HDMI w/Internet Switching Receiver Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-15-2012, 08:35 AM - Thread Starter
TimHuey's Avatar
Quoted: 51 Post(s)
I want to get a receiver that supports 1.4a with internet. But none of the receivers seem to list it. They all just say 1.4a with 3D and audio return channel. 1.4a specs are supposed to include internet but when the manufactures list their HDMI they aren't supposed to list the 1.4a classification they are supposed to list the cables abilities, such as ARC, 3D, internet etc. But none of the receivers list internet.
When I delve into the capabilities of the receiver non mention being able to route internet and combine it with the HDMI signal. Is it the job of the receiver to combine the audio and video in the HDMI with the internet and act as a router? Which piece of equipment does the combination and is responsible for routing?
HTPC. Onkyo 636, Polk audio speakers and Klipsch sub. KHO-7 Outdoor speakers. Homeseer homecontrol over Z-wave.
TimHuey is offline
post #2 of 4 Old 01-16-2012, 02:06 PM - Thread Starter
TimHuey's Avatar
Quoted: 51 Post(s)
Should I just get a cheap $200 receiver at this point until this spec matures?
TimHuey is offline
post #3 of 4 Old 01-16-2012, 02:22 PM
jdsmoothie's Avatar
Quoted: 15386 Post(s)
Liked: 7528
Although ethernet over HDMI is a part of the HDMI 1.4a spec, AFAIK, there are currently no AVRs on the market today that utilize that feature. Simply look for AVRs that feature "network" capability which are usually the mid level and higher models (> $500).
jdsmoothie is offline
post #4 of 4 Old 01-16-2012, 02:36 PM
SonicAppeal's Avatar
To clarify, when you say "with internet" you mean, as to have the HDMI cable provide the internet connection correct? Well, I was wondering the same thing and I came across an article saying that even though the new cables "support" ethernet, there's currently no products with that type of capability just yet.
See, I thought that with these ethernet capable HDMI cables I was going to piggyback my receiver & my TV off the BD player with the wireless connectivity... but yeah, no go on that station, lol... at least not yet.
Maybe they will update our hardware's firmware in the future to be able to do this. That would be awesome. So maybe you could call around and ask manufacturers if they plan on doing this on any of their receivers & then make your purchase.
As far as wether to save your money or buy a cheap one in the meantime... that's one question only you can answer as you know your financial status better than anyone else... I did it & it worked out for me. But my situation was different, I had a an old (but great) receiver without HDMI inputs but it was very stout for music, so I kept it, bought a "cheap" receiver with HDMI inputs until I was ready to buy another good quality receiver...
Good luck...
SonicAppeal is offline
