Sub not coming on my receiver - AVS Forum | Home Theater Discussions And Reviews
Old 01-15-2012, 01:03 AM - Thread Starter
boonie300's Avatar
Need help...I have a 11 or 12 year old Sony Str-de475 receiver and a audio acoustic pa-120 sub,monster sub cable and It won't put out sound at all...I have the sub set to on and the LFE set to 0 and my bookshelf speakers set to small in my receiver,my old sub worked fine but haven't had one in 3 years...Also,when I hooked my sub to the direct tv cable box it worked so I'm not sure if it's a sub problem or a receiver problem...any help would be appreciated!
boonie300 is offline
Old 01-15-2012, 02:41 AM
Roger Dressler's Avatar
Quoted: 1523 Post(s)
Liked: 711
Remove the cable feeding the sub at the rear of the receiver. Touch the tip pf the plug with your finger. If you hear buzz, the sub is working. Now look for reasons why nothing is coming out the sub output jack.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
Old 01-15-2012, 05:17 AM
YeuEmMaiMai's Avatar
things to check assuming you have everything wired correctly
1. does source being played have a lfe track?
2. is bass management enabled?
3. does your receiver think you have a sub attached? if not, change setting approperiately
a. are your speakers set to small?
b. are lfe effects routed to sub?
4. if you are using auto sense turn on off tech try raising the sensitivity or turning it off completely thus leaving the sub "on" all the time
Strong or weak in the end we are all dead
YeuEmMaiMai is offline
Old 01-15-2012, 11:08 AM
Liked: 711
1. does source being played have a lfe track? Doesn't matter.
2. is bass management enabled? He said it is.
3. does your receiver think you have a sub attached? He said it does.
a. are your speakers set to small? He said they were.
b. are lfe effects routed to sub? Where else would they go with his settings?
4. if you are using auto sense turn on off tech try raising the sensitivity or turning it off completely thus leaving the sub "on" all the time. Good question.
Old 01-15-2012, 11:48 AM
1. On some receivers, it does matter if the source material has a LFE track. Yamaha even states in their RVX manual that this is one of the reasons you may not get sub output when listening to x.1 material.... Yamaha RX-V467 manual page 72 states this specifically and referrs you to page 77 for an explantion of LFE.....
3.
b. on my ancient Yamaha HTR-6535 receiver it is possible to route the LFE to the mains even with a sub attached.
Old 01-15-2012, 03:41 PM - Thread Starter
boonie300's Avatar
Thanks for the replies...I dont think it's the sub cause it works when I have it hooked up to the cable box...I had a bic 100 sub a few years ago and it worked fine and I havent changed anything so I'm thinking the receiver must now be defective...just my guess.
Old 01-15-2012, 04:11 PM - Thread Starter
boonie300's Avatar
This might be a stupid question but could some subs just not be compatible with some receivers?
Old 01-15-2012, 04:52 PM
Liked: 711
But not if the bass management is turned on, and that's the case we are discussing.
Yes, many AVRs can do that even today. It requires that the mains be set to large, which is not the case here. And even if they were, the sub signal would still feed the sub in parallel.
Old 01-15-2012, 04:57 PM
Liked: 711
Highly unlikely.
Have you tried running the internal test tones to see if a) it reports it is creating a subwoofer signal, and b) it is audible?
Old 01-15-2012, 11:56 PM - Thread Starter
boonie300's Avatar
Highly unlikely.
Not sure,I'll have to check when I get home...I'm going to take the sub another house on a different receiver to make sure if it really is the sub or receiver...if I have to get another reciver which one would be good for under 200 bucks...if I have to get one on eBay I'll do that if there is a good deal I can find.
Old 01-16-2012, 01:29 AM
Liked: 711
^^ If you already tried the test I suggested in post #2, then there's no need to take the sub to your friend's house. If you just want to hear audio thru it, plug it in to a CD player or iPod.
Better yet, have your friend come to your house and walk through the setup and make sure it's all fine, or confirm the AVR's sub out is indeed dead.
