Optical input or HDMI - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-04-2011, 07:59 PM - Thread Starter
Hannzz's Avatar
Quoted: 20 Post(s)
Hi Guys:
I have yamaha a2000. I am wondering weather Optical cable would produce better sound quality or HDMI cable. Please comment. Thanks
Hannzz is offline
post #2 of 6 Old 12-04-2011, 08:08 PM
Kal Rubinson's Avatar
Quoted: 682 Post(s)
Liked: 461
Optical cannot handle high resolution audio.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #3 of 6 Old 12-04-2011, 08:24 PM - Thread Starter
Hannzz's Avatar
Quoted: 20 Post(s)
Thanks, I ordered HDMI cable. Somehow I was under the impression since optical cable has light means less resistance and hence better sound quality. I guess I was wrong.
Hannzz is offline
post #4 of 6 Old 12-04-2011, 08:31 PM
Tulpa's Avatar
Liked: 61
Optical is immune to RF interference, but most quality cables are shielded enough for that to be a non-factor. Not sure where resistance came from.
HDMI enables the lossless audio from blu-ray discs to be used, which as Kal said can't be used with optical. For DVD playback, HDMI and optical will be the same using legacy Dolby Digital and DTS 5.1 lossy codecs. But HDMI carries audio and video, so there is usually no need to use an optical cable with whatever playback device you're using.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
post #5 of 6 Old 12-04-2011, 08:34 PM
Joeforsale's Avatar
Here's a pretty good explanation of the limitations: http://solidlystated.com/hardware/hd...s3-or-blu-ray/
Joeforsale is offline
post #6 of 6 Old 12-05-2011, 08:02 AM
KidHorn's Avatar
Quoted: 1379 Post(s)
Liked: 888
In most cases, it doesn't matter if you use HDMI or toslink. With some of the newer 7.1 codecs, you need hdmi, but to be honest, I can't tell much difference when the new codecs are played via hdmi or toslink.
The only real advantage to toslink is you avoid handshake issues.
KidHorn is offline
