extender for my integra dtr-6.8 - AVS Forum | Home Theater Discussions And Reviews
Old 08-31-2011, 12:52 PM - Thread Starter
keegstr's Avatar
HI all. I have a goal of moving all of my equipment behind the wall my TV is mounted on to reduce clutter. I've been able to do this with everything using bluetooth except my receiver. The problem is that the remote is IR and it doesn't work behind the wall.
By behind the wall, i really mean in the bedroom closet, which is on the other side of the tv wall. It's maybe 10 feet away from the couch, around a corner.
The manual for the receiver says the following:
"Bi-directional Ethernet & RS-232 Port for 3rd Party Control Systems (Device Discovery, E-control, etc.)"
I think this is directly related to what i want to do. In my head, I'm picturing a mini-receiver, which displays the same info as the main receiver display (volume, etc), and has a bluetooth / IR port on it, which connects to the receiver itself.
Is there any piece of technology that will let me do what i want?
tldr: does a bluetooth or IR extension/addon exist for this receiver?
keegstr is offline
Old 08-31-2011, 12:59 PM
jdsmoothie's Avatar
Quoted: 12180 Post(s)
Liked: 5548
You should be able to use any number of IR extender kits to extend the use of the AVR's stock IR remote. They generally come with emitters that sit over the IR sensor on the front panel display of the AVR or some come with 3.5mm plugs that can plug straight in to the IR input on the back of the AVR.
jdsmoothie is offline
Old 08-31-2011, 01:07 PM - Thread Starter
keegstr's Avatar
Would something as simple as this work?
Next Generation 3-EYE Infrared Remote Control Extender Emitter Cable
on amazon (avs wont let me post links yet)
I see there is an IR port on the back of the receiver. The only downfall to that is I can't see the current input selected and the volume, both of which are useful.
The ability to control my receiver from an iphone is very alluring, if that is possible money would not be much of an issue to make that happen.
keegstr is offline
Old 08-31-2011, 01:10 PM
jdsmoothie's Avatar
Liked: 5548
If the Integra doesn't have an OSD/GUI, then you would either need a bi-directional remote such as you quoted in your first post or you may be able to use either the iPhone app (OnkoTron) or Android REMOTE app (OnkyTroller).
Old 08-31-2011, 01:14 PM - Thread Starter
keegstr's Avatar
If the Integra doesn't have an OSD/GUI, then you would either need a bi-directional remote such as you quoted in your first post or you may be able to use either an iPhone or Android REMOTE app.
Can you recommend a remote? Searching for 'bi-directional remote' on amazon only returns keyless car remotes.
keegstr is offline
Old 08-31-2011, 01:26 PM
jdsmoothie's Avatar
Liked: 5548
No, but I can recommend a site to do some research --> http://www.remotecentral.com/, although I would check out the iPhone REMOTE app as that can be used anywhere in the house where there is access to your home network.
Old 08-31-2011, 08:53 PM
Knucklehead90's Avatar
Quoted: 387 Post(s)
Liked: 334
Try this.
I've used one for years to control the satellite box in the living room from the bedroom - works great and it uses radio frequencies to repeat IR signals past walls. It will do exactly what you want that any remote is capable of doing. It will control any of your components that are within range of the receiver/transmitter unit.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
Old 08-31-2011, 09:49 PM
WilliamZX11's Avatar
Quoted: 25 Post(s)
These work great too. So far mine have lasted for over 20 years:
http://www.amazon.com/X10-POWERMID-C...ref=pd_sim_e_3
WilliamZX11 is offline
Old 09-01-2011, 04:48 AM
jdsmoothie's Avatar
Liked: 5548
Note that in both of the above cases, Amazon reviews in recent years indicate both products are hit or miss (mostly miss though).
Old 10-09-2011, 10:26 AM
Quoted: 25 Post(s)
4 out of 5 stars is "mostly miss"? Looks like 80% satisfaction rate to me, actually a little higher.
Old 10-09-2011, 10:36 AM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
Xantech and Niles make the pro quality stuff but way more expensive than the mini pyramids. I bought the xantech kit and plug directly into receiver. Comes with 4 sticky ir for the other equipment.
http://www.xantech.com/Infrared/Infr...TIrKits/HL25K/
http://www.nilesaudio.com/product.ph...T2&recordID=IR Remote Control Anywhere Kits&categoryID=Ingenious IR&catcdID=5&prdcdID=FG01586
kikkenit2 is offline
