Recommend a compact integrated stereo amp - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 12-06-2011, 04:36 PM - Thread Starter
Big Hath's Avatar
Here is my need: this system will be in a family room with a TV above the fireplace. Inputs for this amp will be a STB (uverse), squeezebox, and dvd-player (soon to become a BD player). I will be connecting the STB and dvd video outs directly to the TV, so I don't need any fancy video switching. All of these components have digital and analog audio out. I want to output to two speakers beside the tv as well as two speakers on our back porch. So I either need stereo A/B speaker outputs or I guess I could always hook up a speaker selector.
Any thoughts on this monoprice selector: http://www.monoprice.com/products/pr...seq=1&format=2
The catch is that the space for this device is very narrow. I'm thinking I could fit something only 14" wide. Also, I don't want to break the bank as I am in the middle of upgrading a dedicated media room. So I'm hoping for a couple hundred dollars max.
Bottom line: looking for a small (width) device that can handle switching between 3 audio inputs (digital preferred) and output to speakers in two areas (but I may be able to do this with a speaker selector)
Thoughts, ideas, recommendations?
Big Hath is offline
post #2 of 6 Old 12-06-2011, 04:55 PM
afrogt's Avatar
Quoted: 1415 Post(s)
Liked: 972
You're not going to find many stereo amps with digital inputs out there in the first place. The HK 3490 does but this is a full sized receiver at 17" wide.
Maybe this Yamaha YMC500 will do the trick. It has 3 HDMI inputs, 1 digital coax and 1 optical. Also converts analog video to HDMI. Dimensions 12.38 x 3.63 x 11.75
http://www.amazon.com/Yamaha-YMC-500...3218884&sr=8-5
You can see better pictures on Newegg's site.
http://www.newegg.com/Product/Produc...82E16882115211
I cannot attest to the quality of this unit.
Afro GT
afrogt is online now
post #3 of 6 Old 12-06-2011, 05:43 PM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
Boy that Yamaha sure is a weird looking box.
Am thinking a bookshelf amp. Not gonna be very powerful at all, and probly will not have capability for 2 set of speakers.
MrBobb is offline
post #4 of 6 Old 12-06-2011, 05:49 PM
afrogt's Avatar
Liked: 972
You may find a small bookshelf amp to suit your needs, but probably not one with digital inputs.
Afro GT
post #5 of 6 Old 12-06-2011, 06:03 PM - Thread Starter
Big Hath's Avatar
yeah, I kinda figured that. Analog is ok for what this will be used for I guess.
Big Hath is offline
post #6 of 6 Old 12-06-2011, 06:04 PM - Thread Starter
Big Hath's Avatar
a speaker selector should be fine for this application, correct?
Big Hath is offline
