McIntosh MX-121 - any thoughts? - Page 22 - AVS Forum | Home Theater Discussions And Reviews
post #631 of 685 Old 05-08-2014, 06:38 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Originally Posted by pierre.goyette View Post
Joe,
I have an MX121 and an MC205 along with a Panasonic Plasma TC-P65ZT60. The sound you are hearing is from the amp itself. If is generally related to the TV creating field current into the amp. McIntosh has admitted to my local reps that the MC205, MC207 and MC8207 are not particularily well shielded due to the amount of electronics that go into those units.
I myself had exactly the same noise as you probably describe. I tested a number of power filters and most of them are not good: Monster, Panamax, Thurman, etc. All the same. Try a PS Audio PS Power Plant P5 or P10. This is a power plant. It converts the AC to pure DC, filters it and then recreates a perfect 120 AC sine wave. This is the only power unit which solved my problem. It is not in the same league as all the other power "conditioners".
Try turning your TV OFF completely. The noise will probably disappear.
In terms of DC Offset, I spent some time with the McIntosh engineers trying to resolve the problem. The issue about DC Offset is that it is very hard to measure. McIntosh will tell you that if you put an Ohm Meter across the AC leads and measure DC, you will measure the DC Offset. This is actually incorrect. I measured DC offsets of multiple power grids all leading to the same value.
The Power Plant fixes this because it recreates a perfect and pure sine wave with less than 0.1% THD.
I hope this helps,
Pierre
My MX121/MC205 combo is dead quiet. This is with a Panny 65VT50 in the mix. You might be right that my PS Audio P5 is partly the reason for the low noise floor. That and everything using XLRs.
Esoteric K-03X. McIntosh MX121. McIntosh MC205. McIntosh C2500. Revel Studio 2 (Mains). Revel Voice 2 (Center). Focal Electra IC 1002 In-Ceiling Surrounds. Paradigm Studio Sub 15. Oppo BDP-105D. Roku XS. Roku 3. Apple TV(3). "Silenzio" EA-2 Media Server (pc-based). DirecTV. Panasonic TC-P65VT50. Samsung UN40FH6030F, URC MX-780.
My current SACD list
scirica is offline
post #632 of 685 Old 05-08-2014, 08:36 PM
mdrums's Avatar
Quoted: 17 Post(s)
Liked: 34
Well I sold my Integra DHC80.3 processor!!! Great processor but just wanting to try something different
I am thinking maybe a MX121 next but wonder ..Integra had xt32 and MX121 just regular Audessessy.
I'm also looking at the Anthem 50v 3D which has only 7.1 and ARC room correction which I'm told is really good and better than Audessessy. Also looking at the much lower cost but great reviews Marantz AV8801 and Yamaha CX-A5000
Thoughts?
Mikes Stuff
McIntosh MC207 Amps.........................DarbyVision Darblet
Marantz AV8801 Processor.................Da-Lite Screen
Klipsch Reference Series 7.2................Panasonic BluRay BDT500
Epson Pro 6010 Projector.....................Sony Playstation used for SACD and BluRay
mdrums is offline
post #633 of 685 Old 05-08-2014, 09:11 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Two sub outs on the 121.
scirica is offline
post #634 of 685 Old 05-09-2014, 06:32 AM
mdrums's Avatar
Quoted: 17 Post(s)
Liked: 34
Thanks I see that now.....I'm still up in arms about either getting a Yamaha CX-A5000, Marantz AV8801 or the less featured McIntosh MX121
Mikes Stuff
mdrums is offline
post #635 of 685 Old 05-09-2014, 07:26 AM
joecmess's Avatar
Quoted: 22 Post(s)
Don't waste your money. You can't easily fix this. If you got something like Torus Power to properly filter your input that could help. But I notice that you have a VT60 and I am sure it is like my ZT60. The humm is created by the Plasma. If you turn off the plasma, the hum should completely disappear...
Thank you Pierre. This is my exact problem. It seems that PS audio works for you and Scirica.  I will look into this. The buzz is only a problem when the TV is on.
joecmess is offline
post #636 of 685 Old 05-09-2014, 08:12 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
I also noticed that the issue was dramatically impacted by which circuit/outlet I plugged the plasma in. The P5 is definitely worth looking into. I've also got 6 PS Audio Noise Harvesters on the way. I'll report back when I have some time experimenting with those and their impact on the noise floor. Honestly, my system is so whisper-quiet right now, even with the VT50 plugged in that I'm not sure what they'll do...but they can't hurt!
scirica is offline
post #637 of 685 Old 05-09-2014, 05:31 PM
pierre.goyette's Avatar
Yes, I did notice that in my tests. If the plasma is on the same circuit as the MC205, the potential for noise is higher.
The following is a link to someone who describes this problem quite perfectly. Although, I did not agree with his solution...
http://audiophile-musings.blogspot.ca/2013/06/plasma-tvs-and-audio-interference.html
pierre.goyette is offline
post #638 of 685 Old 05-10-2014, 01:14 PM
joecmess's Avatar
Quoted: 22 Post(s)
Yes. This is the situation. Ps audio told me the p5 will remove dc on the mains as it creates a perfect ac power source. They are on back order so I will wait till mine arrives.
joecmess is offline
post #639 of 685 Old 05-10-2014, 02:59 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
I expect you to have the same experience as me. Dead quiet. I put my ear up to one of my mains the other night in the darkened room and actually bumped my head on the speaker. I expected to hear it humming long before my head hit!
scirica is offline
post #640 of 685 Old 05-12-2014, 06:52 AM
The sound that is created by this combination of equipment is not from the speakers. It is a transformer hum which typically oscillates but not at a regular interval. In fact, you can disconnect all cables from the power amp and just keep the power and you will hear the transformer hum. Turn off the Panasonic plasma and the hum goes away.
Inexpensive power filtering solutions such as Monster, Panamax, etc do absolutely nothing for the noise. I also tested Torus Power (AVR-20) and that did not help much. The only product which worked to remove the transformer hum was the PS Audio P5 / P10. Although I tested a P5, I ended up purchasing a P10 since I didn't want the power plant running at 80% capacity...
post #641 of 685 Old 05-12-2014, 08:16 AM
joecmess's Avatar
Quoted: 22 Post(s)
Thanks Pierre. Yes the buzz comes only from the amp. Will a P5 be enough to power the mc8207?
joecmess is offline
post #642 of 685 Old 05-12-2014, 08:32 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Not sure how much this helps, but my P5 runs at about 60% capacity and I have the MC205, 65VT50, a 2-channel audiosource zone 2 amp, the MX121 and some additional sources. All outlets on the P5 are in use. I'd love to upgrade to a P10 for even more headroom, but I'm very comfortable with the current (and current) load.
scirica is offline
post #643 of 685 Old 05-12-2014, 08:54 AM
joecmess's Avatar
Quoted: 22 Post(s)
Thanks. Very helpful. I will have the amp, the mx121, the 65vt60 and two sources for now. It should be ok
joecmess is offline
post #644 of 685 Old 05-12-2014, 09:31 AM
I had a bit more stuff on mine: MX121, MC205, MR88, D100, 65ZT60, Popcorn Hour A-410, Sonos, Apple TV, Denon BluRay. But the biggest draw on the unit is the plasma.
But come to think about it, first try with just the McIntosh gear on the P5. Leave the plasma on the wall (or other power filter). That will probably solve your problem and leave more headroom for the MC8207. That is how I run mine. The plasma is currently not on the P10.
post #645 of 685 Old 05-12-2014, 04:40 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
I agree on the approach; biggest draw will def be the plasma. However, there are visible benefits to running the VT 50 off the P5 and you'd miss out on that. I understand right now eliminating the buzz is your primary objective.
scirica is offline
post #646 of 685 Old 05-12-2014, 04:46 PM
joecmess's Avatar
Quoted: 22 Post(s)
Thanks. I will try it both ways and see what the results are.
joecmess is offline
post #647 of 685 Old 06-10-2014, 04:38 PM
joecmess's Avatar
Quoted: 22 Post(s)
I've read that there is a loss of dynamics with regenerators.
Do you guys have any issues?
joecmess is offline
post #648 of 685 Old 06-10-2014, 05:47 PM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Absolutely no evidence of that. I completely disagree!
scirica is offline
post #649 of 685 Old 06-10-2014, 08:03 PM
joecmess's Avatar
Quoted: 22 Post(s)
Perfect. Thanks for the reply!
joecmess is offline
post #650 of 685 Old 06-22-2014, 02:52 PM
So, did you get a P5 ? If so, what are your results ???
post #651 of 685 Old 06-22-2014, 03:08 PM
Quoted: 424 Post(s)
Liked: 348
Posted by mistake. Sorry.
Balthazar2k4 is offline
post #652 of 685 Old 10-28-2014, 06:57 AM
Bigham16's Avatar
Quoted: 196 Post(s)
Liked: 140
Hello, does the McIntosh MX-121 pass through 4k? It says only 1080p on the site. Thanks.
Bigham16 is offline
post #653 of 685 Old 10-28-2014, 07:34 AM
mookie b's Avatar
Quoted: 17 Post(s)
Liked: 26
No.
mookie b is offline
post #654 of 685 Old 10-28-2014, 07:36 AM
Bigham16's Avatar
Quoted: 196 Post(s)
Liked: 140
Thank you!
Originally Posted by mookie b View Post
No.
Bigham16 is offline
post #655 of 685 Old 10-28-2014, 09:32 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
Nope. I just go straight from my Oppo 105D to the display for video.
scirica is offline
post #656 of 685 Old 10-29-2014, 05:57 AM
Bigham16's Avatar
Quoted: 196 Post(s)
Liked: 140
Thanks for the suggestion. Didn't think about doing that with the Oppo.
Bigham16 is offline
post #657 of 685 Old 11-06-2014, 04:29 AM
tritiumglo's Avatar
Quoted: 366 Post(s)
Liked: 165
And once again we are all slapped with obsolescence. Just when we caught up and had OSD via HDMI....... Gone again.
NAD M15 /NAD M25 / PSB STRATUS GOLD / PSB STRATUS 6C /DENON AVR 3300/CARVER TFM 45/35 - ANTHEM MCA3 / NAD T163
IMAGE DYNAMICS / INFINITY RS3 / POLK MONITOR 10/ALTEC 501 / INTEGRA 50.3/PARADIGM DSP 3400 / GOLDENEAR AON3 / HK AVI 200
An Observer of many philosophies, a slave to none.
tritiumglo is offline
post #658 of 685 Old 03-05-2015, 11:07 AM
VGI
VGI's Avatar
Quoted: 298 Post(s)
Liked: 102
I just spoke with macintosh about the future of their MX121 pre pros..
They made it very clear there will be no upgrades available for 4K video pass through etc..
This is unbelievable that a 6000 and their MX151 as well 12500 both are now obsolete..
I feel really bad for the people who spent this kind of money on what now is a paper weight..
Classe SSP800 did the same and Anthem the Same and Bryston the same and the list goes on..
Why do people continue to buy into Pre pros and companies that don't keep promises ? No idea
Theta Digital and the Casablanca still remains 100% upgradable and they have 4K support and have had it for a year..
Craig
Craig Shumer
20 Years of Audio Video Excellence
President of Theatermax LLC
www.theatermax.com
VGI is offline
post #659 of 685 Old 03-05-2015, 11:44 AM
scirica's Avatar
Quoted: 112 Post(s)
Liked: 156
It would really be nice if my MX121 upscaled, but honestly, I don't see my pre/pro as the piece of equipment that I want driving my video experience. For me, that happens with the player (Oppo 105D) or with a specialized external scaler. However, I do agree that at these prices they should do it all!
scirica is offline
post #660 of 685 Old 03-05-2015, 12:01 PM
Selden Ball's Avatar
Quoted: 3216 Post(s)
Liked: 1579
Unfortunately, McIntosh is no longer affiliated with D+M, so upgrading the MX121 would be relatively difficult (i.e. more expensive than it's worth) since they don't have easy access to compatible circuit designs. I'd expect the MX151 to be easier, since (presumably) more of it was designed in-house. Still, so far as they're concerned, I'm sure an all new Atmos/DTS:X/Auro-3D capable device would be more cost-effective if designed from scratch. It'll need much more powerful computational hardware to support roomEQ for the additional speaker channels, for example, as well as more XLR connections on the back panel. By the time you're done with that kind of an upgrade, only the front panel would be left, if that.
Selden
Selden Ball is offline
