10 AM
John Weston's Avatar
Thats my issue though...will they send out an update on a 3 year old model??? or am I just screwed on using Rhapsody???
John Weston is offline
post #2943 of 2962 Old 11-12-2014, 09:20 AM
billmich's Avatar
Quoted: 134 Post(s)
Liked: 40
can you use it as an app on another device and then thru the Yamaha?
Have you called Yamaha customer service about this?
They are actually one of THE BEST customer service places you will ever encounter
billmich is offline
post #2944 of 2962 Old 11-13-2014, 08:53 AM
nathan_h's Avatar
Quoted: 196 Post(s)
Liked: 111
If Yamaha doesn't update the firmware, I'm guessing the cheapest workaround is something like a Chromecast (if it supports Rhapsody) for $35 or less.
____________________
Build thread & current gear: "Nathan's Theater in Search of....".
nathan_h is offline
post #2945 of 2962 Old 11-14-2014, 12:27 AM
Ok...Yamaha did reply to my e-mail in just over 24 hours....they gave me the instructions to force the 2010 into an update mode and it downloaded new firmware ver.1.60!! Rhapsody is back up!!! well done Yamaha ...This is a 2011 model and my fear was that they would no longer provide updates....Solid equipment AND good customer service??? thank you Yamaha!!!
nathan_h likes this.
post #2946 of 2962 Old 11-14-2014, 08:20 AM
nathan_h's Avatar
Quoted: 196 Post(s)
Liked: 111
What were the instructions for force the firmware update?
billmich likes this.
nathan_h is offline
post #2947 of 2962 Old 11-14-2014, 12:06 PM
billmich's Avatar
Quoted: 134 Post(s)
Liked: 40
Yes, please share those instruction!!!
does this update do anything else for the unit?
billmich is offline
post #2948 of 2962 Old 11-24-2014, 11:35 PM
bmerk2010's Avatar
update 1.60
http://download.yamaha.com/search/de...298&1416900866
bmerk2010 is offline
post #2949 of 2962 Old 11-25-2014, 09:12 AM
billmich's Avatar
Quoted: 134 Post(s)
Liked: 40
Originally Posted by bmerk2010 View Post
my 3010 had the update automatically ready for me
already performed it too
billmich is offline
post #2950 of 2962 Old 03-03-2015, 10:38 AM
JL Ponty's Avatar
Hi guys.
Just got an used Aventage 2010 and i have a problem. Music and movies are excellent sounding, the classic radio sound is poor/metalic with no bass. Even at direct/pure audio.
I have searched everything, i can't find anything.
My previous Yamaha RXV 2700 tuner was excellent.
Any ideas ? Thanks
JL Ponty is offline
post #2951 of 2962 Old 03-04-2015, 02:07 PM
RBrock's Avatar
Originally Posted by JL Ponty View Post
Hi guys.
Any ideas ? Thanks
I have some ideas, but I need some more information to help troubleshoot.
Are you using the same antenna you used with the RXV 2700 ? If so, is it in the same location? Do you have the same problem on both AM and FM stations? Do you have any HD radio stations near you? Is the problem only on tuner or is it also on net radio?
My personal preference is to use the 7-channel stereo mode on my 1010 for radio listening.
RBrock is online now
post #2952 of 2962 Old 03-05-2015, 11:39 AM
JL Ponty's Avatar
Hi and thanks for your time.
I'm using the 2010's antenna. Same location, i have checked everything. I'm only listening to FM and i have no HD stations in my country. And i haven't cheched with net radio, i haven't connected yet the 2010.
JL Ponty is offline
post #2953 of 2962 Old 03-05-2015, 01:04 PM
RBrock's Avatar
The 2010 FM tuner specifications show it to be slightly less sensitive than the 2700, but that small difference should not be causing the poor sound. If you are using an indoor antenna try adjusting the position to see if it increases the signal level and improves the sound. Even a few cm change in location or a few degrees in rotation can make a huge difference.
If you can connect the 2010 to the internet and can find an FM station that also streams its program over the internet you could compare the sound of the same program between the two sources.
The DSP in the Yamaha receivers is pretty good, in my opinion. Using the surround enhancer or multi-channel stereo options seems to me to give a fuller sound with more bass. Of course part of that is that it simply sounds louder since you have more amplifier channels active.
post #2954 of 2962 Old 03-05-2015, 08:08 PM
Sven37's Avatar
If the SNR is just bad enough, it might give you that sound. My thought is you might have a bad antenna. I don't have the 2010, but my guess is that its a wire, right? Could be a break in it, or a bad connection internally on your 2010. See if you have another antenna that can plug in to the connection and see if that helps....
Sven37 is offline
post #2955 of 2962 Old 03-06-2015, 05:04 AM
billmich's Avatar
Quoted: 134 Post(s)
Liked: 40
Is the radio sounding "muddy"?
billmich is offline
post #2956 of 2962 Old 03-06-2015, 06:56 AM
JL Ponty's Avatar
Yes, close to that. But ONLY the sound from the tuner. Stereo and movies are great.
JL Ponty is offline
post #2957 of 2962 Old 03-06-2015, 08:12 AM
billmich's Avatar
Quoted: 134 Post(s)
Liked: 40
i had this happen to me on my 3010, only on the FM and HD tuners......(no other source)
the only recourse was to do a master reset (you really should get the receiver manager on laptop/desktop computer and save your setting first)
after the reset you can then download all your setting back to the unit.
I have had to do this reset about 5 times in the past 3 years, i don't listen to the radio all that much, so maybe that count would be higher if i did.
for me, it's not worth tearing everything apart and sending in, just for this....
hopefully I have provided you some insight
billmich is offline
post #2958 of 2962 Old 03-06-2015, 08:13 AM
billmich's Avatar
Quoted: 134 Post(s)
Liked: 40
Best way for me to describe the situation I was having is that it sounded "overmodulated"
billmich is offline
post #2959 of 2962 Old 04-25-2015, 07:51 PM
billmich's Avatar
Quoted: 134 Post(s)
Liked: 40
How can I remove net radio stations from my bookmarks lists?
billmich is offline
post #2960 of 2962 Old 05-02-2015, 12:41 PM
RBrock's Avatar
Even though the manual suggests that you can delete bookmarks by selecting the station on the onscreen display and selecting bookmark off, that doesn't work for me. The only way I have found that works is to use your vtuner account on the web, http://yradio.vtuner.com/
The website allows you to search for stations and add them to your bookmarks. Deleting a bookmark is a simple one click process. You can even set up multiple groups of bookmarks or podcasts. To me it seems much easier to manage bookmarks through the web than on the receiver itself. Note that the first time you use the website you will need to enter the MAC address of the receiver to set up your account. That can be found in the network screen in the information menu of the receiver.
The web help is pretty skimpy so ask questions here.
post #2961 of 2962 Unread Today, 09:29 AM
billmich's Avatar
Quoted: 134 Post(s)
Liked: 40
I am going to call customer service and have then guide me; they are usually pretty solid on these matters
I cant log into that Vtuner website; and I don't see where you create the account
billmich is offline
post #2962 of 2962 Unread Today, 05:41 PM
RBrock's Avatar
The first page of the vtuner website has a box to enter the MAC address. Do not enter an email address or password yet. If you do not know how to find the MAC address click on the bold (more info about the ID #) That will walk you through the process. Enter the MAC address and click on the adjacent arrow. You should be able to create your account on the next page.
Yamaha Rx A710bl Receiver , Yamaha Rx A810bl Receiver , Yamaha Rx A1010bl Receiver , Yamaha Rx A2010 Receiver , Yamaha Rx A3010 Receiver , Receivers Amplifiers
Gear in this thread - A2010 by PriceGrabber.com
