Replace H/K 2600 with Yamaha RX-A1000? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 26 Old 12-25-2011, 03:59 PM - Thread Starter
jtenn's Avatar
Quoted: 36 Post(s)
I'm thinking of replacing my Harman Kardon AVR2600 with a Yamaha RX-A1000. Has anyone compared these two receivers? One of the main reasons I want to upgrade is I need more HDMI inputs. I wish we had a place to demo these receivers.
jtenn is offline
post #2 of 26 Old 12-25-2011, 04:23 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
I generally like HK gear. BUT these last two series (1600, 2600, 3600; 1650, 2650, 3650) they have come out with are HK Lite in comparison to older HK models, like the 635.
The RX-A1000, being in the Aventage series should be good. I'm thinking of getting an Aventage model. Although in my situation, I'll have to fly to Panama to buy one.
Custom, one of a kind pair, MJC212 mains, mod PT800 center, PT800 surrounds, SUB1500s. Parasound P7, Citation 19, Parasound HCA2205A, HK AVR3600, Marantz TT, Samsung BD player, Denon DVD-A player, MacBook Pro w/ Dirac Stereo Suite.
4DHD is offline
post #3 of 26 Old 12-25-2011, 06:04 PM
Quoted: 73 Post(s)
Liked: 112
The HK sounds better at low volume IMO. Dolby Volume is much better than Adaptive Dynamic Range. I prefer HK GUI, but Yamaha's is great too. Yamaha is pretty better in every other category. Real power is probably close. I would look at the Onkyo 370/709 as it offers a lot.
rnatalli is offline
post #4 of 26 Old 12-26-2011, 02:01 AM
astrallite's Avatar
Quoted: 25 Post(s)
Liked: 26
Based on the weight (32.5 vs 26lbs) I would assume it's fairly unlikely the RX-A1000 has a weaker, at the very least it will be a comparable amp section, and both have a pair of 12,000uf caps.
The RX-A1000 is on a higher price bracket than the 2600 though ($1099 vs $799 msrp) though so it has the onus to be a better receiver.
The only thing I can say I dislike about the first generation Aventage receivers is the inability to hide the OSD when changing volume.
astrallite is online now
post #5 of 26 Old 12-26-2011, 06:39 AM
Quoted: 73 Post(s)
Liked: 112
This was only true of the last models. All of the x10 series, even the 710 allow you to turn off the volume OSD. I forget the setting as it is not obvious, but it is there.
rnatalli is offline
post #6 of 26 Old 12-27-2011, 03:13 PM - Thread Starter
jtenn's Avatar
Quoted: 36 Post(s)
So I started looking at receivers at Newegg and the RX-A2000 is about $300 more than the RX-A1000. Is the price difference worth it for the 2000?
jtenn is offline
post #7 of 26 Old 12-27-2011, 05:18 PM
KidHorn's Avatar
Quoted: 1375 Post(s)
Liked: 883
The 2000 has a more powerful amp, a better version of ypao, and can process 9 channels instead of 7. You need an external amp to get 9 discreet channels with the 2000. it would be worth the extra $ for me, but probably not for everyone.
KidHorn is offline
post #8 of 26 Old 12-28-2011, 01:18 AM
astrallite's Avatar
Quoted: 25 Post(s)
Liked: 26
While stereo performance of the 3000 > 2000 > 1000, the interesting thing is all three models limit multichannel performance at 65 watts x 7 channels, and share the same 620VA transformer.
post #9 of 26 Old 12-28-2011, 10:03 AM - Thread Starter
jtenn's Avatar
Quoted: 36 Post(s)
Where did you find that info? I looked in the owners manual but didn't see anything.
jtenn is offline
post #10 of 26 Old 12-28-2011, 11:26 AM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
I just found this review of the 3000.
http://www.soundandvisionmag.com/art...eiver?page=0,0
Of coarse, no one listens to only one channel, unless its a mono block, making that first power output worthless.
Except for trying to fool people. I saw a Anthem power amp (MCA 50) CALLING IT A 225W AMP. But that was with only one channel driven. 180w/5 channels driven.
4DHD is offline
post #11 of 26 Old 12-28-2011, 04:02 PM
astrallite's Avatar
Quoted: 25 Post(s)
Liked: 26
http://www.hometheater.com/content/y...-labs-measures
RX-A1000 has less 2-channel output than the RX-A3000, but clips at 63W x 5 and 63W x 7, the same as the RX-A3000.
The difference between the receivers is the A1000 has 24,000uF of capacitance, and the A3000 has 36,000uF.
Also google image all 3 receivers. The power supply panel on the back all say "490W 620VA"
post #12 of 26 Old 12-28-2011, 04:26 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
According to the chart I posted from sound/vision those numbers are off a bit, as far as the 3000 goes.
4DHD is offline
post #13 of 26 Old 12-28-2011, 04:31 PM
astrallite's Avatar
Quoted: 25 Post(s)
Liked: 26
What's off? The Sound & Vision review has the RX-A3000 at 155W x 2 and the Hometheater.com review has the RX-A1000 at 120W x 2.
Looks fine to me.
post #14 of 26 Old 12-28-2011, 04:47 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
Looks fine to me.
The chart shows the 3000 output @ 66w x 5, so how can it clip @ 63w?
Now for 7 channel output, maybe.
4DHD is offline
post #15 of 26 Old 12-28-2011, 05:29 PM - Thread Starter
jtenn's Avatar
Quoted: 36 Post(s)
So these numbers are very similar to what my 2600 is putting out.
jtenn is offline
post #16 of 26 Old 12-28-2011, 06:48 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
But there is what the 2600 DOES NOT do, that matters to me. No preouts, no phono input, no multi-channel input. I really liked my HK AVR635, which had all that but the phono. I was a great sounding unit.
But from what I've been reading, I think my next AVR will be an Aventage model, most likely the A1010.
4DHD is offline
post #17 of 26 Old 12-28-2011, 06:50 PM
astrallite's Avatar
Quoted: 25 Post(s)
Liked: 26
The difference between 63W and 66W is miniscule and this number can vary under a number of conditions. If you ever have a voltmeter you can see throughout the day the voltage from your wall outlet can vary depending on what's on or off in the house.
post #18 of 26 Old 12-28-2011, 06:54 PM
4DHD's Avatar
Quoted: 205 Post(s)
Liked: 114
True there is not much difference in 3 w, but there is a big difference between true output and when it goes into clipping.
4DHD is offline
post #19 of 26 Old 12-28-2011, 06:55 PM
bommai's Avatar
Quoted: 194 Post(s)
Liked: 49
You are comparing a lower end AVR to a higher end AVR. The 635 was just one step below the top end. The 2600 is one step above the bottom end. I owned a 247 for a few weeks and it had pre-outs and multi channel inputs. The 254 had them too. But the 2600 lost them, but the 3600 had them still (so did the 347 and 354). But 3650 and 2650 have lost them!!! So, it looks like standard features from yesteryears are being lost on the new units.
I believe the only HK that still has everything you need is the discontinued HK 7550HD. That is a good unit. I had one for a few weeks this year - ended up returning it and switched to NAD (T775HD). Awesome NAD sound. However, quite a bit in a different price range. I got a good deal though - $1299.
bommai is offline
post #20 of 26 Old 12-28-2011, 06:58 PM
astrallite's Avatar
Quoted: 25 Post(s)
Liked: 26
When review publications refer to clipping, is when an amplifier reaches 1% THD. That's media industry shorthand.
post #21 of 26 Old 01-01-2012, 07:37 PM - Thread Starter
jtenn's Avatar
Quoted: 36 Post(s)
Just saw on Newegg they have the Onkyo TX-NR809 at a good price, how does it compare to the RX-A2000?
jtenn is offline
post #22 of 26 Old 01-01-2012, 08:36 PM
astrallite's Avatar
Quoted: 25 Post(s)
Liked: 26
Comparable size and power supply, hdmi inputs within 1 of each other. I think you really have to compare room eq programs, dimensions (do their fit in your entertainment center), decor, ergonomics (remote).
post #23 of 26 Old 01-02-2012, 07:30 AM - Thread Starter
jtenn's Avatar
Quoted: 36 Post(s)
Room size is 12'x23'. All components are in a stand in the back of the room with the receiver sitting on the top shelf so it's well ventilated. Hooked up to Yamaha speakers. NS-555 mains, NS-C444 center, and NS-333's for the 4 rear surrounds. Using just the factory remotes.
jtenn is offline
post #24 of 26 Old 01-11-2012, 07:12 PM - Thread Starter
jtenn's Avatar
Quoted: 36 Post(s)
So what about the Onkyo TX-NR809 vs the H/K 2600?
jtenn is offline
post #25 of 26 Old 01-11-2012, 07:41 PM
Quoted: 73 Post(s)
Liked: 112
Not a fair comparison. The 809 is better in pretty much every way.
rnatalli is offline
post #26 of 26 Old 01-11-2012, 08:55 PM - Thread Starter
jtenn's Avatar
Quoted: 36 Post(s)
Feature wise it is but what about sound quality?
jtenn is offline
Yamaha Rx A1000 Receiver
