Quality 2-channel amps 100< $$ - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 01-07-2012, 12:30 PM - Thread Starter
cazten's Avatar
Can anyone recommend some quality 2 channel amps that can be had for less than $100 each. Tri-amping a system and considering jumping right into dedicated amps vs a powered AVR if its economically feasible to start.
I don't care what decade there from, what fancy gizmos they have, ect. Here's what I do want:
1. Less than $100 each
2. Less than 100WPC- even 40-50wpc is enough
3. Quality amplification- Near audiophile level as possible.
4. If used- Pops up on craigslist/ebay/forums often enough to actually find a set within a few months.
cazten is offline
post #2 of 11 Old 01-07-2012, 01:33 PM
M Code's Avatar
Quoted: 806 Post(s)
Liked: 493
Price seems too low..
I would suggest looking for HK 3380, 3385 either used or refurbs..
Maybe Craig's List or E-bagger..
Just my $0.02...
M Code is online now
post #3 of 11 Old 01-07-2012, 01:56 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 151
If you can live with less than 100 watts, there's this -
http://www.amazon.com/AudioSource-AM.../dp/B00026BQJ6
If you can live with the cheapest amps on the market, there's this totally overrated amp (bit more than $100). Probably closer to 100x2 watts, than it's stated ouput (which is clearly BS)
http://www.parts-express.com/pe/show...umber=248-4524
Used might be best
"But this one goes up to 11"
MichaelJHuman is offline
post #4 of 11 Old 01-08-2012, 08:09 AM
jm86wvu's Avatar
You may be able to find ebay deals on used Adcom 535's. Rated at 60 wpc. Bidding sometimes ends right around $100.
here's one:
http://www.ebay.com/itm/VINTAGE-ADCO...a#ht_821wt_934
here's another:
http://www.ebay.com/itm/Adcom-GFA-53...5#ht_500wt_950
jm86wvu is offline
post #5 of 11 Old 01-08-2012, 08:21 AM
Kiel'thalin's Avatar
You could use a power supply with an old class AB car amp found cheap at a pawn shop or eBay. Any power supply up to 30 amp could work off a single dedicated outlet.
Kiel'thalin is offline
post #6 of 11 Old 01-08-2012, 10:06 AM
mcsoul's Avatar
Quoted: 16 Post(s)
Which 3-way electronic crossover are you using. Please don't say it's a car audio one running off of a 12v supply LOL.
mcsoul is offline
post #7 of 11 Old 01-08-2012, 10:36 AM
jparr's Avatar
The 12V power supply would add quite a bit to the cost, not to mention that car amps usually don't sound so great.
jparr is offline
post #8 of 11 Old 01-08-2012, 10:40 AM
ccotenj's Avatar
Liked: 101
except a 30 amp 12v power supply exceeds the budget all on it's own...
i'm curious as to the xover as well...
- chris
ccotenj is offline
post #9 of 11 Old 01-08-2012, 10:50 AM - Thread Starter
cazten's Avatar
Most likely a MiniDSP from the guys at diyaudio forums.
cazten is offline
post #10 of 11 Old 01-08-2012, 01:44 PM
dsmith901's Avatar
Liked: 24
You might search eBay or Audiogon for a H/K PA4000, an 8 ch amp with 4 bridgeable pairs. As I recall power was 65 watts X 8 or 130 watts X 4. It is out of production now, but good used ones are probably still around. You might want to research multi-room amps from other manufacturers if they fit your power specs. Most have 8-12 channels of power in the 25-50 watt range and could be used as you need, though I can't say they are "audiophile" quality. Better yet buy a pair of regular 5 ch HT amps for about the same price as $100/ch. Emotiva HT amps are pretty cheap even new and a couple of them will probably fit your budget.
"The truth is out there!"
dsmith901 is offline
post #11 of 11 Old 01-08-2012, 03:33 PM
I could of swore my vintage Cerwin Vega VS-12's are powered this way just fine with a California two channel amp with no problems. If fact the gain is only turned up 1/3rd if the way to match the center & surrounds... it is a hell of a lot cheaper than buying from behringer or emotiva. I guarantee you won't notice a difference.
