Budget receivers with analog to HDMI conversion - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-01-2011, 05:26 PM - Thread Starter
RyanD's Avatar
I'm looking for a receiver in the $300 range with analog to HDMI conversion. I also want it to have the HDMI audio return channel. I'll only be using it for 2 speakers and possibly a subwoofer.
Here are a few that I've found that would work:
Pioneer VSX-32
Sony STR-DN1010
Sony STR-DH820
Yamaha RX-V571
I'm sure there are others. Please send your suggestions.
RyanD is offline
post #2 of 9 Old 11-02-2011, 03:46 AM
jdsmoothie's Avatar
Quoted: 15319 Post(s)
Liked: 7474
Check your local area Best Buy stores as you should be able to get last year's Denon 1611 (Audyssey MultEQ) on clearance below your budget and will meet your requirements.
jdsmoothie is online now
post #3 of 9 Old 11-02-2011, 08:26 AM
Sonyad's Avatar
Quoted: 194 Post(s)
Liked: 111
Also the Sony dh810. Usually $200.
Sonyad is offline
post #4 of 9 Old 11-02-2011, 09:51 AM
afrogt's Avatar
Quoted: 1432 Post(s)
Liked: 982
Denon AVR 591 and 1611. No video upscaling but will convert analog video to HDMI. Also uses HDMI 1.4 for 3D capability and Audio Return.
Denon 1611 can be found at Vanns in your price range. Also check local Best Buy's for clearance sales.
http://www.vanns.com/shop/servlet/it..._c=site_search
I would take the Denons over any of the receivers mentioned above. Actually I own the Denon 591.
Afro GT
afrogt is offline
post #5 of 9 Old 11-02-2011, 02:36 PM - Thread Starter
RyanD's Avatar
The Denon 1611 looks good except for the small number of analog inputs. Most other receivers have at least 2 component video inputs.
What about the Onkyo HT-RC360? It has a very similar feature set with more analog inputs. It only has Audyssey 2EQ though.
The Pioneer VSX-921K would work also.
RyanD is offline
post #6 of 9 Old 11-02-2011, 03:24 PM
jdsmoothie's Avatar
Liked: 7474
post #7 of 9 Old 11-02-2011, 03:55 PM - Thread Starter
RyanD's Avatar
Yeah, I already have one of those. It's glitchy, and I'd rather not use it.
RyanD is offline
post #8 of 9 Old 12-10-2012, 08:22 AM
Teletodd's Avatar
what is the benefit of analog to hdmi conversion?
Teletodd is offline
post #9 of 9 Old 12-10-2012, 09:25 AM
JHAz's Avatar
Quoted: 307 Post(s)
Liked: 275
AFAIK, just that you only need an HDMI connection from receiver to TV/projector (HDMI doesn't pass analog).
JHAz is offline
