Onkyo TX-SR307 connection help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 12-27-2011, 10:03 AM - Thread Starter
zuhloobie's Avatar
Looking for help on the best possible connection. Having trouble getting all the pieces to play nice.
Right now I have:
1. cable box hdmi OUT going to receiver's IN
2. receiver hdmi OUT to plasma tv's IN
3. hddvd (lost that gamble!) going hdmi OUT to receiver's IN
4. hddvd optical OUT to receiver's IN
5. receiver digital coax OUT to tv's IN
5. wii component OUT to tv's IN
All works awesome (5.1 sound). But...
I got a blu-ray for xmas. Unhooked hdmi from hddvd and plugged into blu-ray. Get video, but no audio (307 is pass-thru only). So duh. But, problem is that blu-ray doesn't have optical out, all it has is coax out. I don't have another coax IN available on receiver. I still want great sound and picture.
I tried connecting the blu-ray to the tv via HDMI (has 2 ports) IN, but confused about audio. Would connecting coax OUT on blu-ray to tv's coax IN fix this mess? Or would there be quality loss (audio or video)? Or is there a better way to connect this so I can still go through the receiver? TV has oodles of ports (except optical). Receiver has 3 HDMI in/1 out, 2 optical, 1 coax out.
Thanks for any advice :0)
zuhloobie is offline
post #2 of 8 Old 12-27-2011, 10:08 AM
afrogt's Avatar
Quoted: 1060 Post(s)
Liked: 763
I've never seen a TV with a digital coax audio input. I doubt your TV has one either.
Your Blu Ray player is new, exchange it for one with an optical output. Plenty of those available.
Either that or buy a coax to optical converter.
If you're talking about the RF connector you'll get bad picture quality as well as audio. I've never seen a dvd or blu ray player with a RF coaxial output either.
Afro GT
afrogt is online now
post #3 of 8 Old 12-27-2011, 10:24 AM - Thread Starter
zuhloobie's Avatar
It's this one here:
tripleW dot hdtvsolutions dot com/Philips-50PF9431D-37 dot htm (avs won't let me post urls yet)
Looking at the back panel it has a rca-looking port with "Digital Audio In" written underneath. Will that work as I described?
I will also look at exchanging it if the answer is no, to the above.
The output on the bluray is a "Digital Out (Coaxial) Jack". Bluray player is this one:
triple W dot target dot com/p/Sony-Blu-ray-Disc-Player-Black-BDP-S580/-/A-13419238 (avs won't let me post urls yet)
Thanks for the tip on the coax converter.
post #4 of 8 Old 12-27-2011, 12:46 PM
afrogt's Avatar
Liked: 763
Yes, the product sheet for your TV is here.
http://www.p4c.philips.com/files/5/5...7e_pss_aen.pdf
Yes it does have a digital coaxial input. That's very rare. Here is the manual.
http://download.p4c.philips.com/file...37_dfu_aen.pdf
If you connect your blu ray to the TV via HDMI it should output the sound thru the digital audio output on the TV. Will you get Dolby Digital and DTS? I dunno, you'll have to try it to find out. Good luck.
Afro GT
post #5 of 8 Old 12-27-2011, 06:19 PM - Thread Starter
zuhloobie's Avatar
I'm picking up another dig coax cable tonight and will let you know if going directly to the tv via hdmi works. I'm worried about losing the DTS/DD as well.
What's weird is that I can hook my laptop, which has 3D bluray, to my tv and the audio DTS carries through with just the hdmi. But if I hookup my sony bluray player with just the hdmi, no sound goes through. Just video. Odd.
post #6 of 8 Old 12-27-2011, 07:13 PM
afrogt's Avatar
Liked: 763
Probably because on the Sony Blu Ray you have to go into the setup menu and set the audio output to either HDMI or Digital Output. You probably cant output both for audio at the same time.
Afro GT
post #7 of 8 Old 12-27-2011, 07:32 PM - Thread Starter
zuhloobie's Avatar
I don't have the laptop and Sony BR plugged in at the same time. If I plug the laptop into the tv via hdmi and set the tv as a projector in my laptop's settings, I get full HD audio. If I then unplug the laptop and plug in the Sony BR player via hdmi (same port/cable that the laptop was running off of), I get picture, but no sound at all. In the Sony BR, the only settings for what they call "Audio (hdmi)" are "auto" and "pcm". So that confuses me. Thanks for the conversation, I really appreciate you sticking around...
post #8 of 8 Old 12-27-2011, 10:11 PM - Thread Starter
zuhloobie's Avatar
SUCCESS!!! I connected the blu-ray hdmi to the tv, then the coax digital cable from blu-ray to tv and mapped the tv's digital-in setting to the hdmi source of the player. And...DTS does come through! Whew!
Although it's still freaky why I have to do this for the player, but not my laptop...this is fine.
Thank you for all your help and brain storming!! :0)
Onkyo Tx Sr307 5 1 Channel A V Surround Home Theater Receiver Black
