DENON AVR-991 Input Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 09-20-2011, 03:22 PM - Thread Starter
NEC1984's Avatar
Alright...I'll admit it. I'm an idiot. I set up my DENON AVR-991 perfectly a few months ago. After setup I was able to use my Comcast universal remote with no problems.
A few weeks ago I was playing around with some setting and changed something I shouldn't have. Now when I turn on the various components the receiver will automatically change itself to the TV input setting. I have gone all through the settings and can't find what I changed.
Does anyone one know what setting to change so that the receiver will turn on to its last input in use? Any help you can suggest would be appreciated. Thanks!
NEC1984 is offline
post #2 of 8 Old 09-20-2011, 04:15 PM
mjpearce023's Avatar
Quoted: 34 Post(s)
Liked: 38
Are you using ARC? (Audio Return Channel)
mjpearce023 is offline
post #3 of 8 Old 09-21-2011, 03:59 PM - Thread Starter
NEC1984's Avatar
Hello mjpearce023,
I am not using an ACR. Unfortunately, it isn't supported with my current TV.
NEC1984
NEC1984 is offline
post #4 of 8 Old 09-21-2011, 05:45 PM
Quoted: 34 Post(s)
Liked: 38
It sounds to me like it's a TV setting. Did you turn on some kind of HDMI-CEC feature?
post #5 of 8 Old 09-22-2011, 10:48 AM - Thread Starter
NEC1984's Avatar
I do not believe so....After the set up the new receiver was working perfectly....then I went playing around with the settings within the AVR-991 and this is the result (didn't touch the TV settings at all). It still works as it should, but its just annoying to keep changing the input each time it turns on.
NEC1984 is offline
post #6 of 8 Old 09-22-2011, 10:56 AM
Quoted: 34 Post(s)
Liked: 38
I'm not familiar with any other settings that would cause that. You might want to post in the Denon 3311/991 owners thread. Here is a link
http://www.avsforum.com/avs-vb/showt...57209&page=284
JDsmoothie or Batpig know a lot more about this stuff than I do so maybe they will be able to help you out.
post #7 of 8 Old 09-23-2011, 10:12 AM - Thread Starter
NEC1984's Avatar
Awesome. Thanks for the help mjpearce023!
NEC1984 is offline
post #8 of 8 Old 09-23-2011, 01:58 PM
Quoted: 34 Post(s)
Liked: 38
I messed around with my 3311 last night and it might be HDMI control/Power off control that is causing your issue. If you have those set to on see if turning them off helps.
