Can you link the AVR-3312CI and 4308CI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 10-12-2011, 11:03 AM - Thread Starter
filcro1's Avatar
I have a AVR-3312CI and a AVR-4308CI hooked up to my home network by CAT-5.
Is it possible to have both of these output the same music at the same time from iTunes or my Network Hard Drive?
For parties it would be nice to have the same music running.
Thank you.
filcro1 is offline
post #2 of 3 Old 10-12-2011, 01:55 PM
585-645-1006
jdsmoothie's Avatar
Quoted: 4419 Post(s)
Liked: 2376
"Party" mode was first introduced in the XX10 models which will do what you want but each AVR connected to the network must have this feature, which the 4308CI does not. Therefore your goal will be much easier to accomplish when you replace the 4308CI with the 4313CI. Until then, you're likely looking at connecting a separate itunes device to each AVR playing the same tracks.
"JD" – jd@avscience.com ; http://shop.avscience.com/ Call for sales info --> 585-645-1006
Daily - 8am to 8pm EST
AVScience sells Denon, Marantz, Yamaha, Pioneer, Onkyo, Def Tech, Oppo, and more
** Think the AVR is defective?  Reset the microprocessor 5 times.
jdsmoothie is offline
post #3 of 3 Old 10-12-2011, 02:19 PM - Thread Starter
filcro1's Avatar
Man, it's hard to think that the 4308IC is outdated already.
Just got the 3312 for my den....
I hope by time the 4313IC comes out they will still work together.
Thank you for taking the time to answer my question.
Best regards,
Tony
filcro1 is offline
Denon Avr3312ci Receiver
