McIntosh MX-121 - any thoughts? - Page 10 - AVS Forum | Home Theater Discussions And Reviews
post #271 of 685 Old 04-04-2012, 05:13 AM
gurkey's Avatar
Quoted: 152 Post(s)
Liked: 106
Originally Posted by elambo View Post
We're in no way referring to time alignment. Phase shifting is an unwanted side effect of the process of equalization which creates harmful distortion. This isn't debatable and it exists in both the analog and digital domains without exception, even with our best modern digital eqs.
I'm not sure why this subject is being shellacked with an ethereal layer of mysticism -- it's not at all complicated. Equalization causes artifacts. Period. We can mask the problem with vague terminology but we can't hide the effects. Companies have spent millions and millions trying.
You have to differentiate between the analog and the digital domain.
In the digital domain using FIR filters, as Audyssey does, does not cause an unwelcome frequency dependent phase shift as in analog filter designs, meaning group delay is constant, if wanted or needed.
But using phase shifting techniques in a carefully planned way you then might time align the output of two or more sources working in the same sound field.
gurkey is online now
post #272 of 685 Old 04-04-2012, 09:17 AM - Thread Starter
elambo's Avatar
I'm not at all unfamiliar with the claims of zero phase shift in the digital domain. However, in actuality, tests have shown that there is, in fact, a slight shift surrounding the frequencies being boosted/cut. It's easily verified by running an inversion test. A null test. If distortion-free the resulting audio would be digital black. It isn't.
I agree, there's great value in time alignment. Different subject.
elambo is offline
post #273 of 685 Old 04-04-2012, 10:00 AM
RUR
Innocent Bystander
RUR's Avatar
Quoted: 381 Post(s)
Liked: 264
Have these tests been performed on recent versions of Audyssey? Lyngdorf? Dirac? Trinnov? Can you provide a link or links to the tests? Were audibility tests performed?
RUR is offline
post #274 of 685 Old 04-04-2012, 10:49 AM
Kal Rubinson's Avatar
Quoted: 701 Post(s)
Liked: 480
That's a more complicated way of saying that equalization corrects for the ill effects of an unclean signal path. Certainly that's the primary purpose of eq in a playback system, and I think we all understand its potential chore as a counterbalance for impure - we could say problematic - electronics, or even personal preferences (in the form of adding treble or bass to one's taste), but here we're talking about compensation for the ill effects introduced by the acoustic properties of the listening environment. It's a bit like having a broken leg, installing a cast, and suggesting that the cast allows the patient to run a marathon as efficiently as a person without a cast. The sum of +1 and -1 is NOT zero because we don't have a way of subtracting a perfectly inverted value for +1. So our total is 0.0234, so to speak.
Anyway, room correction schemes, such as Audyssey, emit test sweeps through much of the same paths followed by our input sources (within the unit, but also cables, amps, speakers, etc.), so many of the issues inherent within the signal path will be present within the sweeps themselves, and thus attempts will be made to compensate for them by Audyssey's corrective filtering, introducing, once again, unwanted artifacts in the form of additional distortion. It's trying to fix acoustic AND electric deviations from a flat line.
This is another way of saying that the more a signal path is faulted, the more heavy lifting Audyssey will have to do. The trouble with that equation is that the less expensive units have the "dirtier" paths, accompanied by the less effective versions of room correction algorithms, and therefor a higher level of distortion.
Once again, this is swimming in a great pool of minutia, and it's hardly worth making these types of waves, especially in an MX-121 opinion thread. It feels like we're halving an onion into infinitesimally thin pieces and there's no taste left. We've lost sight of the recipe.
I had begun quibbling with every one of your statements (except the opening sentence and the closing paragraph) but I think it is time to leave it alone.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #275 of 685 Old 04-04-2012, 03:33 PM
WestCoastD's Avatar
Quoted: 272 Post(s)
Liked: 98
Originally Posted by mookie b View Post
Looks nice. I wonder if MSRP is the same as the 150.
killer unit! Very nice retail price of $12,500.00 USD
WestCoastD is online now
post #276 of 685 Old 04-04-2012, 04:19 PM
scanido's Avatar
Quoted: 99 Post(s)
Liked: 35
The sound quality alone is worth the admission price!
See Profile
scanido is offline
post #277 of 685 Old 04-04-2012, 10:54 PM - Thread Starter
elambo's Avatar
First hand reviews of the 121 are slow to roll in. How are the owner's feeling about it?
I'm still happy with the sound now that the Pall Labs amp is in. And the Transparent Audio cables are staying, too. The AirPlay glitches were attributed to an ethernet switch which was temperamental and has since gone south. After replacing it, AirPlay and the web interface are rock solid.
elambo is offline
post #278 of 685 Old 04-05-2012, 03:17 PM
joehonest's Avatar
Quoted: 100 Post(s)
Liked: 40
No doubt that its good hardware, but really @ $12.5K that can be easly become outdated with the next video/audio uptick.
joehonest is offline
post #279 of 685 Old 04-05-2012, 05:00 PM
WestCoastD's Avatar
Quoted: 272 Post(s)
Liked: 98
true, but I'd love to have one. I'd be first in line if I had won even a piece of that $640,000,000.00-plus MegaMillions lottery last week. Just think, for two of these MX-121 unit's you could trade for my fairly new Mini Cooper-S sedan
Anyway, I believe this (MX-121) unit could go for a while being it does 3D, DLNA, etc.,...maybe 5 or 6 years?
post #280 of 685 Old 04-05-2012, 08:03 PM
rovingtravler's Avatar
The real question for upgrades is what and when will HDMI 2.0 come out and will it really be needed by anyone. It is supposed to be a year to two out.
If made modular the 150/1 and 121 could be upgraded for years. Also just as the 121 the 150 is not actually sold at retail price and the same % discount adds up quickly on the 151.
Anthems and Thetas are made this way and you can pop out an old board and pop in a new one and off you go.
David
"You buy a Ferrari when you want to be somebody. You buy a Lamborghini when you are somebody." - Frank Sinatra
rovingtravler is offline
post #281 of 685 Old 04-07-2012, 11:57 AM
StockInv's Avatar
Quoted: 29 Post(s)
I have this processor as part of my home network and have enabled file sharing. However, I do not know how to access my music files. Can anyone give me some instruction?
Thank you.
StockInv is offline
post #282 of 685 Old 04-07-2012, 12:58 PM
benmoree's Avatar
Thank you.
The mx121 will only be able to access music from an iTunes connected library via AirPlay or from a directly attached USB drive. If you have set up AirPlay and synced the mx121 to you library, then you should be able to select the mx121as the speaker by selecting the pop up menu in iTunes that looks likes a small square on top of a triangle. It is also important that you switch the mx121 to the NET/USB input on the remote so that you get playback from those sources. You should aso be able to access any USB drives on this input. Hope this helps.
benmoree is offline
post #283 of 685 Old 04-07-2012, 04:54 PM - Thread Starter
elambo's Avatar
You aren't required to switch the input when playing via AirPlay. Hitting play in iTunes with the MX121 selected as the playback device will automatically switch the 121 to that input.
elambo is offline
post #284 of 685 Old 04-07-2012, 08:43 PM - Thread Starter
elambo's Avatar
While buying new cables today, I asked my local high end dealer - a VERY long time Mac boutique shop - about the 121, 151 and new crop of products. He feels that Mac is making strides, producing better things at lower costs. I asked specifically about the 121 and its lower price and whether or not he felt that it was a compromise. He looked at me oddly as though I wasn't paying attention and repeated his initial statement -- that they're doing much more with less, which explains the potential for a lower MSRP.
elambo is offline
post #285 of 685 Old 04-08-2012, 06:18 AM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
This is the same way on most (all?) marantz & denon players, They are probably using the same bridgeCo part. The downside is that you override the whole switching idea once something is coming in (like airplay) from the bridgeCo card. Would rather that it would act like a normal input so attaching external airplay using appletv's makes more sense for one i can have multiple of them and video.
Daniel.
for men to evolve we have to upgrade
danielo is offline
post #286 of 685 Old 04-08-2012, 07:46 AM
Mark Harrison's Avatar
Quoted: 17 Post(s)
Originally Posted by baziado View Post
I am actually thinking of taking my 805 bookshelf and putting them in back and buying the 803 diamonds....... Think that would be the perfect but not sure I want to spend the money. think it is worth it?
Consider the B&W PM1 as your back speakers. Great reviews.
Mark Harrison is offline
post #287 of 685 Old 04-08-2012, 09:02 AM - Thread Starter
elambo's Avatar
In my situation, it has been perfect that AirPlay overrides other inputs. As one example, I can jump on the iPhone from anywhere in the house, hit play, and I don't have to touch the 121. I also have a MacMini connected for video and CD-quality audio, but that requires more interaction. One primary advantage to AirPlay is that it switches the 121 into monitor-mode and the rest is done remotely via iTunes. I want as little interaction with the 121 as possible.
elambo is offline
post #288 of 685 Old 04-09-2012, 09:27 AM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
This might not be the thread to discuss this common design that all bridgeCo boards seem to share. Maybe its something apple demands but from a av pre/pro switcher its kind of weird that it overrides and limits you to one signal path. It would be nice if every input had a priority but not forced as it is now. Would be nice to know if this is something apple demands of 'airplay' speakers. (its really AirTunes since airplay assumes also video).
Daniel.
danielo is offline
post #289 of 685 Old 04-09-2012, 08:59 PM - Thread Starter
elambo's Avatar
It's still an AirPlay function, using AirPlay protocols. The option for video remains present, though I doubt Apple will allow video streaming to the 121 -- it could impede the sales of other Apple products meant to serve that purpose. I hope they do because it would open up a slew of new options.
elambo is offline
post #290 of 685 Old 04-13-2012, 01:06 AM
dancoh's Avatar
So I finally received my MX121 yesterday. Ran into a problem straight away. It's to high for my AV rack. It has very long feets. So I had to replace them with some lower acoustic cushions. Worked like a charm. Still plenty of room for ventilation.
Has it connected now to my Parasound Halo A51. Initial impressions are good. Tried first Airplay and it sounded quite badly. But then I setup my speakers and then it got much better.
I had a Denon 4308 receiver before and I must say the menus look almost the same. That's a little disappointing. I know that they share Audessy but I thought that Mcintosh made their own menu system.
And has anyone else reacted to that the Mcintosh when it's dark, is lit up like a christmas tree? Not so good when you are watching a movie.
dancoh is offline
post #291 of 685 Old 04-13-2012, 01:24 AM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
Sorry but they most likely are using the same BridgeCo board the others are using and its limited to audio. You can proof me wrong probably by doing a telnet to its port it probably still gives its name/brand/model. I am with you that it would be nice if it also supports video and apple will allow it at some point my guess is they will only allow it once their figure out how far they want to take the protocols as a apple developer its clear they are not done with changing it and i think iOS6/10.8 will show changes again.
Daniel.
danielo is offline
post #292 of 685 Old 04-13-2012, 09:28 AM - Thread Starter
elambo's Avatar
It sounds like you're ignoring the manual. All of these things are in there, along with some other suggestions for optimizing sound.
McIntosh prioritizes audio so they borrow a few less important things, like the remote and menu software. You want to be disappointed with menus, take a look at a Krell. They're atrocious, but they get the job done quickly. The 121's menus are extremely user-friendly, but for better results log in with a web browser.
Go through the setup menu -- the front panel lights can be set to turn off when unused for a certain period of time.
elambo is offline
post #293 of 685 Old 04-13-2012, 09:45 AM
mookie b's Avatar
Quoted: 17 Post(s)
Liked: 26
I don't have mine hooked up through the web browser...is everything there also in the normal menus?
mookie b is offline
post #294 of 685 Old 04-13-2012, 01:24 PM
dancoh's Avatar
That was my first impressions after only a couple of hours. Now I have more thouroghly set it up. And I must say i'm very pleased.
Yes the web-interface is good. Also exactly the same as on denon. It's not super, but get's the job done. But funny thing I discovered. There is a remote app for denon on ipad and iphone. I thought I just for fun should try it with my Mcintosh. Guess what? Worked like a charm. It even recognises features on the Mcintosh that Denon don't have. You can do absolutely everything with it. Highly recommended. It's called "deremote" and is available for both Ipad and Iphone. A must have.
I could only find how to turn off the display. Not the entire frontpanel lights.
dancoh is offline
post #295 of 685 Old 04-13-2012, 04:02 PM - Thread Starter
elambo's Avatar
Thanks for the tip on the app.
I'm not sure what the function is called or where it's located, but my front panel does go dim. It was a setting I selected.
elambo is offline
post #296 of 685 Old 04-13-2012, 04:04 PM - Thread Starter
elambo's Avatar
I'm not sure. They're similar, though I feel that the web browser offers additional feedback about the 121.
elambo is offline
post #297 of 685 Old 04-13-2012, 06:32 PM
mookie b's Avatar
Quoted: 17 Post(s)
Liked: 26
Anyone know if the 121 passes through 4k video?
fleishher likes this.
mookie b is offline
post #298 of 685 Old 04-13-2012, 10:32 PM
scanido's Avatar
Quoted: 99 Post(s)
Liked: 35
You won't be able to turn off the Mcintosh or control labels.
See Profile
scanido is offline
post #299 of 685 Old 04-14-2012, 01:04 AM
danielo's Avatar
Quoted: 24 Post(s)
Liked: 53
Don't want to derail the topic but what app and what features, Since its clearly using the denon serial protocol (over tcp/ip) i am interested in knowing for possible changes to the denon avp hardware upgrade we just got.
Personally i think its good they are loaning parts within the D&M group and not waisting money redoing things that don't have any real gains.
Daniel.
danielo is offline
post #300 of 685 Old 04-14-2012, 02:11 AM
dancoh's Avatar
Daniel.
Deremote. An app for ipad and iphone.
dancoh is offline
