Integra DHC-80.3 - Page 146 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #4351 of 4377 Old 05-09-2015, 10:08 PM
NorthSky's Avatar
Location: Canada - West Island: Vancouver, South Direction: Go East, dts:x Films: Under the Skin, 3D, Birdman, X_Machina, The Zero Theorem, Interstellar
Quoted: 4902 Post(s)
Liked: 2026
Originally Posted by spike9876 View Post
I do not see Pure Audio in my Integra 80.3, but I do see it in my OPPO. These days, I don't use OPPO... For music I mainly use JRiver and Spotify on my HTPC.... I should try to use OPPO, but I just find it too clunky vs using my HTPC. But I did find a listening mode 'Direct' in 80.3, using this mode... audio is only directed to front speakers... But found that if I have a speaker cross over... The cross over stays in place.... which means I lose any audio below cross over. Do you set your speakers full range ? Or do you set a cross over ? If you have a cross over... are you sure you are not missing audio below your cross over ?
Seems like in order to use listening mode named 'Direct' I would have to set my fronts to full band... but what happens when I watch movies... ? What cross over would it use ? Would there even be a cross over ?
Edit: Using this 'Pure Mode' Would be ideal... Is this using 80.3 ? If so, where do you select this ?
Another Edit: Doing additional search... Pure Audio seems to be 'Direct'.... and I re-tested... If I have a cross over... It does not appear to impact sound. I previously thought that audio below cross over would be eliminated... but it doesn't appear to be that way... So If I wanted to use my subs for movies.. and only mains for music... 'Direct' is the way to go...
Thanks for confirming that If I wanted to remove my subs (which I highly doubt), I don't have to worry about losing LFE signal.
Sorry, it's the Direct mode.
* Page 53: Note => Set the subwoofer to No and the front setting (main L & R speakers) is fixed @ Full Band. ...For Music (digital).
- MOVIES: But best to select Yes for the subwoofer...for movies...digital.
** Page 58: Direct --- Analog --- Subwoofer Off / On - MUSIC 2-channel stereo listening.
- Sound Program Edit
- Listening Mode
- Subwoofer
______
1. Set all your speakers with a crossover. And Yes for the subwoofer. ...For movies.
2. For stereo music listening toggle between digital and analog (select analog), and with that mode you have no Sub because that's what you have selected for the "Direct" listening mode when in analog domain with the Sub selected @ Off. ...Then your front main L & R speakers are now Full Band (full range).
Or, you can also select in the menu (as per page 53), Subwoofer to No, but it is annoying (for digital).
No, you want the analog connection for music listening, and for full range stereo music, without the sub,
just select No for the Analog Direct mode (page 58).
NorthSky is offline
post #4352 of 4377 Old 05-09-2015, 10:14 PM
spike9876's Avatar
Quoted: 26 Post(s)
- Listening Mode
- Subwoofer
You threw me off... Then after doing some additional research... figured you meant 'Direct' mode.
Thanks again!!
Fronts: B&W CM8
Center: B&W CM Center
Surround: B&W CM1
JL Audio F112
Integra DHC-80.3
Emotiva XPA-5
OPPO 93
HTPC
spike9876 is offline
post #4353 of 4377 Old 05-09-2015, 11:24 PM
NorthSky's Avatar
Liked: 2026
Direct, Pure Audio, ...is the same in Integra parlance. ...Verisimilitude.
NorthSky is offline
post #4354 of 4377 Old 05-10-2015, 10:57 AM
mlknez's Avatar
Quoted: 79 Post(s)
Liked: 25
Thanks again!!
I have speakers that are effective down to 22hz and I still have them set as small. What kind of speakers are you getting?
mlknez is offline
post #4355 of 4377 Old 05-10-2015, 11:18 AM
spike9876's Avatar
Quoted: 26 Post(s)
I'm getting Sanders Sound M10d. They are hybrid electro stats With cone woofer. According to his specs, they go down to 20Hz... But he recomend's no to use subs because his woofer better integrates with electro stats....
post #4356 of 4377 Old 05-10-2015, 01:42 PM
mlknez's Avatar
Quoted: 79 Post(s)
Liked: 25
I heard them at AXPONA. They were nice sounding in his setup.
mlknez is offline
post #4357 of 4377 Old 05-10-2015, 02:05 PM
NorthSky's Avatar
Liked: 2026
Use Direct mode: Analog | Subwoofer Off ...For 2-channel stereo music listening.
* With movies, all your bass management will work accordingly to your speaker's settings, automatically, with your two subs engaged, and all your speakers crossed over @ wherever you selected them.
It's a perfect world, between Music & Movies.
NorthSky is offline
post #4358 of 4377 Old 05-10-2015, 04:25 PM
spike9876's Avatar
Quoted: 26 Post(s)
Yes, Subwoofer is set to No in Direct mode... I don't hear my subs when in Direct mode...
Although I will try his suggestion of attempting to eliminate my subs... My gut will be that I will use Direct for music and will leave my subs and set a cross over for movies.
BTW, In Direct mode... does it apply Audyssey ?
Fronts: B&W CM8
Surround: B&W CM1
JL Audio F112
Integra DHC-80.3
Emotiva XPA-5
OPPO 93
HTPC
post #4359 of 4377 Old 05-10-2015, 05:39 PM
NorthSky's Avatar
Liked: 2026
- In Direct mode there is No Audyssey EQ [From both Analog and Digital inputs]
- In Stereo mode there is Yes Audyssey EQ [Analog inputs included - Through A/D & D/A processing]
- From the Multichannel Analog Input there is No Audyssey EQ.
* Note: Most people prefer the benefit of Audyssey MultEQ XT32 (engaged) over no Audyssey @ all (Direct mode - disengaged).
Experiment, and pick your preferred auditory music listening quality performance. No one room's acoustics is equal to another one, same for people's ears. ...It all depends.
NorthSky is offline
post #4360 of 4377 Old 05-10-2015, 06:46 PM
spike9876's Avatar
Quoted: 26 Post(s)
That's why I asked... Because I noticed a difference in direct vs stereo... Besides subs not being included... Music definitely becomes more alive in stereo so I prefer Audyssey engaged...
One thing about speakers I'm getting... They are powered speakers and will have ability to do some EQ below 500Hz... Will be using a Behringer DCX2496 and will be able to apply EQ... Hopefully this will help in not applying Audyssey while in Direct mode.
Edit: BTW, I was able to verify that if I set no subs, LFE goes to my main L&R speakers... Remembered I had an audio calibration disk... and disk sends a .1 audio signal...
Fronts: B&W CM8
Surround: B&W CM1
JL Audio F112
Integra DHC-80.3
Emotiva XPA-5
OPPO 93
HTPC
post #4361 of 4377 Old 05-10-2015, 08:05 PM
NorthSky's Avatar
Liked: 2026
I also usually select the Stereo mode when listening to two-channel music recordings (with Audyssey engaged; it adds more "presence").
...Using the analog stereo connection, as well the digital coaxial one.
When selecting No for the Subwoofer from the Speaker's Menu settings; it automatically sets your two main front Left and Right speakers to Full Band.
And the bass from the other speakers selected as Small goes to them, plus the LFE (.1 channel) content, when present in some hybrid multichannel SACD music recordings.
...And every other mediums; Blu-ray, DVD, ...of the two flavors...Video and Audio, and everything else...streaming, downloading, music/movie files, etc.
...Hi-res, lo-res, tra-la-la, even All Channel Stereo from the Phono input.
NorthSky is offline
post #4362 of 4377 Old 05-20-2015, 12:25 PM
hidefpaul's Avatar
Quoted: 101 Post(s)
Liked: 73
I have posted this on the Integra/Onkyo warranty extension thread but I thought I would ask you guys here.
Does anyone know the answer to the question in "red" below.
I have owned the Integra DHC 80.3 pre amp since March 2012. The unit has performed perfectly in an open cabinet, with plenty of air circulation and I even added a fan that sits on top of the unit which blows air away from the top. The unit is always cool to the touch.
On Saturday, upon turning the unit on, I noticed it was taking longer than usual for audio/video to display on the screen. I kept seeing the unit's display showing "HDMI STAR UP" and it remained this way for about 9-12 seconds before it displays proper audio & video. After this long "boot up", let's call it that for now, everything works perfectly as usual.
Now, I have read enough to know that this may be a inevitable HDMI board failure, that has plagued many Onkyo/Integra units and owners here on AVS.
I do not want to do a factory reset (PITA) having to recalibrate set up everything again. Unless, someone knows if it is possible to save the settings, do the factory reset, and then re-apply the saved settings. Can someone confirm this??
I just wanted your thoughts on how to proceed, should I get a repair/work order started with Integra in case the unit finally dies or should I wait and try the reset first.
5.1 Home Theatre
Pioneer 60" Kuro
Integra DHC 80.3 Pre Amp
Parasound Halo A51 5 Ch Amp
Speakers : Elac's FS-247's (L,C,R SR, SL)
Sub: Velodyne SPLR1000
hidefpaul is offline
post #4363 of 4377 Old 05-20-2015, 01:19 PM
NorthSky's Avatar
Liked: 2026
HDMI Hand-Shake Issue
Read ^ the entire thread (only 22 posts), and in particular post number 13 and also the other posts following it.
♦♦ Perform a Firmware Update ...if available...in case you don't have the latest one.
NorthSky is offline
post #4364 of 4377 Old 05-20-2015, 01:25 PM
hidefpaul's Avatar
Quoted: 101 Post(s)
Liked: 73
Thanks north sky, I did read that thread already..... I will perform a FW update today ( I know I did not install the last one)....I will see what happens.
I'll post back tomorrow
5.1 Home Theatre
Pioneer 60" Kuro
post #4365 of 4377 Old 05-21-2015, 12:04 PM
hidefpaul's Avatar
Quoted: 101 Post(s)
Liked: 73
^^ Well, I installed the latest FW last night and the problem still persists......this unit will have to be sent in for repair.
5.1 Home Theatre
Pioneer 60" Kuro
post #4366 of 4377 Old 05-22-2015, 04:48 AM
pbc
pbc's Avatar
Quoted: 116 Post(s)
Liked: 61
So I may buy a 4K LCD in the next couple of months as I"m moving into a new house. Has there been any reviews of the 4k upscaling that the DHC-80.3 performs? Does it have a 4K pass-through setting at all? Just curious how best to utilize the 80.3 with the new set if I do go 4K.
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #4367 of 4377 Old 05-29-2015, 04:42 PM
Liked: 0
I'm setting up a HT in a small room so the DHC-80.3 may be more than I need but I snapped one up that was sold as 'not working/for parts'. It starts out in setup mode, so I went through it and took out the setup mic. But the message to remove the mic remained and nothing would get it out of setup (other than plugging something into the headphones jack). So the detection of the setup mic is stuck, forcing the unit into setup mode, and changing the jack may solve the problem. Can someone with a service manual please look up the part number for the setup mic jack?
M49r is offline
post #4368 of 4377 Old 05-29-2015, 06:23 PM
mlknez's Avatar
Quoted: 79 Post(s)
Liked: 25
You may have the HDMI/DSP board issue. Those are replaced for free even if you are out of warranty.
mlknez is offline
post #4369 of 4377 Old 05-30-2015, 08:09 PM
SQAudiophile's Avatar
HDMI Board Failure
Anyone having sent their unit out for repair know if the Onkyo/Integra service centers require the original sales receipt? I'm having what appears to be the HDMI board failure after years of flawless performance.
SQAudiophile is offline
post #4370 of 4377 Old 05-31-2015, 09:23 AM
calentz's Avatar
I've had a few glitches, but got the processor back on track without doing a full reset. I've gotten away with just pulling the plug, waiting a bit and then plugging the unit back in while holding in the (On/Standby) button. No loss of settings!
--Carl
calentz is online now
post #4371 of 4377 Old 05-31-2015, 09:31 AM
I'll give it a shot. Anything to avoid having to disconnect and send out.
Just tried it and still no luck.
post #4372 of 4377 Old 06-01-2015, 07:12 AM
hidefpaul's Avatar
Quoted: 101 Post(s)
Liked: 73
Question to all 5509 & 80.3 owners: How long does it take your pre amp, (from the moment you hit the on/standby button on the unit or remote) to actually display both audio & video on your display?
Paul
5.1 Home Theatre
Pioneer 60" Kuro
post #4373 of 4377 Old 06-01-2015, 10:59 AM
NorthSky's Avatar
Liked: 2026
About 8.9 seconds, on average.
* It also depends of your other gear and own display and HDMI cables used, and how sequential your turn your other components ON.
But roughly, between 8 and 12 seconds, on average.
NorthSky is offline
post #4374 of 4377 Old 06-01-2015, 01:39 PM
hidefpaul's Avatar
Quoted: 101 Post(s)
Liked: 73
^^Thanks North sky.
5.1 Home Theatre
Pioneer 60" Kuro
post #4375 of 4377 Old 06-04-2015, 05:29 AM
pbc
pbc's Avatar
Quoted: 116 Post(s)
Liked: 61
Bumping this. Looks like the Onkyo doesn't do 4k pass-through? So if I end up with a 4K TV (let's put aside the lack of 4K content right now! ), how does this processor work in terms of what it is doing to the resolution that is sent to a 4K TV from a 4K source?
pbc is offline
post #4376 of 4377 Old 06-05-2015, 01:41 PM
kingofthecrate's Avatar
Well it is HDMI 1.4 so it should be able to hand the bandwidth. Anyone else want to chime in on this?
3 things in life my father said to me
1. Deny till death
2. If you dont sleep with her, someone else will
3. If it dont fit, force it
kingofthecrate is offline
post #4377 of 4377 Old 06-27-2015, 05:34 AM
atkatana's Avatar
Remote for the Integra 80.2
Some of the buttons on my remote have stopped working. I have an old iphone setup as a sort of universal remote but its not 100% ideal as I will likely upgrade in the next year or so I would like to have a working remote that will run my unit. Anyone have a good cheap universal or options to get a replacement?
atkatana is offline
Onkyo Integra
