The "Official" Onkyo TX-NR3009 Owners Thread - Page 31 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #901 of 965 Old 03-21-2014, 04:50 PM
vodil's Avatar
Quoted: 85 Post(s)
Liked: 27
Originally Posted by SeekingNirvana View Post
This is kinda a cross post as I posted over in the Oppo 103 thread, but i'm curious if any one is running any Oppo player with the 3009? Im curious is the DAC's in the Oppo are superior. Right now I have a PS3 as my blu-ray and CD player, but I am letting the 3009 do all the processing. Is anyone out there letting the Oppo do the processing, and if so.... is there a improvement in either picture or sound. I know the 3009 has good DAC's and processors and i would hate to buy a $600 + player only to find out that the PS3 and 3009 combo are on par with the Oppo and 3009. /quote]
I have an Oppo 103d with my 3009, which has Darbee video processing in it. I let the Oppo do the video processing of all the signals but the 3009 do all the audio processing. The Onkyo is the switch and the Oppo can then process the video from it for TV, PS3, etc. I too have a PS3 which was once my Blu-ray player, but Oppo is superior in all ways for playing any l disks.
JS9500, MRX1120, Oppo 103D, XboneS, DirecTV, Harmony Hubs
vodil is offline
post #902 of 965 Old 04-03-2014, 05:50 AM
Tsunamijhoe's Avatar
Quoted: 85 Post(s)
Liked: 27
I own a 3009 and would like to add an Emotiva XPA-5 to drive my fronts,front wide and center only, while subwoofer and side surround,rear surround would still be controlled by the onkyo.
Would this work? Or should i go all the way,and run pre-out on everything?
Marantz 7702, Emotiva XPA-5,Emotiva XPA-2,Densen B-340+,B&W 683,B&W HTM61,B&W DS3,SVS PB-2000,Monitor Audio BX1 (Atmos),Sony VPL-HW65ES,Stewart 123" CIMA Neve Motorized, Dune HD1, Popcorn Hour A-210, Mede8er x600 3D,Panasonic BD60,PS4
Tsunamijhoe is offline
post #903 of 965 Old 04-28-2014, 01:21 PM
SeekingNirvana's Avatar
Quoted: 233 Post(s)
Liked: 124
I know this thread is pretty much done but I'm hoping someone can answer this question....
Can you configure the sub outs independently?
For example have sub1 with audyssey on and sub2 with audyssey off.
I ask because I am looking into getting some Crawson transducers and I need to send them a signal not effected by any type of room correction.
I'm don't think you can configure separately, but I hope. My other Option is to buy a Oppo and use it's sub out, but that's $500 I don't really want to spend.
My dual sealed LMS 5400 Ultra build
http://www.avsforum.com/forum/155-di...0-build-4.html
SeekingNirvana is online now
post #904 of 965 Old 04-28-2014, 04:07 PM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
This thread will be active as long as there are people using these receivers.
To answer your question, no.
Onkyo TX-NR3009 - Emotiva XPA-2 300 WPC - Polk Audio RTiA9 Mains - CSiA6 Center - F/XiA6 Surrounds - Dual PSA XV-15se Subwoofers - Epson 5030UB Projector - Monoprice Multi-format 106" HD Gray screen - Samsung BD-F5900 3D Bluray - WDTV Live HD Media Player with 6TB External Storage - Nintendo Wii - XBox 360 - Logitech Harmony One, and custom DIY media console...
climber07 is online now
post #905 of 965 Old 04-28-2014, 05:17 PM
Quoted: 233 Post(s)
Liked: 124
I understand how these forums work....maybe I should have worded it differently
I know this thread isn't very "active" anymore but.........
As for answering my question. Thanks
post #906 of 965 Old 04-28-2014, 05:26 PM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
No problem brother. I am still learning new things about my NR3009. One of which is how the distance is calculated for DSP controlled subwoofers... biggrin.gif
post #907 of 965 Old 04-28-2014, 11:51 PM
Quoted: 233 Post(s)
Liked: 124
Taking about latency? The delay of the signal running through the processor? Are you trying to get your sub to blend better with your mains?
post #908 of 965 Old 04-29-2014, 12:14 AM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
Yes. I was unsure why Audyssey set my speakers 4 feet farther than they actually are. Tom V from PSA explained it in a post.
post #909 of 965 Old 04-29-2014, 08:59 AM
Quoted: 233 Post(s)
Liked: 124
Some receivers/pre-pros don't use feet, instead they use milliseconds. Basically it just measures the delay for the signal to travel through all the circuitry. If you are having trouble blending your subs you can try adjusting this setting manually. It helps if you have a measurement software like REW, to see if it is making a difference.
post #910 of 965 Old 04-29-2014, 09:48 AM
nismo604's Avatar
I only run one sub and use the sw2 out for my buttkicker. After running audyssey you enable the sw2, remember you don't run the transducer during the calibration process. I'm guessing since audyssey didn't detect a second sub no filters are applied. The distance and trim are fully independent of sw1. Under this setup I had to set the trim to the lowest possible setting to prevent my buttkicker from bottoming out.
SeekingNirvana likes this.
nismo604 is offline
post #911 of 965 Old 04-29-2014, 10:00 AM
Quoted: 233 Post(s)
Liked: 124
Hmmm that sounds like it could be true......by any chance, do you have REW?
post #912 of 965 Old 04-29-2014, 10:02 AM
nismo604's Avatar
Sorry no REW.
nismo604 is offline
post #913 of 965 Old 04-29-2014, 10:18 AM
Quoted: 233 Post(s)
Liked: 124
I'll have to wait until I'm done building my subs to test it out. I'll do like you said....only have one sub hooked up during audyssey, then measure each sub out to confirm that audyssey didn't apply any filters to sub2. It sounds logical....
post #914 of 965 Old 04-29-2014, 05:36 PM
gem1201's Avatar
I am retired and work for Onkyo and also sold their products retail. Dont worry about the heat. Its not a problem. A lot of R&D goes into the product before a decision is made.
gem1201 is offline
post #915 of 965 Old 05-17-2014, 03:14 PM
mavericks64's Avatar
My Net feature stopped working (Pandora, Spotify, etc.). When I choose the Net feature the front display goes blank instead of saying "Net." Any suggestions or ideas. I checked the ethernet cable in back and it seems firmly attached on both ends.
Sharp 80-inch 3D LED TV
Onkyo TXNR3009 Receiver
Paradigm Reference Studio/100 v.2 front speakers Paradigm Studio CC-690 center-channel
Paradigm CI Pro P80-IW Surrounds
Paradigm Monitor 9 back speakers
FV15HP Rythmik subwoofer
mavericks64 is offline
post #916 of 965 Old 05-17-2014, 09:29 PM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
I would suggest a firmware update first. Onkyo support forum may also mention something about your issue. If not, send them an email.
post #917 of 965 Old 05-22-2014, 03:56 PM
Kamikaze13's Avatar
Quoted: 100 Post(s)
Liked: 49
Originally Posted by btinindy View Post
Hmmmm, mine was never there for longer than a week for an HDMI Board.
Hopefully they were just under promising so they can over deliver!
VIDEO: JVC DLA-RS57U Projector / 122″ EluneVision Reference Studio 4K Cinemascope Screen - Oppo BDP-103 Blu-Ray Player - PlayStation 3 AVR: Anthem MRX-1120 SPEAKERS: Paradigm Monitor 11 Mains - Paradigm Monitor CC-390 Center - Paradigm Monitor ADP-390 Surrounds x 4 - Polk MC60 Atmos Ceiling x 4 SUBWOOFERS: SVS PB2000 / Velodyne DPS-12
Kamikaze13 is offline
post #918 of 965 Old 05-23-2014, 10:52 AM
Jon S's Avatar
Quoted: 797 Post(s)
Liked: 259
You guys were lucky... I had to pay for my repairs.... twice!!! Plus shipping in Hawaii.
If it's not a BIG screen, it's not a theater...
Jon S is offline
post #919 of 965 Old 05-27-2014, 11:09 AM
DblHelix's Avatar
Got my 5009 back from repairs and it is working. One issue I still have and no one really seems to mention is it will occasionally lock up and the fix I have used is to unplug it and then plug it back in and it works every time, but anyone ever get an answer from Onkyo why it locks up on changes in HDMI. It usually happens when I change the channel on my tivo.
DblHelix is offline
post #920 of 965 Old 06-15-2014, 11:02 AM
vodil's Avatar
Quoted: 85 Post(s)
Liked: 27
I Quit
I have been using Onkyo from the days I bought my first 706. I think I have had 4 different models. I like the features and the value, but I just can't take the reliability any more.
I just had to send my 3009 into the shop. Onkyo blew it because I still have 4 weeks left on the warranty...fortunately for me. But enough is enough. [I have kept around my venerable 706 as an emergency substitute for the many (well, 4) times I have had to send Onkyos in for repair.]
I had foolishly thought when I stepped up to a 4-digit model, I would not have to worry about reliability as much. Anyway I am going to sell my 3009 once it is officially fixed and try to find something that I don't have to worry about. I was thinking of going to Denon/Marantz, but would take any recommendations.
vodil is offline
post #921 of 965 Old 06-26-2014, 08:00 PM
Quoted: 233 Post(s)
Liked: 124
Anyone know if you can add a delay to zone 3? I have some Klipsch AW-650's in the back yard on zone 3, and when I'm in my kitchen (between backyard, and living room) there is a big delay in sound. The zone 3 speakers are at least 1/2 a second early......I would like for them to sound the same
post #922 of 965 Old 06-26-2014, 09:07 PM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
No. Same source on multiple zones is at the mercy of distance and the speed of sound.
post #923 of 965 Old 08-19-2014, 04:10 PM
Liked: 0
I have all 11 speakers plus the 2 subs connected but I can only get sound out off 9. Either the high and wide with no rear surround or wide or high with rear surround. Is there a way to get all 11 speakers working? Even with all stereo I only get 9. What am I doing wrong?
Mike
Mrobles is offline
post #924 of 965 Old 08-19-2014, 05:20 PM
candoan's Avatar
Quoted: 13 Post(s)
Smile
Mike
Hi Mike,
I believe that this reliever is:
Onkyo TX-NR3009 9.2-Channel Network A/V Receiver
http://www.amazon.com/Onkyo-TX-NR300...rds=onkyo+3009
I hope that help.
Pana 60ST60, Onkyo TX-NR3009, OPPO BDP-103, Klipsch WF-35, Klipsch WS-24, Klipsch WC-24, Klipsch Reference RW-12d, BIC America DV62si.
candoan is offline
post #925 of 965 Old 08-19-2014, 07:48 PM
Liked: 0
Yes it is but it shows the 11 speakers for 9.2. In the manual on page 12
Mrobles is offline
post #926 of 965 Old 08-19-2014, 08:08 PM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
Page 51 talks about front height and wide as well as surround back. You can't use both at the same time. Only 9.2 works, however you can configure up to 11 speakers. Just not all at the same time.
candoan likes this.
post #927 of 965 Old 08-20-2014, 03:35 AM
candoan's Avatar
Quoted: 13 Post(s)
Smile
I do not have the manual with me right now but I remember that if you want to have 11.2 you need to have another stereo receiver. Maybe there are 11.2 peramp outlet then..
candoan is offline
post #928 of 965 Old 08-22-2014, 11:45 AM
RoedeOrm's Avatar
Hi good people of AVS Forum!
First post in +10 years, about time. Anyway, a maybe simple question for some of you but not for me - I want to use a separate amplifier (already in place, a Bladelius TYR II with bypass) for the front speakers (FL and FR), how do I go about to do that? The manual does not help very much, except for how to use an additional amp for all channels (while I only want a separate amp for two channels).
Any help would be much appreciated, thanks!
Best regards,
Karl
RoedeOrm is offline
post #929 of 965 Old 08-22-2014, 12:31 PM
JKR1963's Avatar
Quoted: 191 Post(s)
Liked: 88
the 3010 and 5010 can become 11.2 with an external two channel amp...........the 3010 and 5010 are capable of processing the front high and front wide and back surround channels all at once the 3009 and 5009 can only process up to 9.2......extra amp's won't help an 09 as it is a processing capability issue.
candoan likes this.
JKR1963 is offline
post #930 of 965 Old 08-22-2014, 02:09 PM
climber07's Avatar
Quoted: 332 Post(s)
Liked: 1335
Best regards,
Karl
Simply disconnect the speaker cables for your front L/R speakers from the AVR, then connect an RCA cable from the front L/R pre-outs of the AVR to the correct inputs on the amp. Then connect your speaker wires to the amp speaker outputs. Viola!.
Onkyo , Onkyo Tx Nr3009 , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , The Fifth Element Remastered Blu Ray , Onkyo Ht Rc160 7 2 Channel A V Surround Home Theater Receiver
