8 ohm AMP with 6 ohm speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-01-2011, 04:03 PM - Thread Starter
Roald's Avatar
I've bought my first (used) AMP, a Marantz PM80. Now I was doing some research to find suitable speakers for my budget and I've found the Wharfedale Diamond 10.1 (haven't bought them yet though).
Now I've noticed that the nominal impedance of the speakers is 6 ohm and the nominal impedance of the AMP is 8 ohm. I'm wondering if this will cause any trouble?
Roald is offline
post #2 of 7 Old 10-01-2011, 04:15 PM
videoaddikt's Avatar
Quoted: 32 Post(s)
You need to find the full specs of the amp. In most every case, amps are designed to take speakers specified as low as 4 ohms, so you should be fine with 6. There normally is a sticker or printing on the back panel stating the minimum impedance. I realize this is an older amp and may not have that.
If it is a well designed amp you should yield more output with the lower impedance.
6 Ohm speakers are very common (these days).
Samsung PN51F8500, Emotiva UMC200, Emotiva XPA-5, Samsung BD-H5900 BluRay, Dish Hopper, Furman Elite pf-15 conditioner, Dali Ikon (Ikon6, Vokal2, OnWalls) Outlaw Audio LFM-EX subwoofer.
videoaddikt is offline
post #3 of 7 Old 10-01-2011, 05:58 PM
OzzieP's Avatar
If an amp reads 120W/8 Ohms & 200W/4 Ohms (Range?).
Is this the limits of the ohms on the speaker you can use, in other words you can use any speakers with an ohm range between 4 and 8?
Does this mean if you use a 4 Ohms speaker your max amp output will be 200W?
P.S. here are the specs for Roald's amp;
http://audio-database.com/MARANTZ/amp/pm-80-e.html
OzzieP is offline
post #4 of 7 Old 10-01-2011, 06:26 PM
Knucklehead90's Avatar
Quoted: 382 Post(s)
Liked: 332
That amp is fine with 4ohm speakers - 6 or 8ohm speakers would only be easier on it.
The speakers will work fine with that amp.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #5 of 7 Old 10-01-2011, 06:38 PM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
If you look at Ohm's law, it explains a lot. V (Volts)= R (Resistance) x I (Current). The Ohms is resistance and if it drops, current increases. Since Voltage stays the same the variables are Resistance and Current. The problem many amps have is with more current you have more heat. Amps are usually designed to match the resistance (or impedance) to maximize efficiency. It cost more to design an amp that can handle lower impedance speakers. In the real world, most speakers dip to 4 ohms or so in certain frequency ranges (even though they are rated at 8 ohms). I cannot think of a single consumer AVR that cannot handle a 6 ohm load. In reality many can handle 4 ohm loads under normal listening conditions.
I would be completely blown away if your amp couldn't handle a 6 ohm load. Many in here have used cheap AVRs to power 4 ohm speakers with success for many years. Speakers are not a set impedance. With each frequency the load to the amp changes. A speaker's resistance is an average given by the speaker manufacturer and is not a simple number that tells all. I think this is why people think a certain amp is better than a different amp. It just performs better with a certain speakers impedance curve.
Xbox Live: TheRealMaxPower --- PSN: TheRealMaxPower (no PS4 currently) Panasonic TC-P65VT60    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S Astro Mixamp 2013   Soundblaster X7 (Sparkos Op Amps) Schiit Modi Multibit/Magni   LTA MicroZOTL2 AKG K702 65th Anniversary   Fostex TH-X00 Ebony DT990 Pro 250 ohm  Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
post #6 of 7 Old 10-01-2011, 07:06 PM
OzzieP's Avatar
So this is the reason for the range on my speaker showing it to be 4 to 6 ohms/50 to 200 Watts.
OzzieP is offline
post #7 of 7 Old 10-01-2011, 10:46 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Yes, there's a range as mentioned above because it's not a fixed impedance. 200 watts is probably the average power handling of the speakers, but it's hard to say for certain without more info (it could be a peak number.)
"But this one goes up to 11"
MichaelJHuman is offline
