Zone 2 issues with Integra DTR 7.8 - AVS Forum | Home Theater Discussions And Reviews
Old 01-12-2012, 10:04 AM - Thread Starter
danger dan's Avatar
Nobody has been in the Official Integra DTR 7.8 thread for a long time so posting here. I'm having Zone 2 and Back Surround issues and was wanting some input. I run a 5.1 system in my theater area in my basement. I recently built a new bar area in my basement and am trying to run two speakers in that area as Zone 2. I have a cd player hooked up to the analog in on the receiver and when I follow the instructions for turning on Zone 2 and choosing an input the receiver shuts down immediately as soon as it gets to the matching analog input. It goes into standby mode with the standby mode indicator light flashing red. I know my Zone 2 speakers work as I hooked them up as my front L and R in my theater setup to test them. After pulling my hair out I decided to hook up my bar speakers as back surround L and R figuring I could just run all channels stereo when I wanted music in the bar area. So I enabled the two back surrounds and tried setting the levels using the pink noise test tone and I could not get any pink noise to the speakers as back L and R surrounds. When I scrolled to those speakers on the test tone menu there was no sound at all. I lost my original Integra 7.8 to a flood last summer and bought the one I currently have off ebay so I guess anything is possible as far as things not working properly. The only thing I can think of doing at this point is buying a separate two channel amp and running the pre-outs to it for my Zone 2 bar area speakers. I have yet to try a system reset. May try that tonight. Suggestions?
DANger
danger dan is offline
Old 01-12-2012, 10:28 AM
jdsmoothie's Avatar
Quoted: 12104 Post(s)
Liked: 5508
Do the system reset and if still no joy, apparently you bought a defective AVR.
jdsmoothie is online now
Old 01-14-2012, 08:39 AM
you2slo's Avatar
Make sure the volume for zone 2 is not turned up too high. It could cause the receiver to go into protection mode. If the bar speakers work when hooked up to a different channel on the receiver, it is possible the 6th and 7th channels are no longer working. It is odd that the receiver will shut down when you try to use zone 2 but it does not shut down when you run the tones to the surround backs. I assume you swapped the location of the speaker wire from Z2 to SB.
you2slo is offline
Old 01-17-2012, 11:50 AM - Thread Starter
danger dan's Avatar
Everything was checked and re-checked and double checked and checked again. I then did a system reset to no avail. Then I unplugged the receiver for a while and tried again to no avail. No Zone 2 or back surrounds. Doesn't really surprise me all that much considering how the receiver was packed from the ebay seller. No packing material of any kind. Just dropped into a box. Too much time has passed now to send back. Guess I should have checked everything I could once I received it. Looks like I'll be getting a two channel amp for Zone 2. Will run the Integra Zone 2 amp preout into my headphone amp first to make sure it works.
DANger
Old 10-26-2012, 08:37 PM
sawyerthecat's Avatar
I had a similar problem and found my zone 2 volume was all the way up to the max. so the reciever thankfully went into protection mode. zone2 volume controls are tiny up/dn buttons to the left and not the main volue control - tricky if you are looking at the back of the unit and adjusting the front by feel.
zone 2 without a separate amp steals two of the speakers so 7.1 becomes 5.1 and 9.1 becomes 7.1
Another zone2 thingy is that the subwoofer preout is not i guess as they say "eqed" - it get's full range audio
sawyerthecat is offline
Old 01-16-2015, 07:01 PM
Liked: 0
Begin set up of my system after being packed away for 10 months or so after a move.I have a audio problem with my integra 7.8 AVR. No audio HDMI IN>HDMI OUT. I bypassed AVR with computer>TV to check cable and I get audio/video. I then went COMPONENT>AVR>HDMI OUT and I get AUDIO/VIDEO using PSX-2. This is analog so I don’t think plays in the equation.I tried all three HDMI IN with same result of no audio. When going HDMI IN>HDMI OUT and disconnecting HDMI OUT >TV I lose VIDEO but gain AUDIO. I have been reading post about Integra failure rates and hope I am not another victim. Would like to eliminate a problem on my part before repairing or buying another AVR.I appreciate your help and time with any suggestions. James
bonno5id is offline
