Suddenly: No more image but sound is ok ??? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-05-2011, 11:39 AM - Thread Starter
SimonB27's Avatar
Hello,
I installed my receiver about three months ago, and everything was working perfectly.
However, suddenly, one morning, I wanted to watch TV, but I was getting no more image (just a black screen) but the sound was ok.
My setup is: PS3 and Cable box both connected to the receiver (DENON 1612), and the receiver connected to a Panasonic 1080p plasma screen.
As I said, I get no more image from the cable box through the receiver but the sound is still ok. However with the PS3 (again through the receiver) its perfect.
And, however again, if I connect the cable box directly in the TV its working fine!!
So: receiver works with PS3 but not anymore with cable box, but cable box still works if connected directly in the TV.
I already tried different cables and all HDMI ports of the receiver and its not the source of the problem (since anyway it works fine with PS3).
Any idea??
Thanks very much,
Simon
SimonB27 is offline
post #2 of 3 Old 12-05-2011, 05:29 PM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
You could try resetting the microprocessor (p. 94) although as cable/sat boxes often have HDMI handshake issues, you may also simply want to consider leaving it cable box (HDMI) to the TV w/ cable box (optical) to the AVR.
To learn more about your new 1612, join us in the Denon XX12 Owner's thread linked in my sig ... reviewing especially post #3 for more tips where you can try doing an HDMI reset.
jdsmoothie is offline
post #3 of 3 Old 12-05-2011, 08:24 PM - Thread Starter
SimonB27's Avatar
Thanks for your answer.
I finally been able to resolve my problem by:
1-Turning everything off
2-Unplugging cable box to reset it and replugged after 10 seconds.
3-Waited 3-4 minutes.
4-Turned TV on, then AVR on, then cable box on.
And its now working perfectly!
SimonB27 is offline
