Whole house audio receiver - AVS Forum | Home Theater Discussions And Reviews
post #1 of 21 Old 10-09-2011, 07:05 PM - Thread Starter
DeepFrz97's Avatar
My wife and I are building a house and we are having a whole house audio system installed. It will be using the Russound system and Proficient speakers. The installer uses Sherwood receivers for the system, but I am thinking of changing the receiver to allow for other audio options.
We have other/better receivers for home theater and critical listening. I want to be able to add Sirius, internet radio (not a deal breaker), iPod (or home networked music), and regular radio. It would need to be multiroom capable to allow us to listen to seperate audio sources. The watts isn't a factor, as the Russound system will be providing the power to the speakers.
Does anyone know of any good options for us?
DeepFrz97 is offline
post #2 of 21 Old 10-10-2011, 04:19 PM
jdsmoothie's Avatar
Quoted: 12079 Post(s)
Liked: 5499
jdsmoothie is offline
post #3 of 21 Old 10-10-2011, 04:24 PM - Thread Starter
DeepFrz97's Avatar
That receiver isn't Sirius ready, nor does it have multiroom capability. Those are two must haves.
post #4 of 21 Old 10-10-2011, 04:33 PM
jdsmoothie's Avatar
Liked: 5499
Denon DRA-697CI http://usa.denon.com/us/Product/Page...A697CI(DenonNA)
Although only XM ready, any network receiver can be XM/Sirius ready using a smart phone app streaming the audio from the smart phone.
post #5 of 21 Old 10-10-2011, 05:51 PM - Thread Starter
DeepFrz97's Avatar
I would rather go this route if I am going to be spending that much money.
http://www.pioneerelectronics.com/PU...vers/VSX-921-K
It is $200 cheaper and I wouldn't need an app work around.
post #6 of 21 Old 10-11-2011, 12:32 AM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
That receiver may not be adequate. I don't see multizone or preamp out for external amp on that 921.
kikkenit2 is offline
post #7 of 21 Old 10-11-2011, 10:10 AM - Thread Starter
DeepFrz97's Avatar
It does have multizone, but not preamp outputs.
post #8 of 21 Old 10-11-2011, 10:30 AM
jdsmoothie's Avatar
Liked: 5499
I'm not familiar with a Russound system, but it likely only accepts RCA inputs from a receiver's preout jacks otherwise you'll have to convert the 921's speaker posts to line level outputs.
post #9 of 21 Old 10-11-2011, 10:36 AM - Thread Starter
DeepFrz97's Avatar
It accepts RCA inputs, so I will need to find a receiver that has RCA outputs. That is why I am asking for help finding the receiver that will fit my needs
I am looking for a receiver that has:
RCA outputs
2 zone capability
Sirius ready
AM/FM tuner
iPod/DLNA input
optional:
internet input
post #10 of 21 Old 10-11-2011, 10:45 AM
jdsmoothie's Avatar
Liked: 5499
In addition to the Denon DRA-697, you may also want to consider last year's Denon 3311CI which although overkill for your use, meets all your requirements and also has a full set of main zone preouts as well as Zone 2/3 preouts giving you 3 independent source ability as well as ipod to Zones 2/3. It's on clearance now at Best Buy/Magnolia stores.
post #11 of 21 Old 10-11-2011, 10:52 AM - Thread Starter
DeepFrz97's Avatar
I am guessing you are either a Denon rep or fanboy...lol The Denon 3311CI is an option. It meets all of the requirements, but is a bit expensive for what I need. Any other options? I am sure there are other manufacturers that can meet the requirements as well.
post #12 of 21 Old 10-11-2011, 10:55 AM
jdsmoothie's Avatar
Liked: 5499
It would be easier to provide suggestions with your budget maximum. The 3311CI can be had for about $500 on clearance.
post #13 of 21 Old 10-11-2011, 11:00 AM
kikkenit2's Avatar
Quoted: 822 Post(s)
Liked: 303
RCA outputs
2 zone capability
Sirius ready
AM/FM tuner
iPod/DLNA input
optional:
internet input
The yamaha 867 is a strong candicate at about $400 right now. It doesn't have a usb port, s-video, nor as good room correction software as denon, but has everything else and then some. It has sirius, but ipods need a dock. It usually works best to send mp3 to receiver thru network connection anyway.
post #14 of 21 Old 10-11-2011, 03:25 PM - Thread Starter
DeepFrz97's Avatar
The Yamaha RX-V671 looks like it might be what I am looking for. It has two zone RCA output, Sirius, is DLNA certified and ethernet. It also is controllable by iPhone app, so that is an added bonus.
post #15 of 21 Old 10-11-2011, 07:21 PM - Thread Starter
DeepFrz97's Avatar
I think the Onkyo TX-8050 looks like a good option as well. http://www.us.onkyo.com/model.cfm?m=...s=Receiver&p=i
post #16 of 21 Old 10-11-2011, 08:23 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
Do you need to have video distributed to every room? This is the main question you need to answer first. But generally the best solution is to have media player in every room (either A/V or audio only), with content distributed via home network. For audio only WiFi is sufficient, but for video I recommend either have CAT5 cables or (in case if you don't want/can't to re-do wiring) MoCA.
ap1 is offline
post #17 of 21 Old 10-11-2011, 08:29 PM - Thread Starter
DeepFrz97's Avatar
I do not need video. This is just to play music in four rooms. Instead of purchasing seperate components for each room I am going to use a whole house system to distribute the audio to each room. Hence the whole house audio receiver.
post #18 of 21 Old 10-12-2011, 07:09 AM
ap1
ap1's Avatar
Quoted: 22 Post(s)
This is bad idea, and ultimately more expensive one. Having long speaker cables is not good too. I suggest to get Squeezebox Touch and dedicated power amp for each room. Keep receiver only where you need video too.
ap1 is offline
post #19 of 21 Old 10-12-2011, 09:10 AM - Thread Starter
DeepFrz97's Avatar
The install does not require long speaker cables. The Russound system uses Cat 5 cable to run to the individual rooms.
post #20 of 21 Old 10-12-2011, 08:40 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
I wouldn't use something like Russound for anything other than background music. If it is enough for you, go ahead. But for less than $500 per room in electronics you can have completely flexible solution, which you can upgrade at any point of time, rather than get stuck with a single vendor.
ap1 is offline
post #21 of 21 Old 10-12-2011, 09:11 PM - Thread Starter
DeepFrz97's Avatar
The system is to be used for background music. I have a home theater and stereo set up for more critical listening.
The Russound system can be expanded to other rooms as needed, since I am running Cat 5 to all rooms. With that said it would cost me about $200 per room to upgrade in the future and be less obtrusive. The initial cost is about $1500 for four rooms. I don't see how your option is better than that.
