How does the Pioneer Warranty Work? Receiver On Fritz - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-31-2011, 09:07 PM - Thread Starter
bobafart's Avatar
Got a Pioneer VSX 921-K receiver (2011 model)
the HDMI Output is too loose/wiggly to get a connection, you have to hold it in place to get a connection
it's been like that since I bought it 3 months ago.. i thought i could do with component but I should probably get it exchanged while under warranty
Pioneer is closed for holidays so I will contact them when they open
do I have to mail the receiver into Pioneer to get an exchange? how does the process work? positive or negative experiences from people please?
thanks in advance
happy new year!
bobafart is offline
post #2 of 2 Old 12-31-2011, 09:13 PM
Tulpa's Avatar
Liked: 61
If there's an authorized service center nearby, you can just take it to them. They'll generally attempt to fix it at first, maybe offer an exchange if it's not repairable.
http://www.pioneerelectronics.com/po...003367a8c0RCRD
Bring your receipt. Might call around, they often have different turnaround times.
If you want a straight up exchange, you'll have to deal directly with whomever you bought it from. If it's in their return window.
Don't believe everything on the Interwebz! A duck's quack DOES echo!
Tulpa is offline
