How to hook up a car amp in my house? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 10-03-2011, 11:05 AM - Thread Starter
CTate93's Avatar
I have an 800w Fosgate amp and two 12" Fosgate Punch subs. I had them hooked up in my truck before I sold it and got a new car and i don't really want to but my subs in there. I know how to hook the subs up in a vehicle so the only thing I dont know how to do is hook the amp to a power supply. Is there some type of adapter that I can use to go from a standard wall outlet to the amps power input? Thanks for any Help!
CTate93 is offline
post #2 of 9 Old 10-03-2011, 11:13 AM
JOHNnDENVER's Avatar
The power supplies for those types of amps are expensive. They have to be extremely beefy and cost a mint.
You will be better off buying a new cheap amp for the application than attempting to supply that amp properly.
A smaller amp? Maybe, but not that one in all likelyhood.
JOHNnDENVER is offline
post #3 of 9 Old 10-03-2011, 11:17 AM
JBWIII's Avatar
Liked: 42
I think that any home amp that can drive the 2-ohm car subwoofers could cost just as much as a fancy power supply.
What kind of input power does the car amp need?
JBWIII is offline
post #4 of 9 Old 10-03-2011, 11:37 AM
That one? The min I would try would be 20amp, 30 amp would be much better.
Just try to find a 30amp 12v supply. $110 for a cheapy 20amp.
There are some less expensive pro amps that could handle the 2 ohms.
post #5 of 9 Old 10-03-2011, 11:43 AM - Thread Starter
CTate93's Avatar
CTate93 is offline
post #6 of 9 Old 10-03-2011, 01:20 PM
Car audio amps, particularly sub amps can sure be demanding, but they assume they have a battery on the power supply too.
I don't really know what this one draws. Looks and sounds beefy from the description. I wonder what gauge wire they reccomend for it in the automobile install?
post #7 of 9 Old 10-03-2011, 01:46 PM
kapone's Avatar
Quoted: 245 Post(s)
Liked: 206
A Behringer EP4000 is under $300......
Why bother?
kapone is offline
post #8 of 9 Old 10-03-2011, 02:28 PM
DreamWarrior's Avatar
Quoted: 320 Post(s)
Liked: 238
Yeah, I would not bother. You'll need to buy a good DC power supply or the amp will suffer, possibly to the point of failure. If you can tolerate the fans (and I'd suppose you can if you're willing to look at the mess that'd be the DC power supply + wiring to the amp, etc) then sell that amplifier and put the money towards a pro amplifier.
DreamWarrior is offline
post #9 of 9 Old 10-03-2011, 03:15 PM
Behringer iNUKE NU1000 under $200
I saw some guys playing out in a larger venue not long ago using a bunch of these and it rocked hard for sure.
