My Marantz SR3053 Receiver's FL display disappeared - AVS Forum
post #1 of 5 Old 12-27-2011, 04:02 PM - Thread Starter
samsamwch's Avatar
Recently my Marantz SR3053 front Display disaapeared on me, graudually. For 2 days, the display was dim, on the 3rd day, it went completely blank. However, while fiddling with all possible buttons, the display came back, full power, for about 3 secs and disappeared again.
Do you know if it is a technical or setting problem?
samsamwch is offline
post #2 of 5 Old 12-27-2011, 05:31 PM
JBWIII's Avatar
Liked: 41
Did you try a full reset of the receiver? Unplug it for a few seconds and plug it back in. If that didn't fix it, try holding down SURROUND MODE and CLEAR together for three seconds. It'll erase all of your settings though.
JBWIII is offline
post #3 of 5 Old 12-27-2011, 07:25 PM - Thread Starter
samsamwch's Avatar
Thanks, JBWIII. I have tried your suggested method or unplugging and plugging, followed by SURROUND+CLEAR. I can hear the relay clicks of resetting but still no display. All other functions are working fine. Or is there another way to see the display? Do you think SR3053 has OSD?
post #4 of 5 Old 12-27-2011, 08:05 PM
JBWIII's Avatar
Liked: 41
Not sure. Check out the manual under the "Downloads" tab here:
http://www.marantz.com.sg/sg/product...oductId=SR3053
JBWIII is offline
post #5 of 5 Old 10-12-2012, 02:30 AM
aleoper's Avatar
Thanks for your useless advise. Now I have no LCD, and all settings lost, and can't see screen to correct.
aleoper is offline
User Tag List
