Crown XLS-1500 hook-up Q's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-16-2012, 06:51 PM - Thread Starter
Thunderheader's Avatar
Hello,
Alright I have kind of a newb question regarding integrating a Crown XLS 1500 into my HT setup.
Avr: Onrkyo TX-NR809
Front L/R Polk TSi 500
Center Polk TSi CS20
Rear L/R Polk Monitor 50
Surround Back L/R older Technics
Sub SVS PB13-Ultra x 2
So my problem is figuring out how to hook this amp up, I want to power the TSi500's with it. In my mind I did not take the learning curve into account, though there is only one way to learn, the manual is not too descriptive.
From the factory it comes in stereo bypass mode; other options are bridged-mono, crossover mode, highpass mode and lowpass mode.
What mode do I want to be using? What would you recommend? I have another one coming into tomorrow that I was going to run the center off of.
Thunderheader is offline
post #2 of 6 Old 01-16-2012, 07:02 PM
kmannth's Avatar
Stereo bypass mode. Let the AVR do the crossover business. The amp has a crossover (that is what those other modes are) in it for flexibility you don't seem to need.
You might set you single center channel to "mono" for even more overkill.
Have Fun!
kmannth is offline
post #3 of 6 Old 01-16-2012, 07:13 PM - Thread Starter
There does not seem to be sound coming out of the front l/r, the speakers are connected (bare wire) to the posts on the Crown and I have RCA's to the front pre-outs on the Onkyo. Am I doing something wrong?
post #4 of 6 Old 01-16-2012, 07:37 PM - Thread Starter
I am just playing with the front l/r levels and to be able to get the fronts to 75db I have to raise the level to around +11? Is this how you calibrate with a power amp, since you have more headroom?
post #5 of 6 Old 01-16-2012, 07:52 PM - Thread Starter
So I raised the levels in the Onkyo and adjusted the gain on the Crown to about 75%, it cancels out the SB r/l. They do not show up as hooked up in the Onkyo anymore, why?
post #6 of 6 Old 03-28-2012, 08:12 PM
ALMFamily's Avatar
Did you ever get this figured out? I am hitting the same issue at the moment and have just started the research process.
ALMFamily is offline
