Trouble shoot receiver: no sound from LF speaker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-17-2012, 11:13 PM - Thread Starter
ManMachine's Avatar
I have a Harmon Kardon AVR320, with 5 channel speakers (Onkyo), and the left front (LF) speaker has no sound. Hope to get some advice.
I connected the LF speaker to the wire for the RF speaker and it has sound, so speaker is not the issue. Then I connected the RF speaker wire to the connections for the LF speaker and then there's no sound from that speaker, so the problem seems to be with the receiver - it no longer powers the LF speaker connections. Any suggestions on how to fix this?
ManMachine is offline
post #2 of 5 Old 01-17-2012, 11:22 PM
nightvet's Avatar
Did you try the wire from the right speaker in place of the wire for the left speaker on the off chance that the wire has a break in the run?
nightvet is offline
post #3 of 5 Old 01-18-2012, 12:07 AM - Thread Starter
ManMachine's Avatar
Yes I did. The wire is just fine.
post #4 of 5 Old 01-20-2012, 06:44 PM - Thread Starter
ManMachine's Avatar
It turns out to be really simple thing; the balance was turned all the way to right (probably by my kids). I felt so dumb.
post #5 of 5 Old 01-20-2012, 09:24 PM
nightvet's Avatar
Don't be too hard on yourself. Nobody else thought of it.
nightvet is offline
