Yamaha receiver subwoofer volume very low - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 65 Old 06-20-2014, 07:26 PM
old corps's Avatar
Quoted: 157 Post(s)
Liked: 87
Seems like I remember reading that the problem was solved by setting your main speakers to SMALL regardless of what they actually might be. I don't own a Yamaha but think I read this somewhere. ???
Hope it helps!
Ed
old corps is offline
post #32 of 65 Old 06-20-2014, 08:06 PM
MichaelJHuman's Avatar
Quoted: 266 Post(s)
Liked: 148
Interesting idea, but that would not explain the fact that the OP says the test tones don't play correctly. The test tones should put out a signal that's independent of the speaker setting.
That's why an SPL meter is useful, to ensure all is correct with the YPAO setup. But if I understand the OP, it's obvious the sub channel is very quiet when the test tones play
"But this one goes up to 11"
MichaelJHuman is offline
post #33 of 65 Old 06-21-2014, 06:40 AM
Liked: 0
Thank you Ed & Michael. I did set the speakers to Small. Did a sub crawl and ¨placed it in a better place, ran YPAO again, it set speakers to large, sub level at +6db, speakers around 0db, cross-ver 40hz, extra bass on. you can feel it vibrating, albeit for net radio the bass isn't too loud, and if i turn the gain up (currenltly below half) it sounds what i guess you call "boomy".
Now I set speakers to small again, crossover at 80, will try it on a movie tonight... on the test tones however it gives all but the faintest rumble, barely hearable, well below the other speakers. I think there's still something wrong, doesn't seem normal to have to run it at +6db with meager results.
cheritoga is offline
post #34 of 65 Old 06-21-2014, 10:38 AM
old corps's Avatar
Quoted: 157 Post(s)
Liked: 87
Sorry my suggestion didn't appear to help. I've been very tempted by the Yamaha 675 to replace my perfectly functioning Onkyo 609--only because all of the reported HDMI board failures have made me paranoid and the 675 is currently available for such a great price.
Hope you get it figured out!
Ed
post #35 of 65 Old 11-20-2014, 09:52 AM
Liked: 0
Hello,
Same issue with me!
Yamaha rx-v375, q acoustics 2020i speakers and svs pb-2000 subwoofer.
On the receiver: subwoofer set to on; all speakers set to small, crossover 80hz; phase normal (but also tried reverse); levels set to zero.
On the sub: Volume set to half, fase 0, crossover set to maximum (LFE).
With the previous settings I can barely hear the sub. If I turn sub volume to maximum and receiver sub level to +10db. The sub plays ok... not loud and not even good enough. I'm testing the sub on a small living room (4m x 3m / 13ft x 10ft) with almost no windows.
Connected the sub to a media player (600X3D) analog out with red and white RCA from the media player to R and L on the sub and the result was great... I am starting to think that there is some issue with the yamaha receivers with some subs....
Any help?
miguelPT is offline
post #36 of 65 Old 01-29-2015, 06:11 AM
M-Theory's Avatar
I have the same receiver with the same issues: no subwoofer volume after trying two new subwoofers. I have tried a global reset with no improvement.
Ron Compton
Never offend people with style when you can offend them with substance."
--Sam Brown
Anybody who knows all about nothing knows everything - physicist Leonard Susskind, Stanford University
M-Theory is offline
post #37 of 65 Old 02-05-2015, 07:56 AM
Quoted: 43 Post(s)
Liked: 3
I'm glad I found this thread! Same problem over here!! I'm using the Yamaha V377 and the SVS PB-1000. I purchased the yamaha 12-23-14 and the SVS just a few weeks ago both brand new. Also using the Klipsch Quintet 5.0 satellite speaker system, also purchased last month. The way everyone was raving about the SVS sub I was definitely expecting more oomph. I spent time with SVS tech support, which is excellent by the way, and connected a cd player directly to the sub and concluded the sub was working fine. After reading this thread, I'm wondering if there's an issue with the yamaha's sub port or maybe a compatibility issue in general. Luckily I'm within the last 2 days of the return policy of best buy. Just wondering should I get the same model or different brand receiver.
I would really really appreciate your opinions! Only have today and tomorrow to do this....
MrGrim999 is offline
post #38 of 65 Old 02-05-2015, 11:46 AM
Alan P's Avatar
Quoted: 4694 Post(s)
Liked: 3321
MrGrimm - how large is your room? Have you done a sub crawl to determine the best location for your sub? Is the bass stronger in other areas of the room away from the listening position?
Pics or a diagram of your room will be helpful.
Alan P is online now
post #39 of 65 Old 02-05-2015, 12:09 PM
Quoted: 43 Post(s)
Liked: 3
It's a small bedroom 12 x 12. I'm limited to where i can put it because of all the furniture in the room. I don't believe it's in a bad spot though. My listening position is on my bed against the headboard which is against the back wall. My tv is on a stand directly in front of the bed right in front of the front wall. The sub is right beside the tv at least a foot away from the wall.
post #40 of 65 Old 02-05-2015, 12:21 PM
Alan P's Avatar
Liked: 3321
And what do you base this statement on?
You didn't answer my question:
post #41 of 65 Old 02-05-2015, 03:24 PM
PretzelFisch's Avatar
Quoted: 396 Post(s)
Liked: 262
If it's the issue I had, you need to rest it to factory defaults and then re calibrate it with the mic. assuming your direct to bule-ray sounded good.
PretzelFisch is online now
post #42 of 65 Old 02-06-2015, 09:59 AM
Quoted: 43 Post(s)
Liked: 3
I haven't tested from different listening points, no. There's always the possibility I'm being paranoid. I am hearing bass but not sure how much is coming from the Klipsch speakers and if I'm getting the sound i should be getting from the SVS sub. I've already done the factory reset with the Yamaha and ran the YPAO. If the sub port on the yamaha was faulty, is that something that can happen where its working but not as it should? Or would it just not work at all period?
post #43 of 65 Old 02-06-2015, 10:49 AM
Alan P's Avatar
Liked: 3321
If the sub out on the Yamaha was defective, you wouldn't get reduced bass. Those jacks usually either work or don't work.
If you can't tell if the bass is coming from the speakers or the sub, try turning off the sub and listening. I can guarantee you you're not getting anything that could be called bass with those speakers (only rated down to 110hz). Which brings up the question - where do you have your crossovers set (in the AVR and on the sub itself)?
You need to walk around the room with some bass heavy music on and see if the bass is a lot stronger in other areas of the room. If it is, that means your listening position is in a null and the only cure is to move the sub to a different location.
post #44 of 65 Old 02-06-2015, 11:31 AM
Wrager's Avatar
Quoted: 192 Post(s)
Liked: 114
I have had several Yammy receivers and they all had reduced sub out. I even dumped my MiniDSP because of this. Try a line level shifter like the Reckhorn B1. There are a few others. My QSC DSP 30 allows me to adjust the input voltage so no longer need the bump box. Good luck to all with a Yammy.
Wrager is offline
post #45 of 65 Old 02-06-2015, 11:46 AM
Alan P's Avatar
Liked: 3321
Good point Wrager...I didn't think that there could be low voltage on the sub out. But then, wouldn't these guys be maxing out the sub gain and still falling short? Heck, maybe they are and I just missed it.
post #46 of 65 Old 02-06-2015, 03:41 PM
Quoted: 43 Post(s)
Liked: 3
Haha, yea I'm sure its not coming from the satellites. The crossover settings are ok. There's a LFE setting on the sub which it is set to. The setting on the avr is set to 120hz. I was on the phone today with SVS tech support and suggested something interesting....using a Y adapter to double the output from the avr....
post #47 of 65 Old 02-06-2015, 04:09 PM
Alan P's Avatar
Liked: 3321
Not sure what this means, but FYI the crossover on the sub itself should be set as high as it will go (or disabled, if that's an option).
A y-splitter into both sub inputs will raise the gain by 6db...worth a shot.
post #48 of 65 Old 02-06-2015, 04:36 PM
Quoted: 43 Post(s)
Liked: 3
LFE is a setting on the SVS subwoofer crossover dial which means it will get the information from the receiver, which is set to 120hz.
I used the YPAO calibration tool and i think the avr level setting is at -2.5. Should I lower that further?
post #49 of 65 Old 02-06-2015, 04:38 PM
Quoted: 43 Post(s)
Liked: 3
Really?? Is this still an issue with today's Yamaha receivers? How can you tell?
post #50 of 65 Old 02-06-2015, 04:45 PM
Alan P's Avatar
Liked: 3321
Only if you feel the bass is too much at that level.
post #51 of 65 Old 09-17-2015, 01:39 PM
Liked: 0
I'm sorry to both revive a thread and to hijack, wasn't sure if I should create a new thread or not, but I just hooked up a Yamaha RX-V577, and am having major issues with the subwoofer level output. I have a Pioneer SW-8MK2, but I can barely hear the thing. I've used the YPAO setup exactly as it described, and the sub was practically inaudible, I had to turn the sub over and feel the woofer just to see if it was even making any sound while cranking the receiver to a far louder level then I normally would listen at. I turned on the sub, enabled extended bass and all that like the manual recommends. I even manually went and messed with the gain levels, for it to be even a remotely audible level I have to adjust the mains to -10db and the subwoofer to +10db, but the bass level is still rather low (better, but a lot lower then I'd like while listening to music).
I've had the exact same 5.1 setup, same wires and everything hooked up and tested with two different receivers with absolutely no issue with the low pre-amp sound from either other those, one of which was even an older Yamaha, and the other was a newer Sony 5.1 receiver. In fact, on the subwoofer adjustments I had the gain down to almost a quarter and had plenty of bass, with the new receiver I have it cranked as high as it goes just to even output sound.
At this point I'm debating on returning the receiver, but I really like it other than the subwoofer issue and got a great price on it. I've ordered a pre-amp and will try that in a few days (unless there's absolutely a specific reason I shouldn't; I will turn down the gain and slowly inch up so I don't blow anything). Did anyone find a solution for the Yamaha low line-level outputs? Its gotta be the receiver, because 2 other receivers work just fine (and it's not broken, since it does output to the subwoofer, just a really, really, really low level).
Somesome11 is offline
post #52 of 65 Old 09-18-2015, 08:32 AM
Quoted: 51 Post(s)
Liked: 9
When you say the sub output is barely audible, are you talking about the sub out while playing the test tones or is the the bass level while playing contents such as movies and music.
If it is while playing the test tones from the AVR, then remember that for Yamaha the sub output is not independent of the volume on the AVR. I had a similar problem where the sub output while playing test tones was barely audible, however when I increased the volume I was able to hear them. Also I had turn up the gain on the sub to about 75 % for the bass to the acceptable. I had an Onkyo before and when I played the test tones from the Onkyo the bass from the sub was always audible irrespective of the volume set on the AVR.
nikhilnh is online now
post #53 of 65 Old 01-25-2016, 01:10 PM
smilepak's Avatar
Glad I come across this. I am having the same issue. Driving me nuts....
Yamaha V677
Polk Audio PSW505 Sub Woofer
I've tired all 3 types of connection from the sub to receive. Currently using a single cable in the LFE OUT on the sub to the SUB in on the receiver.
I've set the Speaker to Small on the receiver. Sub volume to max. Sub volume on the receiver to -10db. Barely hear any thump. For the life of me, can't figure out how to get more thump out of this sub.
Sad to say (people will hate me saying it) I get more bass out of my BOSE ACOUSTICMASS subwoofer at this moment by far.
smilepak is offline
post #54 of 65 Old 01-25-2016, 03:15 PM
Quoted: 396 Post(s)
Liked: 262
Yamaha V677
did you set it to -10 or did the calibration? because -10 turns the signal down you would want to adjust it to 0.
post #55 of 65 Old 01-25-2016, 03:23 PM
smilepak's Avatar
it was originally zero. Calibration changed it to -4, I changed to -10.
The Subwoof Trim value is still set to 0.
smilepak is offline
post #56 of 65 Old 01-25-2016, 09:07 PM
Alan P's Avatar
Liked: 3321
You are going the wrong way.
-10 is lower than zero. To pump up the bass, go into the positive numbers.
post #57 of 65 Old 01-25-2016, 10:03 PM
smilepak's Avatar
Lol just realized that after u asked. Changed to +19. A bit better light thump
smilepak is offline
post #58 of 65 Old 09-21-2016, 05:28 AM
Liked: 0
Hi All,
Same issue with me too!
I recently brought YAMAHA RX-V379 & Energy Take Classic 5.1. Tried all the options found here still my sub sounds low rest of the speakers sound good.
By increasing sub level to 10dB i could see some increase in bass but still its low not as expected.
I have used YPAO and tried impedance @6 ohms also.
Finally did a factory rest also and tried.
After searching finally fount this thread others facing the similar issue. Was there any luck in finding the solution.
Please advice.
vvadde is offline
post #59 of 65 Old 09-21-2016, 08:44 AM
Alan P's Avatar
Liked: 3321
Originally Posted by vvadde View Post
Hi All,
Please advice.
Size of room?
Placement of sub?
Speaker trims post-YPAO?
Speaker trims now?
post #60 of 65 Old 09-21-2016, 12:01 PM
Liked: 0
Hi Alan,
I have attached the speaker position diagram below.
Along with YAMAHA speaker trims with factory default now.
ID:	1673433   Click image for larger version
ID:	1673489   Click image for larger version
ID:	1673497   Click image for larger version
vvadde is offline
