How do more expensive receivers effect sound quality? - AVS Forum | Home Theater Discussions And Reviews
 3Likes
post #1 of 36 Old 10-14-2011, 11:23 AM - Thread Starter
pittsoccer33's Avatar
Quoted: 648 Post(s)
Liked: 426
Definitely a beginners question.
I've had a basic Sony theater in a box set up since college and it's served me well enough. It has no hdmi. I would like to put together a better sounding system for when I finally pull the trigger on a projector.
What are some major "cant live without" features on the newer receiver? I run an HTPC with Windows Media Center, and given it's HDCP problems I will probably send one hdmi to the projector and one to the receiver, so in reality I really only need one input. Given that the source is a computer I don't need any networking capabilities (or do I?)
Are the price point bumps more of a result of more features, or is a lot of it sound quality?
My basement media room and bar
Epson 2030, Onkyo TX-NR626, and Kodi based system
Mironto's Panasonic plasma black level restoration guide
Restore the initial MLL on a 2009 Panasonic plasma
pittsoccer33 is offline
post #2 of 36 Old 10-14-2011, 12:28 PM
mlknez's Avatar
Quoted: 204 Post(s)
Liked: 52
What is your budget, what is the room like where you will be listening, what is your source material and what is your primary goal?
mlknez is offline
post #3 of 36 Old 10-14-2011, 01:38 PM - Thread Starter
Quoted: 648 Post(s)
Liked: 426
I suppose I don't really have one yet - I am just trying to figure out how much is enough without buying features I don't need.
The plan is to support 7.1 sound for movies mostly and occasionally music. I will be reusing my current satellite speakers for the sides and rear, and buying a new sub, new center channel, and two front towers. I know multizone is a big thing now but I'm not interested.
I guess my main question is what on the $1000 Pioneer system is going to make it sound better than the $200 Sony one?
post #4 of 36 Old 10-14-2011, 04:17 PM
Knucklehead90's Avatar
Quoted: 382 Post(s)
Liked: 332
Better AVRs have better room correction software. The effect is very noticeable.
Lay out the features you need/want - then we can tell you how much you'll need to spend.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #5 of 36 Old 10-14-2011, 05:04 PM
Audiodork's Avatar
Liked: 37
Hello,
A major advantage to more expensive AVR's is that they have better Amplifier Stages. As the number of features has skyrocketed with the attendant licencing fees, Entry Level AVR's really tend to skimp in respect to Heat Sinks, Capacitor Banks, and Power Transformers.
Especially if using a large space and wanting to produce Reference Level SPL's, having a quality AVR is pretty much essential. If using super efficient Speakers like Klipschs, you can get around needing that much power. Also, more expensive AVR's also tend to have the most advanced Room EQ Systems and Video Processing.
Cheers,
AD
Radio Shack SPL Meter Owner
Audiodork is offline
post #6 of 36 Old 10-14-2011, 05:06 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Don't presume more expensive means better sound.
More money buys you a better power supply, which means more watts which means better sound (IF the cheaper unit would have been distorting due your your normal volume.)
More expensive receivers may use better parts in some cases, which may lead to a long lifespan.
More money is, to a large extent about features. Fancy video processing chips, network features, the latest audio processing gimmicks, more speakers (such as your 9.1 or 11.1 systems,) more zones, more flexibility to name some off the top of my head. Interestingly, as you may more, you get less per dollar, in my experience. I have seen price bumps of $100's for a small set of higher end features. That being said, I am happier with my Yamaha Z7 than my cheaper 800 series receiver - some of that may be the better power supply on the Z7...the 800 series receiver just doesn't seem to have the same impact, for what that observation is worth.
One option some people choose is to get a receiver with pre outs, and external amps to ensure they don't run out of power. Unfortunately, there's been a sad change in the market, and pre outs are becoming a high end feature (silly, if you ask me, because it was one of the selling points Yamaha's 600 series line...did they not realize that some of their sales were due to that feature, or were the sales from that aspect not that important?)
djjoshuad likes this.
"But this one goes up to 11"
MichaelJHuman is offline
post #7 of 36 Old 10-14-2011, 05:20 PM
mikejedi123's Avatar
Quoted: 71 Post(s)
Liked: 61
I would totally agree with what Michael said.. Usually the higher end receivers will have better PSU, PARTS ETC. They tend to sound better, at least from my own personal exprience as I have owned many lower-end and higher end Yamaha's over the years as I know Michael has as well. I am also a current RX-Z7 owner.. blows away my 2700, while no slouch itself.. I am 100% sure after opening both units that the power supply is slightly larger and I think contributes to the higher quality sound. My old 3090 may actually outperform both .. but haven't listened to it in some time. I think my wife would kill me if i hooked up another Yammie in my house. hehe
Mike in Vegas
mymoviegeeks.com
mikejedi123 is offline
post #8 of 36 Old 10-14-2011, 05:21 PM
mlknez's Avatar
Quoted: 204 Post(s)
Liked: 52
The answer to your "main question" is... it depends. That is why I asked you the questions I did earlier. If you are planning on using cheap speakers and your source material is old movies or mp3 files then you will not benefit much from the upgraded receiver/processor. An analogy would be, would you benefit from an upgrade of an old chevy to a new ferrari if you put wagon wheels on the ferrari and used watered down gasoline?
Your benefit is only as good as your source material and your output devices. If you are using blu-ray movies and hi-def audio downloads and you purchase reasonably good speakers then, yes, you will notice a difference.
Beyond your source material and your speakers, the better Recievers and processors will come with good room correction software that will help over come some issues with your speaker differences and room layout.
A good receiver will also have quality hardware to convert your digital media and provide sufficient, clean amplification.
In todays world, more material is digital and requires good digital to analog conversion for clean, realistic output
mlknez is offline
post #9 of 36 Old 10-15-2011, 05:23 PM
Ryan1's Avatar
Quoted: 12 Post(s)
Liked: 41
Actually, if you listen at identical (and reasonable) levels, you are not going to hear any difference between the vast majority of modern amplifiers, regardless if they cost $200 or $20000. No matter what marketing and "audiophile" trade literature tells you, blind tests show time and time again that people can't hear a difference (like this one).
Even DAC tech has gotten to a place where beyond certain rather inexpensive point, you are just not going to get much real improvement.
The only place where you'll often hear real improvement as the price goes up is speakers and room correction. And even there you don't have to go too high to get truly good stuff.
Ryan1 is offline
post #10 of 36 Old 10-15-2011, 09:19 PM
Quoted: 266 Post(s)
Liked: 148
One interesting point is that the current limiting circuits can lead to audible issues (according to some engineers.) And if I understand the implementation, they may kick in even when not strictly needed.
This could result in some receivers seeming to have enough power on paper, but not sounding as good as expected. Just a theory.
Some higher end receivers may be more forgiving and sound better for this reason.
I know some people suggest that you really don't want to get that close to the point.
post #11 of 36 Old 04-23-2013, 09:26 PM
Calgry's Avatar
True, more expensive does not mean better sounds. I had an old Sony receiver from the 80s and an old set of large speakers Audio Logic ( maybe older than me) only 35 watts but enough to rock the party, the highs were crisp and lingering, bass was clear and punchy, over all sound was rich and every sounds were just perfectly blended in versus today receivers/speakers some feature 500 Watts plus -IMHO, just waste your money on electricity bill with them- tend to reproduce the sound of large concerts or a jet engine screams by your ears, you get synthetic high sounds, overly loud thumping bass but flat and muddy.
I have a $500 Pioneer receiver and $400 Sony Slim design floor standing tower speakers for upstairs, well, they do look fancy in the room.
Down in my basement, I bought a used Mitsubishi receiver ( before remote control was invented) and a set of old fashion large 14" X 23" Audio Logic speakers, all cost me $25. I plug in an Airport express ( $15 for a used one) and I can Airplay my iTunes, ipod touch iPhone playlists wirelessly from the other rooms.
At night when I chill out and want to listen to my fav music, I go to the basement to hear music from the old stereo set because they sound so much better and richer than the fancy looking stereo system upstairs. And that is $25 vs $900. smile.gif
Calgry is offline
post #12 of 36 Old 04-24-2013, 03:45 AM
Costanza's Avatar
All I know is when I went from an entry level Sony receiver to an entry level Harman/Kardon receiver, the difference in sound quality was night & day. The Sony sounded like a clock radio in comparison.
Costanza is offline
post #13 of 36 Old 04-24-2013, 04:14 AM
Bond 007's Avatar
Quoted: 2370 Post(s)
Liked: 1906
You will get very little difference (if any) in sound quality based on the receiver that you buy. And even at that it would not be because of the amplifier but would be because of better room correction software. Higher prices are for better features.
By far the biggest difference in sound quality you can invest in is the speakers you choose.
Licence to Kill
Bond 007 is offline
post #14 of 36 Old 04-24-2013, 01:07 PM
bizwiz41's Avatar
Quoted: 14 Post(s)
To answer your main question, the $1000 Pioneer will have the acoustic equalization feature. This will make it "sound" better because it will correct for any room acoustics issues. Other than that, sound quality will probably be not much different.
However, outside of sound quality, if you want 7.1 for movies, then you will need a newer AVR which will have HDMI connection that supports 7.1 sound. As said many times here in this thread, the "money" part is in the speakers. That is where you will pick up the sound quality improvement.
In the end, it is about "listening". Go to a few stores and audition different receivers. Keep the test simple, use the same speakers and media across the different AVRs to judge any difference.
Sometimes I have to remind myself that I bought all this "stuff" to enjoy it!
bizwiz41 is offline
post #15 of 36 Old 04-24-2013, 05:47 PM
johnBlanker's Avatar
Quoted: 410 Post(s)
Liked: 68
I just can't disregard the placebo effect. I was reading reviews about the Anthem mrx 300 and everyone just can't get over the sound quality, even before their ARC was tuned in. I wonder if people just have it in their heads that more expensive, high-end stuff (Anthem, Rotel, etc) have to sound good because they are so expensive, and the result is: they do, because they believe it. And I really think manufacturers play into this. (Monster cable anyone?) Is Anthem's amp a better sounding than my PIO's? This is not news by any means, just my 2 ¢.
johnBlanker is offline
post #16 of 36 Old 04-24-2013, 08:07 PM
grasshoppers's Avatar
Quoted: 802 Post(s)
Liked: 506
I have an Anthem MRX-300 and I agree with your post about the amp section.
Wasn't a night & day difference for me, BUT, ARC is a big time game changer.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is offline
post #17 of 36 Old 04-24-2013, 08:28 PM
Quoted: 410 Post(s)
Liked: 68
I really like the simplicity of the anthem 300. The 4 inputs is a real downer and the fact that I have to go to a specialty shop to get it. My experience with those places have not been good. They tend to stick their nose up at people if they are not dropping serious coin. They don't take kindly to returns either. Shame. I only have two stores on Long Island that deal anthem. I'm looking at the onkyo 818. Btw, didn't mean to say anything derogatory about anthem or rotel owners.
post #18 of 36 Old 04-24-2013, 09:42 PM
Quoted: 802 Post(s)
Liked: 506
^^^^^Sorry I got off topic.
Rythmik F12 subs
post #19 of 36 Old 04-25-2013, 06:47 AM
bizwiz41's Avatar
Quoted: 14 Post(s)
As a wise man once stated somewhere on this forum....."Listen with your ears, not your wallet......"
bizwiz41 is offline
post #20 of 36 Old 04-25-2013, 09:01 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
I have reviewed a number of service manuals for modern AVRs, and find that their schematics seem to not contain current limiters.
Here are some sample schematics from popular AVRs:
Onkyo NR 807
Onkyo NR 809
Could you provide an documented example of such a thing, or a technical test that conclusively shows such a thing in action?
arnyk is offline
post #21 of 36 Old 04-25-2013, 09:03 AM
arnyk's Avatar
Quoted: 851 Post(s)
Liked: 1238
The trick is listening with your personal biases and endemic systematic biases under control. For example, how many audiophiles have ever quick-switched between two level-matched AVRs?
arnyk is offline
post #22 of 36 Old 04-25-2013, 06:04 PM
Quoted: 410 Post(s)
Liked: 68
AVR's have to be one of the hardest things to demo. Online is out since you usually have to pay return shipping, excluding Amazon or Newegg, and you obviously can't demo online. B&M stores/custom shops might give you hassle or inflict restocking fees. This usually leaves you with best buy. I am generalizing. Any store is not going to sound like your living room with your speakers. Once you get it home, hook it all up, figure out how it all works, dial it in, who wants to go through all the work returning the thing?
post #23 of 36 Old 04-25-2013, 08:49 PM
Yosh70's Avatar
Quoted: 172 Post(s)
Liked: 126
I don't think I ever demo'd a receiver.....ever. Really, whats the point? Pick a couple of AVR's that interests you, check the specs, read some reviews online and make up your mind.
The things I've always considered are features and reliability and of course, within budget.
Now with room correction systems applied almost to all receivers, thats another thing to put on my short list.
Yosh70 is offline
post #24 of 36 Old 08-03-2014, 12:52 PM
Liked: 0
I have bose speakers 6.1 [2cubes together * 3 and 1 woofer] model is Acoustimass 7 computable with amplifier or receiver rated 10-200w/channel - 8 OHMS.
I have a denon receiver AVR-1000.
Vintage mid '90s Denon AVR-1000 A/V stereo receiver with Dolby Surround Pro Logic.
70 watts/channel; right + left front, center, rear right/left rear speaker outputs; 1 each switched/unswitched power outlets; Master Volume, Balance, Treble, Bass, Tape Monitor, Tuning, 16 preset station memory, Surround Bypass and Mode, Dolby Center Mode, 3 Channel Logic, Video Select and Output controls; 1/4 inch headphone jack; measures appr. 17" W, 11 3/4" D, 5 1/2" H; all lights fully functional; screen display clean; made in Japan.
Wire I am using is local not sure it is thick enough as in how much gauge may be 16 or 14.
Also the wire I am using to connect TV to Receiver is local purchased from dollar store (Audio cable one is to two)
The sound it produce is not crisp or I am not happy with it does not decently feel like bose.
What should I change or do make it better ?
Should I change the AVR (it is old does not have HDMI)
I have attached picture of them
Sam
ID:	194969   Click image for larger version
ID:	194977   Click image for larger version
sambhav is offline
post #25 of 36 Old 08-03-2014, 01:29 PM
Quoted: 266 Post(s)
Liked: 148
Well, IMO you can do better than Bose speakers. I suspect there's some limitations in the design of the super small sat with how their bass system works. It's ok sounding, I had a friend with a Bose setup, but I think there's better out there for similar price or cheaper.
But if you like the speakers it's hard to say if the fault like with the receiver. I don't expect dramatic differences in sound by switching receivers. You can get more powerful receivers but know that it takes double the power for a significant jump in SPL. Newer receivers can have better room correction systems which attempt to correct for room acoustics which can help.
You could shop for receivers, and/or also consider getting a quality power subwoofer and a good set of bookshelf speakers.
I helped a friend buy some speakers and a sub for his setup and the price was in the 1k range. So it's not cheap but the results were ok.
post #26 of 36 Old 08-03-2014, 01:52 PM
fatbottom's Avatar
Quoted: 1420 Post(s)
Liked: 518
Sam
Change the Bose. Changing the AVR will do nothing.
arnyk likes this.
fatbottom is offline
post #27 of 36 Old 08-03-2014, 07:01 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
Actually changing the AVR will help. Your very old Denon only does Dolby Surround Pro Logic. No room calibration either. And no dedicated subwoofer channel.
It can't do Dolby Digital 5.1 or DTS at all, no digital inputs. Not even Pro Logic II. So a receiver upgrade would make a pretty big difference, especially if you're using it for home theater. You guys that are telling him the receiver will make no difference must think he has the current x1000 Denon. He does not.
Just think what a nice upgrade having discrete 5.1 channels is over early Dolby Surround. And we're not even talking TrueHD or DTS-MA with Blu Ray.
Your Bose speakers still are a weak point but a more current receiver will make a difference.
How much are you willing to spend to upgrade your receiver and speakers?
arnyk likes this.
Afro GT
afrogt is offline
post #28 of 36 Old 08-03-2014, 07:42 PM
Liked: 0
Thanks afrogt and fat bottom for the reply.
afrogt ---> I am willing to spend $200 more, or should I sell the whole speaker and receiver for $200
and add another $200 so then my budget will be $400 and buy something much better ? Or I am dreaming of getting bose speaker and receiver for $400 ?
-Sam
sambhav is offline
post #29 of 36 Old 08-03-2014, 07:50 PM
Liked: 0
Thanks MichaelJHuman,
I am not sure I want to spend 1k right now. But I am thinking of upgrading the receiver and see how it behaves if still I don't see the difference then as you said i may have to replace the whole set. How much will be a decent reciver cost
Will their be any available in $200 range ?
sam
sambhav is offline
post #30 of 36 Old 08-03-2014, 08:07 PM
turnne1's Avatar
Quoted: 1754 Post(s)
Liked: 410
generally speaking
I think Anthem is higher end than Rotel
But...I may be thinking of either companies separates and you may mean strictly AVR's
I would disagree with what some of the others have said about being able to hear a difference in AVR's
I absolutely think you can...just like you can see a difference in a higher end TV
though some say they cant see the difference there either
even minus the extra features...which you typically get these days in midrange AVRs
The higher end AVR's just sound a lot better.....I did an exercise with a 1K AVR and 3K one
no room correction enabled because I wanted to listen to some instrumental jzz that I use as a reference disc
The clarity on guitar and piano passages was very different
Clearer ..more detailed and no edginess in the tone
The louder I played it the more obvious the difference was
Was that because of the speakers I was using?..maybe
There is a difference even among AVR's in the same price point
Though its more a of a characteristic sound quality than one that is better or worse
I did the same exercise with an A3000 and Onkyo 875...pluses and minus for both in the sound department and I could see...depending on preference...why one could prefer one over the other
I owned both at the same time...both great...just different
Warren
Rm 1 Samsung 64F8500 Marantz 8801 prepro Sherbourn 5/1500A amp B&W CM10s..CM2 center...CM5's.rears
Rm 2 Hisense H50C Yamaha A2050 Celestion 305 speaker system
Rm 3 Panasonic 50ST50 Denon4520 Kef 2005.2 speaker system
Rm 4 Samsung 51E8000 Sony DA5400ES Mirage Omni sat speaker system
turnne1 is online now
