The "Official" Onkyo TX-NR3009 Owners Thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 8Likes
post #181 of 965 Old 07-13-2012, 04:02 AM
mgp
mgp's Avatar
Got my 3009 from Vann's today. It;s replacing a TX-DS989 ver 2.
Sharp Elite Pro-70x5fd Display
Panasonic DMP-BDT220
Onkyo TX-NR3009 Receiver
Emotiva XPA-5 Amp
Sony PS3
Triton 2 L/R
SCXL Center
SS50 Surround
SS3 Rear
SVS SB13-Ultra Sub
mgp is offline
post #182 of 965 Old 07-13-2012, 08:13 AM
TazExprez's Avatar
Hey, I have a TX-DS989 upgraded to Version 2. I am thinking of replacing it with either a TX-NR818 or a TX-NR3009. Let me know how you like your new TX-NR3009 in comparison to the TX-DS989 Version 2. I really like my TX-DS989, but I want to use the new surround formats. Thanks for any help.
HD-A1 + XBOX Add-On + PS3 = Format Neutral
TazExprez is offline
post #183 of 965 Old 07-15-2012, 01:38 PM
mgp
mgp's Avatar
So far, so good. Outstanding receiver. I've noticed there is no OSD without a video souce. Is this correct? When I am streaming my music lib from my pc it would be nice to see what i am selecting without having to get up and look at the receivers display.(My equipment is in a dedicated closet with front/back access).
I did go and get a cheap laptop cooler(coolermaster notepal x-slim) to help cool the beast.
Overall one of the best purchases i've made in a long while. I noticed Vann's is now out of stock, i'm glad i jumped when i did.
Emotiva XPA-5 Amp
Sony PS3
Triton 2 L/R
SCXL Center
SS50 Surround
SS3 Rear
SVS SB13-Ultra Sub
mgp is offline
post #184 of 965 Old 07-15-2012, 02:36 PM
freeyayo50's Avatar
There is OSD for video source. You may have to turn it on in setup under miscellaneous. When you switch video source, it will show on screen. Is at what you mean?
AVR: Onkyo 3009...Onkyo 609 (Old)
Amp: QSC GX5 (powering RTi A7s) & GX3 (powering CSi3)
Speakers:
Polk Audio CSi3 (Center)...CS1 (Old)
Polk Audio RTi A7 (Fronts)...Monitor 60 (old)
Polk Audio OWM 5 (Surrounds)
Sub: SVS PC12-Plus...BIC America PL-200(Old)
freeyayo50 is offline
post #185 of 965 Old 07-15-2012, 05:54 PM
mgp
mgp's Avatar
No, I know the OSD works with a video source, I wish is worked without requiring a video src. On my old 989 i had OSD without any video source running.
Emotiva XPA-5 Amp
Sony PS3
Triton 2 L/R
SCXL Center
SS50 Surround
SS3 Rear
SVS SB13-Ultra Sub
mgp is offline
post #186 of 965 Old 07-16-2012, 09:01 AM
nikerret's Avatar
Quoted: 43 Post(s)
Liked: 34
I see there are eleven speaker cable outputs, on back. I understand the amp can only power nine channels. Does this mean I can hook up all eleven channels for the main room (fronts / center / surround / back surround / front wide / front height) and just switch them, on the fly, for the nine speakers I choose to use?
Also, can the processors do all eleven channels if I were to use an externl amp for the fronts and the nine internal channels for the rest (center / surround / back surround / front wide / front height)?
I'm thinking about picking one of these up soon, as the new models are about out.
My understanding is the Denon 4311 will do the processing with an external amp for the fronts and the nine channel internal for the other channels.
I would be upgrading from a TX-SR608. I was going to upgrade to a Pre and all seperates, but it seems like the best option ($) is to use the internal amp from a good receiver for the surrounds (and I want a bunch of them!)
nikerret is offline
post #187 of 965 Old 07-16-2012, 10:58 AM
fuzz092888's Avatar
Quoted: 40 Post(s)
Liked: 100
Yes
Yes
fuzz092888 is offline
post #188 of 965 Old 07-16-2012, 04:00 PM
flint350's Avatar
Liked: 38
Let me disagree with Fuzz's response on a couple of things.  Yes, you can hook up all 11 channels but No, you cannot easily switch them all on the fly, just some.  For example - you can use the 'speaker setup' to switch btwn FW/SB or FH/SB, but you cannot select FH/FW like that.  You actually have to disconnect the SB speakers and re-configure the wides to those outputs.  It takes going into the setup menu and selecting btwn "FW/FH-Both" OR FW/SB and FH/SB.  Also, since the processor decodes up to 9.2 channels, it won't matter if you connect a separate amp, you will not get 11.2 output.  The 11 speaker connections are for choosing btwn the mentioned setups of 9 channels - there is no functionality to run 11 channels, even with external amps.
Ray
"You cannot reason a person out of a position he did not reason himself into in the first place." -Jonathan Swift
flint350 is offline
post #189 of 965 Old 07-18-2012, 08:12 AM
pukemon's Avatar
Quoted: 279 Post(s)
Liked: 71
Hmmmm...
butter and jelly please...
Home theater gladly not designed by ereed or bgtighe23. 65" JS9500, Marantz 7702MKII, Parasound Halo A31, ClassDaudio SDS470 4ch, RBH R56, 4xRBH R55, 2x RBH R5, Hsu VTF 2 MK 3 and VTF 3 for subwoofage, OnStage MS7701B mic stand with boom for improved Audussey XT32 calibrations. Listening space happily treated with 1" OC 703 rigid fiberglass. OPPO 203 or 205 soon.
pukemon is offline
post #190 of 965 Old 07-18-2012, 01:04 PM
cablebandit3's Avatar
Quoted: 23 Post(s)
Onkyo is supposed to be replacing my faulty 3007 with the 3009 and I cant wait based on some of the feedback here. I always thought the 3007 sounded great (except in 2 channel mode). I already have the coolermaster massive23 fan mentioned in this thread. I got a new plasma tv this weekend and boy does tv sound just SUCK!
cablebandit3 is offline
post #191 of 965 Old 07-18-2012, 08:34 PM
pukemon's Avatar
Quoted: 279 Post(s)
Liked: 71
Why is the 3009 worth $300+ more than the 818?
pukemon is offline
post #192 of 965 Old 07-18-2012, 08:51 PM
coppertop's Avatar
simple answer...SUB EQ. Worth $300 on it's own. Plus 9 channel amp...and a bunch else. There is some advantages to the 818 like the thumbnail source preview. But for $300, the SUB EQ and 9 channel amps are the key differences.
freeyayo50 likes this.
coppertop is offline
post #193 of 965 Old 07-18-2012, 08:58 PM
joerod's Avatar
Quoted: 612 Post(s)
Liked: 492
Great answer.
My Sony 5000ES Review PART 2 FINISHED:
http://hstrial-jrodriguez996.homeste...=1462841668379
joerod is online now
post #194 of 965 Old 07-18-2012, 10:14 PM
TazExprez's Avatar
If I have a 7.1 system, would it be worth it for me to get a 3009 over an 818? I am replacing an "ancient" TX-DS989 upgraded to Version 2 and I mostly watch movies at or near reference levels. I may even consider getting a 5009, if it goes down a bit more in the next couple of weeks.
post #195 of 965 Old 07-19-2012, 06:17 AM
apelbaum's Avatar
nope , subeq is for 2 or more subs , you have only one and 3009 have 9 channel amp and you have only 7.
if you dont want to go 7.2 or 9.1 do not worth
apelbaum is offline
post #196 of 965 Old 07-19-2012, 06:34 AM
jdsmoothie's Avatar
Quoted: 12214 Post(s)
Liked: 5562
Not addressing the additional 2 amps, but the Sub EQ HT feature is only worth it if you have multiple subs (or want the option to add a sub in the future) AND you don't plan on placing them equidistant from the MLP and level matching them prior to using XT32, otherwise, there's no benefit.
jdsmoothie is online now
post #197 of 965 Old 07-19-2012, 12:27 PM
coolcat4843's Avatar
Quoted: 279 Post(s)
Liked: 105
How would you add (hook up) 4 subwoofers to the 3009.
2 SVS PB12-NSD subs (ported) and 2 BIC America F12 subs (sealed).
Because of my small home theater, the only place that I can put all 4 subs is against the front wall.
The PB12's are in each corner and the F12's are located closer to the center of the wall, spaced equally apart.
Again all four subwoofers are spaced equally across the front wall.
Benq W1080ST DLP 3D Projector
Sony BDP-S5200 3D Blu-ray Player
Onkyo TX-RZ1100 Dolby Atmos/DTS:X 9Ch. Network Receiver
Pioneer SP-FS52 Tower Speaker x 4
Pioneer SP-C22 Center Channel Speaker
PSA XS15se Subwoofer x 4
coolcat4843 is offline
post #198 of 965 Old 07-19-2012, 01:48 PM
TazExprez's Avatar
I am considering the 3009, and maybe the 5009, simply for the better amp section. I was wondering if it would be worth it for a 7.1 system if I like to listen to my system at or near reference levels give or take 5 to 10 dB.
post #199 of 965 Old 07-19-2012, 01:51 PM
freeyayo50's Avatar
You would need two split Interconnect cables. One would would go from sub1 connection to each of the PB12s and the other connected to the sub2 connection to the F12s. This way the equalizer will work better when the pairs are at the same volume.
Speakers:
post #200 of 965 Old 07-19-2012, 01:57 PM
apelbaum's Avatar
ask for joerod. if I remember correctly he owned both and found that it was not worth the difference in 3009 to 818
apelbaum is offline
post #201 of 965 Old 07-19-2012, 02:14 PM
Quoted: 279 Post(s)
Liked: 105
The owners manual says to adjust the volume dial on the back of each sub to 75db,
before running Audyssey.
Is this what you did?
post #202 of 965 Old 07-19-2012, 03:41 PM
freeyayo50's Avatar
Yes thats what I did for my two subs. I actually ran them a little hotter at 80db. But yes make sure each pair of subs together are 75db. Try and make it so the PB12s are at the same volume level at the dial to reach 75db. Same with the F12s.
When running Audyssey it allow you to level out the subs with a test tone. Try it out.
Speakers:
post #203 of 965 Old 07-19-2012, 03:55 PM
Quoted: 279 Post(s)
Liked: 105
post #204 of 965 Old 07-19-2012, 06:43 PM
joerod's Avatar
Quoted: 612 Post(s)
Liked: 492
Actually if you only have one sub it is not worth it. Two or more go 3009 or 1010.
post #205 of 965 Old 07-21-2012, 03:18 AM
mgp
mgp's Avatar
For me, 2 reasons:
1) I have 2 subs and needed eq for both.
2) I use an MK750 surround system, LCR and L/R Surrounds are 4 ohm nominal impedance(Only Back surrounds are 8 ohm). I wanted the extra power.
Emotiva XPA-5 Amp
Sony PS3
Triton 2 L/R
SCXL Center
SS50 Surround
SS3 Rear
SVS SB13-Ultra Sub
mgp is offline
post #206 of 965 Old 07-21-2012, 03:59 AM
vmanuelgm's Avatar
Originally Posted by vmanuelgm View Post
Hello, I have an onkyo 5009, connected to a pc and a Pioneer p50vt30.
I am having strange click sounds (not classical click from Onkyo) when I use hdmi from my gtx 680 graphic card (nvidia), windows 7 media player and high volume (stereo or all channels stereo), with mp3 or wma archives. If I use optical, no problem.
The click sounds come from 5009 when I use high volume, from 65 to 85, and are more audible when the volume is higher.
If I use optical input, there is no click sound, so it has to do with hdmi circuits.
In spite of click sounds in the onkyo, the receiver works correctly, and gets hotty too..
Anyone having this trouble?
EDIT: I have the same problem with optical, but the click is more random and less audible. It seems has to do with heat..
I answer myself. I have placed a notebook cooler over the 5009 and now the clicking sounds have gone. It was a heat issue, when playing stereo biamp at high volume...
PC LGA 2011 Intel 3930K C2 Onkyo 5009 2xMonitor Audio GX300 Biamp Kef XQ50C 2xKef XQ10 Rel R-205 Sub Panasonic P50VT30
vmanuelgm is offline
post #207 of 965 Old 07-21-2012, 08:53 AM
freeyayo50's Avatar
Strange, I never have any sort of heat issue when playing that loud for extended times. What is the ambient temperature like in the room?
Speakers:
post #208 of 965 Old 07-21-2012, 11:06 AM
Quoted: 279 Post(s)
Liked: 105
Just placed my order for the 3009 from OneCall a few minutes ago. Noticed that Amazon has sold out of 3009's, so I thought I better jump on the similar deal at OneCall. Seems like the remaining 3009's are flying off the shelves now that the price has dropped so low.
post #209 of 965 Old 07-21-2012, 11:08 AM
joerod's Avatar
Quoted: 612 Post(s)
Liked: 492
post #210 of 965 Old 07-21-2012, 11:21 AM
Quoted: 279 Post(s)
Liked: 105
Doesn't the 3009 come with built-in twin fans, like the 818? If so, why the need for an external fan? Also, shouldn't the fan be mounted underneath the unit, instead of attaching a fan to the top, blowing dust and dirt into the receiver and possibily damaging the internal circuitry?
Onkyo , Onkyo Tx Nr3009 , Transformers Dark Of The Moon Three Disc Combo Blu Ray 3d Blu Ray Dvd Digital Copy , The Fifth Element Remastered Blu Ray , Onkyo Ht Rc160 7 2 Channel A V Surround Home Theater Receiver
