Integra DHC-80.3 - Page 149 - AVS Forum | Home Theater Discussions And Reviews
 1Likes
post #4441 of 4467 Unread 05-18-2016, 12:25 PM
Diamond Dog's Avatar
Quoted: 18 Post(s)
I have a 80.3 pre amp.
I was playing a concert video through a media stream and selected AC-3 as the audio on the streamer.
I would expect the 80.3 to display Dolby Digital or AC-3 on the screen, but it didn't. I tried to cycle through all the music and movie modes and it would go through (all channel, Dolby PLiix, direct, orchestra, etc) all the modes, but I could never get it to read "Dolby Digital" or "AC-3" on the Integra?
When I selected "direct" it would only indicate on the Integra Unit display that 2 channels were playing.
How do I get it to recognize the audio as a a Dolby Digital Stream?
Diamond Dog is offline
post #4442 of 4467 Unread 05-18-2016, 12:53 PM
Selden Ball's Avatar
Quoted: 3109 Post(s)
Liked: 1519
If the incoming signal actually is Dolby Digital and you can hear reasonable sounds, then the Dolby Digital decoder is being used. If the wrong decoder were being used, you'd just hear noise.
It could be that you were misinformed about the type of audio being provided by the streamer. If it's an external media player device, you have to make sure that it's configured to output the appropriate audio signal.
Fortunately, the 80.3 can tell you exactly what kind of audio and video signal it's receiving. When you press on the remote's buttons Receiver followed by Display (not the Listening Mode selection), each press should cause the front panel display to step through several informational displays which include listening mode, incoming signal type and audio and video resolution. See page 45 of the 80.3's owner's manual, which is available at http://redirect.onkyousa.com/redirec...web[1].pdf
Selden
Selden Ball is online now
post #4443 of 4467 Unread 06-14-2016, 08:31 PM
bao01's Avatar
Liked: 24
It's getting hot in the summer. Last night my 80.3 stopped showing spkr icons and i did a reset/clear and it fixed it then today after work same thing but this time no joy with reset/clear. I guess it has died. It is about 4 years old.
B&W 802 Diamond mains, B&W HTM2 Diamond center, B&W 804 Diamond surrounds, Parasound HALO A 51, Krell KAV-300i , Integra DHC-80.3 pre-pro, two JL Audio Fathom f113 subs, Panasonic TC-P65VT50 65" plasma
bao01 is offline
post #4444 of 4467 Unread 06-15-2016, 08:46 PM
robinasu's Avatar
Originally Posted by YooR3 View Post
Hello, I have the dhc 80.3 and 70.1 dta bought used for over a year . Later I have seen in this youtube video that there is a pc software where are additional settings.I already wrote to integra because of the software, but have referred me to dealer. ..
So i call a dealer and asked where I get the software over here in Germany ... answer: we provide support only to customers who have purchased equipment from us . ..
Have now kilometers scrolled on the internet and found nothing where I can download it ...
Did any of you have the pc software , or can one saw me where I can get it here . ..
Here's the video what I mean , fast forward to 4:40 https://youtu.be/9gKzr_k1UsU
And sorry for my google english, i give my best..
Bump.. anybody know where to get the PC software?
robinasu is offline
post #4445 of 4467 Unread 06-30-2016, 12:24 PM
Quoted: 18 Post(s)
I can not log in to the the Sirius XM app on the Integra 80.3
I called them and they said that Sirius XM changed something and they do not have firmware to support Sirius XM streaming directly from the Preamp anymore and they were working on a fix. I told them the last firmware update was 2 years ago!!!
Can anyone verify if this information is true? I can not get past the login screen on the SiriusXM app on the preamp.
post #4446 of 4467 Unread 07-02-2016, 09:00 AM
Ron Tobin's Avatar
I had email correspondence, months ago, with Onkyo (Integra) support, and they claimed they were "working of a fix" for the 80.3. When I followed up, they said they still did not have a fix and could not give me a timeframe when they would. I personally feel that they're no longer supporting this product. I've given up, and am able to stream Sirius XM from my Roku.
Ron
Ron Tobin is offline
post #4447 of 4467 Unread 07-02-2016, 12:34 PM
jongig's Avatar
Audio on HDMI partially dropping out.
A little help with my 80.3.
The audio while connected by HDMI to my Samsung Bluray player or the Directv HD player connected as well by HDMI cuts in/out. Not all the audio but some of the audio. I was considering it was the movie since we rent from Netflix but now it's just too often and since it does this with the Directv player I'm guessing my problem is with the Integra. The Integra is connected to a Samsung plasma TV. The 80.3 is connected to the amps by way of balanced connectors.
When I pause/play it may play fine on parts where the audio didn't play previously. This doesn't seem to be happening until the unit has been on for about an hour.
I do stream Pandora and I've not noticed a problem while listening to Pandora.
Thanks...
jongig is offline
post #4448 of 4467 Unread 07-02-2016, 05:34 PM
Liked: 1519
Thanks...
What happens to audio from devices that don't use HDMI?
If it's only HDMI devices which have the problem, I'd suspect that the HDMI board is starting to go bad.
However, do make sure that all of the HDMI cables are firmly seated. Press on both ends of all of them, maybe wiggling them just a little. I had a dropout problem which I thought was being caused by a failing BD player, but it turned out that its HDMI cable was making poor contact at the end going into the receiver.
Selden
post #4449 of 4467 Unread 07-02-2016, 07:02 PM
jongig's Avatar
HDMI cables are okay.
jongig is offline
post #4450 of 4467 Unread 07-02-2016, 07:06 PM
Liked: 1519
Then you need to consider contacting Onkyo for repair.
Selden
post #4451 of 4467 Unread 08-07-2016, 06:26 PM
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Hey guys. Just picked up a 4k Tv. When I set the HDMI resolution in the processor to 4k Upscaling, I get a no signal error on my tv set, and have to switch back to Through or Source.
Anyone using 4k upscaling successfully on this unit?
Side note, it's a shame it doesn't have 4k pass through. Will have to be replaced soon, but I guess that's how these things work!
pbc is offline
post #4452 of 4467 Unread 08-08-2016, 09:23 AM
Liked: 1519
This is just a guess, but....
Modern 4K source material requires HDMI V2.0a with HDCP V2.2 copy protection. It could be that your new TV requires them for any 4K input signal. The 80.3 predates those new standards, so its HDMI circuits can't generate or pass them.
Selden
post #4453 of 4467 Unread 08-08-2016, 09:51 AM
pbc
pbc's Avatar
Quoted: 347 Post(s)
Liked: 206
Thx..odd thing is I was trying it with basic cable as I don't have any HDR players at the moment. The cable box is "4K capable" and has about 4 channels that are broadcasted in 4K, but I wouldn't think that would cause the copyright problem.
My DIY Subs ... http://www.avsforum.com/avs-vb/showthread.php?t=1233892
J Dunlavy:.. if you stop to think about it, no loudspeaker can sound more accurate than it measures.
pbc is offline
post #4454 of 4467 Unread 10-12-2016, 01:27 PM
Alembicjeff's Avatar
Quoted: 21 Post(s)
Liked: 34
Hey guys,
I bought the 80.3 when it was first released because of my having owned, and loved, the 80.2.
I'm having a problem using the Audio Return Channel (ARC) after having successfully used it to stream the audio for Pacific Rim from VUDU.
I first posted the information below in the Vizio P65 thread but I suspect that the problem may be with the 80.3 and not the Vizio. Here it is:
"Hoping I can get some advice on an issue possibly involving the use of ARC with the P65. Since I purchased the panel a couple of months ago, I have been really enjoying disc play from the Samsung UHD player, an OPPO 103, and cable thru the X1 platform.
It was only recently that I started using the P65 to cast from an app (VUDU), which necessitated an upgrade to a new router and a wired Ethernet connection directly to the P65.
All hdmi cables were upgraded with blue jeans 4K "certified" cables, none longer than 7 feet.
I set up, for the first time, my Integra 80.3 pre/pro so that I could use ARC for audio.
With some assistance from VUDU, I was able to cast Pacific Rim in UHD for video and Dolby 5.1+ for audio (I wasn't able to get the "Atmos" audio because I don't have an Atmos setup but was hoping to get Dolby True HD like you do with a disc?). The video looked beautiful and the 5.1+ audio track surprised me because it was very close in impact and power in the bass to the bass I get from the blu-ray disc I have.
I also have the most recent firmware update for the panel.
Now when I attempt to cast, I cannot get any audio, whether it be from VUDU, Crackle, or You Tube. I studied the Integra manual very carefully and tried a multitude of different settings to get ARC to work, but it does not.
I am aware that some owners have reported issues with ARC since the last firmware update, but is anyone else getting NO audio at all? I re-studied the posts on the first page regarding the use of ARC and nothing has helped. Any idea if this is a Vizio issue, Integra issue or something else?
Really would VERY much appreciate any help or suggestions."
THANKS!
Jeff.
If anyone knows who the "ARC expert" is for the 80.3, I would be happy to PM them.
Subs: 10 x 18" LMS Ultra 5400 in 5 Funk Audio sealed custom cabinets; 5 x Sanway FP14000 amps.
Speakers: Definitive Technology BP7000SC Front; BPVX/P surrounds
Pre/Pro: Marantz 7703; Disc Player: OPPO UDP-203.
Front Amp: Emotiva XPA 2 Gen 2; Surround Amp: XPA 7.
Display: Vizio P65-C1
Alembicjeff is offline
post #4455 of 4467 Unread 01-08-2017, 02:38 PM
jongig's Avatar
This thread really isn't moving much so I don't imagine I'll get much help but here goes anyway.
Upgraded to the 80.3 in 2013 because the previous Integra would no longer work with HDMI.
The replacement now three years old and now has garbled audio from the HDMI inputs. The first one lasted three years, this is getting expensive.
Any ideas?
John
jongig is offline
post #4456 of 4467 Unread 01-08-2017, 03:13 PM
Cigarjohn47's Avatar
Any ideas?
John
Did you try changing the HDMI cable. My DHS 80.3 is working fine so far. Been more than 4 years now. I purchased it the year it first came out. Was Integra able to help you out?
Cigarjohn47 is offline
post #4457 of 4467 Unread 01-08-2017, 05:04 PM
mlknez's Avatar
Quoted: 208 Post(s)
Liked: 52
Any ideas?
John
I have a 2011 DHC-80.3 that had the HDMI board changed in late 2014. I have had no issues since.
mlknez is online now
post #4458 of 4467 Unread 01-13-2017, 01:48 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Any ideas?
John
Integra is honoring failure of the HDMI board past the typical warranty period. You may still be covered.
jkasanic is offline
post #4459 of 4467 Unread 01-13-2017, 02:19 PM
jongig's Avatar
Would you happen to have a contact at Integra even if you could send it to me by PM? I ask because I've sent emails back to the person I reported the problem to last July at Integra and he never got back to me. I also sent a copy of the email to a second person at Integra and that person also didn't get back to me. Maybe they're both no longer with Integra.
Thanks for the help.
I want to offer my opinion on this if you don't mind. I like to upgrade and it so much fun and I know everyone here at AVS feels this same way. I also do plenty of upgrading with this being probably my 8th processor after starting with the Yamaha DSP-3000 so many years ago. The only time I've felt bad about an upgrade was the forced upgrade to the 80.3 because the one before it had a bad HDMI board. It's not the same feeling and I'm very much against forced obsolescence. You can say that things just break and they do but I still have a Yamaha bought before HDMI that still looks and works the same as the day it was purchased as well as my very first receiver which is a Rotel from 1981 that again works like the day I bought it. This is my second Integra with the same problem and nearly $6,000 spent, they should have been far more helpful back in July as I suspect that they probably knew that it was a bad HDMI board since my complaint was about the HDMI inputs. They put me through hoops that have taken me 6-months to go through since I don't have so much free time. Change cables, do resets, replace Bluray and etc.. It was summer, I could have sent it to them and they could have diagnosed it but no offer to help, we're just on our own.
My rant, my opinion.
John
jongig is offline
post #4460 of 4467 Unread 01-13-2017, 03:10 PM
jkasanic's Avatar
Quoted: 329 Post(s)
Liked: 123
Sorry, no specific contact. I believe I just called Integra and explained the issue and they setup a warranty repair. I took it into a local authorized dealer and they had to send it out for repair. Only took about a week or two. I'm sure if you search this thread you'll find plenty of detail on it though. Good luck!
jkasanic is offline
post #4461 of 4467 Unread 01-14-2017, 11:46 AM
calentz's Avatar
Quoted: 59 Post(s)
Liked: 42
My DHC-80.2 failed. While it was being repaired under Warr I purchased a DHC-80.3.
It always had shadowy intermittent problems. It finally got to the point that I was having to do a partial reset (Re-inserting the power plug while holding in the power button on the front of the unit in) more & more often. It finally became a hard fail, so I took the processor in for repair. (~$400) The repair lasted for ~one month before it had to be repaired - again. (Warr) The first failure involved loss of sound. The second involved loss of Ethernet. (Both on the HDMI board)
It has been OK for close to two months now.
--Carl
calentz is offline
post #4462 of 4467 Unread 02-15-2017, 11:27 AM
jongig's Avatar
Well here's my update and I wish I had better news because this really is annoying.
Spoke to Integra last month and they agreed to fix the unit under warranty. I sent the unit two weeks ago and received it back two days ago. Connected it last night and it worked for 10-minutes when it started doing exactly the same thing. Watching Transformer-Age of Extinction I see the person talking and do not hear the voice.
I am so peeved at this company and just really wish I wasn't having to deal with people that just do not care. If they cared they would have taken this unit last July just to say lets help you figure out the problem. At what price point do companies like this care but this one doesn't, rhetorical.
jongig is offline
post #4463 of 4467 Unread 02-21-2017, 06:23 AM
ajhoop's Avatar
Best way to hook up UHD bluray?
I have a setup question that I can't seem to sort through.
I just got an Oppo BDP-203 4k blu ray player. I have the video hooked up direct from the Oppo to my TV via HDMI (as I understand the Integra cannot pass through a 4k signal).
The Oppo has an HDMI audio out, coax/optical digital outs, and multi-channel analog outs. I tried connecting the HDMI audio out to the Integra (BR input), but didn't get any audio (and see a footnote in the manual that audio may not play if the corresponding video source is turned off). The Oppo manual says that coax/optical digital outs do not have enough bandwidth to handle the newer audio tracks (TrueHD and maybe one other one?).
Is there a way to get the Integra to play the HDMI audio in (so that I can get the best audio from a 4k disc)?
If not, does the Integra apply the Audessey settings and room correction if I run the audio via the multi-channel analog inputs?
Is there any other way to accomplish what I'm trying to do? Or am I just out of luck with the now-somewhat-dated Integra?
Thanks for the input!
ajhoop is online now
post #4464 of 4467 Unread 02-25-2017, 01:12 AM
AVGeek99's Avatar
Quoted: 85 Post(s)
Liked: 77
I have the 80.3 and the Oppo 203. You definitely want to use HDMI, that is the only way to the lossless audio (TrueHD, DTS HD MA). It sound like you have it connected correctly. The HDMI audio out on the Oppo should go to the Integra. Check your Digital input settings on the Integra in the set up menu. Make sure Blu-Ray is set to whatever HDMI you have plugged it into. If that doesn't change anything, check the audio output settings on the Oppo.
This is kind of a dumb question, but an easy mistake to make if your're not paying super close attention. You don't have the HDMI going to your Integra plugged into the HDMI in on the Oppo, do you?
Question, how long have you had the Oppo? Have you updated to the latest FW. I have the latest public beta released last Friday. I've had no issues to speak of. The beta FWs can only be installed via USB, the file is available on their site. Check the Oppo 203 Owners Thread. A caution about that thread if you haven't been following it. Just start at the end, maybe the last 10 pages. There were a lot of issues with the first couple FWs after release, but most have been resolved. The latest beta is very stable. That is the one I would go with.
Official OPPO UDP-203 Owner's Thread
AVGeek99 is offline
post #4465 of 4467 Unread 02-25-2017, 05:50 AM
ajhoop's Avatar
Thanks for the tips. Sounds like I need to double-check the cabling. I was initially experimenting with using the 203 to upscale my fios box, so have 2 identical HDMI cables running between the 203 and the other side of my cabinet which houses the fios box and 80.3. Perhaps I just got those crossed up.
I just got the 203 this week and am on the latest full version of firmware (did update via wifi). I've only watched one movie so far...John Wick 4k. When I first loaded the disc nothing happened. I had to power cycle the player to get it to load. After that, everything seemed to work flawlessly. I was just listening to the DTS soundtrack via the coax input, but it was still pretty amazing (I'm just on a 5.1 setup anyway).
post #4466 of 4467 Unread 02-25-2017, 06:54 PM
AVGeek99's Avatar
Quoted: 85 Post(s)
Liked: 77
Don't bother running the FIOS box through the Oppo HDMI in at this point. There is a severe lip sync issue that is not correctable.
I recommend installing the beta FW. It has a lot of fixes for playback issues that were fairly common with the current official FW that would have been installed with network update. The only issue that is fairly common in the beta is that sometimes the tray can get stuck open. Simple fix, just press the power button on the front panel one time. After 15 seconds the player will power off. The tray then closes upon the next power up. I say it's fairly common because several people have reported the issue. For most though it doesn't happen very often. It happened to me once.
John Wick is awesome! Perfectly suited for HDR. I just watched Deepwater Horizon last night, INSANE!!!
Sent from my HTC 10 using Tapatalk
AVGeek99 is offline
post #4467 of 4467 Unread Today, 09:12 AM
ajhoop's Avatar
So, I just double-checked the settings on both units and my cabling.
As far as I can tell, the settings and cabling are all correct. I have the Integra set to HDMI and the correct HDMI input (#1) mapped to the BR input.
With both the HDMI and coax connected, the Integra will flash the HDMI light on the front for several seconds with no sound playing, then reverts back to coax and my DTS soundtrack.
I guess I could try a reset of the Oppo and/or unplugging the coax cable (which I have not yet tried). It's a brand new HDMI cable, but maybe I'll try swapping that out, as well. Anything else that I might not be thinking of?
I'm still on the non-beta, current FW.
Onkyo Integra
