integra dtr-20.3 vs onkyo txnr 608 vs denon 2112ci?? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-19-2011, 11:45 AM - Thread Starter
tekjunkie28's Avatar
Looked @ all these, all sounded great. Denon has multi eq plus but the integra is thx select2 plus certified. Help me choose
tekjunkie28 is offline
post #2 of 8 Old 09-19-2011, 01:14 PM
mjpearce023's Avatar
Quoted: 36 Post(s)
Liked: 38
MultEQ and MultEQ XT are important in my opinion because they can EQ a subwoofer while 2EQ cannot. Low frequencies are the most difficult to get right so you need to do something with them. Subwoofer placement and room treatments are the best solution but EQ can help as well. The 2112 has a lot of features for the price and is a great option. If you want to get Onkyo, I would look at the RC370. It steps up to MultEQ XT and the new models are said to not get as hot as the 08 series did.
mjpearce023 is offline
post #3 of 8 Old 09-19-2011, 02:05 PM - Thread Starter
could i tell a difference? if multi EQ is so much better for low freq then why is the integra THX select 2 certified? The denon 2112CI is also $100 more.
post #4 of 8 Old 09-19-2011, 02:08 PM
ccotenj's Avatar
Liked: 101
because onkyo/integra paid for the certification and d&m did not...
- chris
ccotenj is offline
post #5 of 8 Old 09-19-2011, 02:17 PM - Thread Starter
So which one should I get? I'm asking from personal experience
post #6 of 8 Old 09-19-2011, 02:20 PM
ccotenj's Avatar
Liked: 101
i own none of the above...
however, imo, the biggest issue that virtually all home users have is lousy response in the low octaves... multieq/xt addresses this, and 2eq does not...
- chris
ccotenj is offline
post #7 of 8 Old 09-19-2011, 05:43 PM - Thread Starter
anyone else with additional advice?
post #8 of 8 Old 09-20-2011, 02:14 AM
jdsmoothie's Avatar
Quoted: 14597 Post(s)
Liked: 6928
+1
Agree with them both re: MultEQ XT in the 2112CI over 2EQ in the Onkyo and Integra ... also, if you are referring to MSRP ... you can save a couple hundred on the 2112CI simply by "calling" Electronics Expo or AV Science and asking for their best price.
jdsmoothie is online now
Denon Avr 2112ci Receiver
