How to determine reference level with a volume display of 1-99? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 01-05-2012, 10:51 AM - Thread Starter
gregdpw's Avatar
My friend just got an onkyo sr309. How do I know what reference volume is since it won't display the 0db on the main display? It only displays 1-99. Thanks guys
gregdpw is offline
post #2 of 10 Old 01-05-2012, 11:50 AM
ccotenj's Avatar
Liked: 101
with test tones and a spl meter...
- chris
ccotenj is offline
post #3 of 10 Old 01-05-2012, 01:12 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
That's how I would do it
"But this one goes up to 11"
MichaelJHuman is offline
post #4 of 10 Old 01-05-2012, 01:18 PM
ccotenj's Avatar
Liked: 101
can't think of any other way...
if you and i agree, well dammit, it's gotta be right...
- chris
ccotenj is offline
post #5 of 10 Old 01-05-2012, 01:22 PM
jdsmoothie's Avatar
Quoted: 12264 Post(s)
Liked: 5592
It's likely 82.
On Denon AVRs ... the "absolute scale" goes from -88.5db to +18db with 0db being reference volume, while the "relative scale" goes from 0 - 99 with 82 being reference volume. Likely the same on the Onkyo as well.
jdsmoothie is offline
post #6 of 10 Old 01-05-2012, 02:01 PM
JChin's Avatar
Quoted: 349 Post(s)
Liked: 204
Agree, Onkyo receiver as far back as 2003 has this reference.
JChin is offline
post #7 of 10 Old 01-05-2012, 02:43 PM - Thread Starter
gregdpw's Avatar
That's all I need to know. 82 then. Thanks!
gregdpw is offline
post #8 of 10 Old 01-09-2012, 04:43 PM
Brian B's Avatar
Quoted: 234 Post(s)
Liked: 101
But don't you want an acoustic reference level? 75db? For that you have to use the meter and measure otherwise seating distance and speaker sensitivity aren't being taken into account.
B.
Brian B is offline
post #9 of 10 Old 01-09-2012, 04:57 PM
moparfan's Avatar
After I calibrated my Sc-27, I listen at -25 to -20 (rarely). Am I a girlie-man?
edit: Speakers are 93db sensitivity.
moparfan is offline
post #10 of 10 Old 01-09-2012, 05:22 PM
mjpearce023's Avatar
Quoted: 36 Post(s)
Liked: 38
Yes
I'm really not sure if MCACC sets ref level to 0 or not. On my Denon, I usually watch TV around -25 or so but I crank movies and music to around -10 to -5. It gets extremely loud at -5 but it sounds good for action movies.
mjpearce023 is offline
