Any way to edit EQ band with Audyssey enabled?(Denon 891) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-12-2011, 09:57 AM - Thread Starter
revenicus's Avatar
I like how it sounds, except the lowest range I need to dial down for neighbors' sake(My system is one pair of CF-70s). However I don't see a manual EQ option when I have audyssey enabled, also the tone adjustment option for bass and treble is gone with audyssey enabled. Is there any way to do it?
revenicus is offline
post #2 of 6 Old 11-12-2011, 10:04 AM
primetimeguy's Avatar
Quoted: 556 Post(s)
Liked: 359
Does your receiver have Dynamic EQ? If so turn that off and your bass will be reduced.
primetimeguy is offline
post #3 of 6 Old 11-12-2011, 10:04 AM
Kal Rubinson's Avatar
Quoted: 674 Post(s)
Liked: 460
Sorry, no.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #4 of 6 Old 11-12-2011, 10:19 AM
jdsmoothie's Avatar
Quoted: 12094 Post(s)
Liked: 5504
For more questions on your AVR, join us in the Denon AVR-891 Owner's thread.
jdsmoothie is offline
post #5 of 6 Old 11-12-2011, 10:28 AM - Thread Starter
revenicus's Avatar
I do but it pretty much cuts out bass way more then I want it to.
Originally Posted by Kal Rubinson View Post
Sorry, no.
Dang.
I think I'll just fool with manual EQ, It's just a shame they don't let you edit the EQ. I'm able to see it, just can't edit it
Cool, will do
post #6 of 6 Old 11-12-2011, 04:46 PM
jdsmoothie's Avatar
Liked: 5504
Note that what you can see is a very crude EQ representation which actually can be edited using the "Manual EQ - Adjust CH" and "Manual EQ - Base Curve Copy" settings (p. 53); however, doing so disengages the Audyssey filters.
You might also want to try adjusting the "Reference Level Offset" setting (p. 52) to 10db which will reduce the added bass effect as well as improve center channel dialog for TV and music sources.
